Engine malfunction, reduced power e60 m5 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 10-29-2012, 04:24 AM
Beamerhead Beamerhead is offline
Mein Auto: 2008 BMW E60 M5
Angry Engine malfunction, reduced power e60 m5
Hello Guys, I just recently got my 2008 M5 it has 76k miles
Had it for a couple of months and its been perfect. I was driving all day today and not beating on it either and I don't really beat on it nowhere close to what some other people do. All day was perfect but I decided to take a little cruise from my house and 2 miles away I got on the highway that's when it said ENGINE MALFUNCTION REDUCED POWER....& THE ENGINE LIGHT It was driving very rough, and not all the power was there.. so I stopped on the emergency lane shut it off then turned it back on but nothing changed. So I drove it back home. Once I got on my garage it smelled like gas and like its running very rich. Turned it off for about 15 minutes. Then I turned it back on again to see if its gonna do it again and that's when bunch of smoke started coming from the exhaust, and the warnings were still there. Then I shut it off. And didn't bother anymore. The car is bone stock. I see some people had this problem but seems to go away with then after the shut it off and turned it back on. Mine won't go away.
PLEASE HELP
Old 10-29-2012, 01:44 PM
60 views and no replies................
Old 10-30-2012, 07:24 AM
DONROD DONROD is offline
Send a message via AIM to DONROD Send a message via Yahoo to DONROD
Mein Auto: 2013 535
On my 540 wagon, I had a similar issue and It was gasket on my intake manifold, I am looking at getting a 06 M5 so I hope this doesn't happen to me GOOD LUCK
Old 12-23-2012, 10:59 PM
timwe775 timwe775 is offline
Mein Auto: E60 M5
Angry reduced power
had similar issue occur 4-5 times as revs increased (without going hard). Sometimes in D mode and sometimes manual. No smoke or any other obvious issue. Turn engine off and on again and all error messages get reset and power was restored.
However, last time the messages have been reset but the orange engine light is still on and power appears to be still reduced.
Anyone else know about this issue (late standard 2007 E60 M5 with 80,000 kms now)
Old 12-23-2012, 11:59 PM
Thank you to the ones that commented and shame on how many viewers and no help or support. Anyways I had no choice but to take the car to BMW dealership and although I told them that I'm in the auto industry business they still tried to rape me on unesecary repairs but since I know how **** works that did NOT fly with me. I was told that my spar plugs were burned ($799) car won't blow smoke if spark plugs go out. So after our argument I told them that since that's what they're best at doing if they guarantee that if I spend $799 on spark plugs that it will fix my problem to go ahead and perform the work and if i spent $799 on something unesecary that I would go there pissed and there would be a problem since I'm not someome that can be ****ed with. They kept telling me that that's all they're seeing and without getting rid of that problem first they wouldn't be axle to know the actual issue. Again I told them that if you actually have a real tech checking into the problem to check it again since I'm by no means paying for unesecary repairs, like a lot of people do and get ripped off by mechanics, and told them to only call me after they found the actual problem...5 hours go by and I did recieve the call that I should of got in the first place without trying to ripp me off on $799 spark plug job that was not needed by any means.
So it ended up being Injector 1 went out and needed to be replaced. Since they realized that there not going to rape me they assured me that it was not the spark plugs and that was the actually problem. I authorized the work and also needed a oil change since some gas got into the motor.
They quoted me $1,800 on the injector replacement. I got other quotes from other dealers and jewed them down (YES YOU CAN NEGOCIATE WITH DEALERSHIP SHOP)
So hers what everything ended up costing me:
Injector 1 replacement $1,299
(((( the injector was only $230 the rest is labor))))
Oil Change $115.00
Out the door with taxes included
-----$1,495.98-----
That's not including the $208 for the tow.
To my luck I heard for the BP bad gas sales in August 13-23 and since all I buy is BP Gas I made a claim went thru the hassle for a month and just got a check for $1,703.98 :-)
CHEERS
Old 01-06-2013, 08:11 PM
Stone Roots's Avatar
Stone Roots Stone Roots is offline
Mugicinal Engineer
Mein Auto: 2003 E39 2009 E60
$1700 for a month of gas?
Old 01-07-2013, 10:30 PM
Mein Auto: E60 M5
Reduced power on E60 M5
Thank you for those that commented. Here is the update from the BMW Dealership.
Computer reported misfiring on Cylinder 3 so (and with no suprise now when you look at Stone Roots comments), a new set of spark plugs was fitted to see if this fixed the problem. It didn't. 2 days later no further news - still looking for source of problem.
Be interesting if it ends up being injectors or manifold as others posted. Will let you know what happens.
Old 01-08-2013, 09:55 AM
Mine was misfiring on all the cylinders at least what they said. But I don't trust the dealership at all.
Good Luck
Old 01-09-2013, 02:54 AM
Mein Auto: E60 M5
Angry M5 engine misfire update
Dealer has tried swapping injectors around between cylinders and cylinder 3 error still there, so back to the investigations..
Old 01-16-2013, 01:54 PM
S85FTW S85FTW is offline
Mein Auto: IB E60 M5, MW F30 328XI
What codes popped up? That could help narrow down the problem. You can go to autozone and get them for free. Write them down and report back.
Old 01-17-2013, 04:47 AM
Mein Auto: E60 M5
Diagnosis of misfiring M5 E60
Further to the misfire on Cylinder 3, it looks like the problem has been narrowed down to oil leaking into cylinder 3 (after new spark plugs, etc didn't fix problem). Interestingly, the engine error message (and reduced power) only occurs on cylinder 3, under higher revs/stress in moving from gears 2-3. Not any other gears. Sounds like head may need to come off - will keep you posted.
Old 01-18-2013, 09:58 AM
IEbimmerguy's Avatar
IEbimmerguy IEbimmerguy is offline
Mein Auto: E38, e23, e3
From what I hear, Autozone does NOT read codes anymore. "Too many shops got angry at us" was their response.
Old 01-18-2013, 09:59 AM
Funny because I had it done two days ago at an autozone.
Old 01-20-2013, 12:16 PM
B767capt B767capt is offline
Mein Auto: 2008 M5 SMG
A lot of people chase the misfire at high rpms. Usually an ionic sensor. You have 2, one for each bank. Swap the senors and see if misfire moves to the other side. If so, thats the problem.
Old 01-20-2013, 05:07 PM
Mein Auto: E60 M5
tks for the advice. have passed on to check it out. Just concerned about fact oil was found in cylinder 3 too.
Old 02-06-2013, 09:21 PM
Mein Auto: E60 M5
Angry E60 M5 engine malfunction update
Well I have a progress update now on oil in cylinder 3. Apparently the sizing of cylinder 3 is larger than BMW spec and other cylinders - faulty manufacturing. So we are in discussion about how best to fix here.
Stay tuned for further updates but in the meantime, BE VERY, VERY CAREFUL ABOUT BUYING ONE OF THESE CARS - THERE MAY BE ISSUES AND CHECK YOUR WARRANTY TERMS VERY CAREFULLY first.
Old 08-29-2013, 12:17 PM
thealla thealla is offline
Mein Auto: E60 M5, E92 328XI
Hi
Try to look for broken coilpack
if you have any, you changed your spark plugs right?
yeah try to look for any broken coilpack
then secondly, pull the codes from someone you know has the scanner
it sounds like Throttle actuator problems.....
I've had it. still has it but parts are on the way
Throttle actuators!!
Old 08-31-2013, 07:16 PM
Mein Auto: E60 M5
closure
actually worse than that. replaced plugs and most coils and advised oil leaking into one cyclinder and failing compression tests. new engine block and cylinders is the advised remedy. Good luck to those with the v10 M5, I hope this doesn't happen to you - I have moved on.
Old 09-27-2013, 10:23 PM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
lol ouch haha just as I'm getting ready to take the plunge on on an s85 smg
Old 10-24-2013, 05:40 PM
08M5V10 08M5V10 is offline
Mein Auto: 2008 M5
Same issue, "Engine Malfunction Reduced Power" and "increased emissions" warning.... Dont know where to start but the BMW dealership... I have extended warranty, so hopefully it will cover any issues that arise.
Old 11-07-2013, 05:55 PM
Mein Auto: 2008 M5
The verdict; coil in cylinder number 9 replaced. And the dealer wanted to charge me $1,500.00 for new spark plugs and one coil!!!
Went to autozone ordered the coil and got it done. $80.00 and 1 hour of my time. After watching DIY, ordered a obdII from ebay $135.00 reset the engine light.
Hopefully that will fix the issue!
Back to enjoying my car!!
Thanks for the help!!!! Very grateful
Old 02-19-2015, 07:42 AM
45cal 45cal is offline
Mein Auto: 545i
Cuz they haven't a clue what to say lol
Old 03-30-2015, 09:20 PM
r1rida07 r1rida07 is offline
R1rida07
Mein Auto: E60 M5
Did that solve the issue?
Old 05-15-2015, 06:48 AM
dallas535 dallas535 is offline
Mein Auto: 535
I finally resolved this issue
This was occurring for me. It took several trips to the dealer.
Ultimately they had to replace my VANOS solenoid. Since that was replaced I've not had the problem again. Fortunately, the car was still under warranty. I don't want to know what it would have cost otherwise.
