e39 540i Body Shell Project - Bimmerfest - BMW Forums
Old 12-17-2012, 02:26 PM
EmpScorpion EmpScorpion is offline
Mein Auto: BMW 540i
Hello,
I'm in the middle of replacing the passenger side shell on my e39. I have a parts car shell, and have been drilling out the spot welds. I'm at a point in the project where I could use some advice. (Do's, dont's, problems that I may encounter, etc.) Not sure exactley how to proceed from this point to get to the shell that I need. I need to replace the door jams, (from just in front of the passenger door to the tail lights. The parts piece that I have has plenty of excess material. Has anyone ever done this kind of work before? I would really appreciate any advice and knowledge about this project. I have attatched some photos.
Thanks!
Noah
Added on 1-6-13
Ok, as I'm getting more into this project, things are starting to make sense. I have found how the skin has been seamed to the car. I have removed a kind of putty sealant, which was covering the seams.
Question - Will the skin seperate without diffuculty once the spot drills and putty sealant has been removed from the seams?
ID:	353564   Click image for larger version
ID:	353565   Click image for larger version
ID:	353566   Click image for larger version
ID:	353567   Click image for larger version
ID:	353569   Click image for larger version
ID:	353570   Click image for larger version
ID:	353571   Click image for larger version
ID:	353712   Click image for larger version
ID:	353714   Click image for larger version
ID:	353715   Click image for larger version
ID:	353733   Click image for larger version
ID:	353734   Click image for larger version
ID:	353736   Click image for larger version
ID:	353737   Click image for larger version
ID:	356355   Click image for larger version
ID:	356356   Click image for larger version
ID:	356358   Click image for larger version
ID:	356359   Click image for larger version
ID:	356360   Click image for larger version
ID:	356361   Click image for larger version
ID:	356859   Click image for larger version
ID:	356860   Click image for larger version
ID:	356861   Click image for larger version
ID:	356862   Click image for larger version
ID:	356864   Click image for larger version
ID:	357055   Click image for larger version
ID:	357056   Click image for larger version
Old 12-18-2012, 01:30 PM
Mein Auto: BMW 540i
How do I get to the spot welds that I can't see? I need to remove the excess material, to get to what I need to replace. Major project, overwhelmed.
Old 12-18-2012, 01:46 PM
ItsTweek ItsTweek is offline
C.R.
Mein Auto: 530i
nice!
Old 12-18-2012, 04:37 PM
Mein Auto: BMW 540i
I want to save the car. It has 100k miles and is mechanically sound. I've had to replace the entire front suspension, motor mount, and the positive battery cable. (The HPS airbag deployed)
Old 01-06-2013, 10:34 PM
Mein Auto: BMW 540i
Old 01-07-2013, 11:27 AM
fortunateson fortunateson is offline
Mein Auto: 525i
Smile
That putty stuffis called "seam sealer" and must be re-applied after welding. You should really brace the original body tub up/down, sideways, and criss-cross so as not to lose original alignment of body. If you are good at oxy/ac welding you could weld the entire replacement piece onto the original after matching up the cut lines. Finish off with proper metal finishing process.
If you are going to just cut out spot welds and replace that is probably the better route especially if you are going to mig it all together. Take copious measurements off original tub and go at it. I would probably start at the "A" pillar then move onto the quarter panel. A bit of a job but can be done. After cutting out the spot welds you may have to do some prying to get the panels to separate. Good luck!
Old 01-07-2013, 10:01 PM
Mein Auto: BMW 540i
Thanks very much Fortunate Son! I have some help with the welding, and we are going with mig wire feed. The more I get into this project, the more things seem to be falling into place. I have the Bentley shop manuals for the E39, but it doesn't get into this type of work at all. Thanks again, as I needed to hear some feedback that it CAN be done! I'll post more pics as the project moves on.
Old 01-08-2013, 07:55 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
You are undertaking a project of proportions that the majority of us wouldn't dream of! Most of us would have started parting out the vehicle and bought another one. I commend your perseverance and wish you luck on your endeavor.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 01-09-2013, 01:44 PM
Mein Auto: BMW 540i
Thank You! The car has been sitting for a couple of years. I slid off a road in the Sierras after hitting some black ice. Thanks to BM Tech in Rancho Cordova, used parts have been plentiful, and not very expensive. I bought a couple of 17" style 19's from ECS Tuning, which saved a lot of money. I've decided it was time to start this project, as I LOVE this car. I had a 79 320i and a 71 2002 when I was in my twenties, and have been in love with BMW's ever since. I want the satisfaction of being able to put her back on the road, and put that scary crash behind me! It's a project of love!
Old 01-11-2013, 11:12 AM
Mein Auto: 525i
Hi again. I was just looking at your photos for the second time and it occurred to me to ask you what is the damage to your car. It looks like the "a" pillar and the rocker panel. Is there more (eg "b' pillar, etc.)? If it is only the "a" pillar why are you messing with the trunk area? Replace what needs to be replaced but don't go crazy and make more work. By the way, if there are a couple of small dents don't replace the entire panel. Once things are basically done take it to a body shop where they will have a cool little tool (name varies by brand). Basically they well little studs to the dent and then carefully pull the dent out, cut off the stud, and grind smooth. No stupid holes to fill afterwards. Let us know the progress, we're interested.
ADDED: If the "b" pillar isn't too bad I would definately get a body shop to pull/push it out with a "Porta Power" rather than cutting all that material out and trying to replace it. It can be done but it is a lot of work that may not be really required. Shops that do this kind of work do it smartly as well as correctly. I just don't want to see you get over your head and go to far and not being able to go back. Best of luck whicheer way you choose!
Old 01-13-2013, 03:15 PM
Mein Auto: BMW 540i
Thanks again Fortunate Son! I've attatched a few more pics. The rocker panel took the brunt of the impact. The B pillar (without a measurement) seems to be approx 1/4 to 3/8's pushed back. That is just by eyeball of how much the passenger rear door gap overlaps the door well. From these pictures, do you think that these dents can be pulled, or is it way too far gone for that kind of repair? I have started pulling parts out of the car, (backseat, passenger seat, trunk lid, passenger tail light, sunroof, headliner, ABC pillar covers,) and have been bag n tagging things for an easier reassembly. This site and the Bentley have been a huge help with removing things. I have more pics, or can take specific pics of the car if needed. I appreciate any help with this project!
ID:	357486   Click image for larger version
ID:	357487   Click image for larger version
ID:	357488   Click image for larger version
ID:	357489   Click image for larger version
Old 01-14-2013, 07:56 AM
Kingshanker Kingshanker is offline
Mein Auto: 2001 530I
Where do you plan on making the cuts? From what I can tell from the pictures you should only need part of the A & B pillars and the full rocker panel. Did the rocker damage make it to the inner floor metal? This is a big project to be done in a garage, especially if you have never done anything like it before. A port-a-power and BFH will help you greatly!
Kingshanker
Stable;
2001 530i
2002 325ci
2000 740il (sold)
Old 01-14-2013, 11:20 AM
sidneyj sidneyj is offline
Mein Auto: '03 BMW 530i
A
Mein Auto: 525i
Is the 3rd pic the 1/4 panel or what? I'd like to see a full view of the side and then none of the "a" pillar back to "b" pillar and yet anothe rone from "b" pillar back to rear bumper in order to get an overall view with details. I would use a porta power as much as possible and only replacewhat is truly beyond hope if you want the best shot at a 100% job. that beingsaid, if you have the skill, time, and patience you canreinforce the snot out of the cain and remove and replace everything.
Old 01-14-2013, 03:49 PM
Mein Auto: BMW 540i
The passenger floorboard has a small ripple, not very big at all. The skin behind the rear passenger door doesn't look damaged. With the skin being one piece, I was thinking that the whole passenger side would have to be replaced. I was going to follow a diagram I found on the net, (see attatched) and seperate near the tail light. The outer skin goes about an inch under the car, and about a 1/2 inch in the wheel well. The roof seems more tricky to find where the outer skin seperates from the roof panel and the side sheet metal. If it is possible for a body shop to repair this, and the cost wouldn't be too steep, then that would be great. I wouldn't mind paying a couple grand to have this fixed professionally. If the cost was more than that, I do have the time and parts to fix it on my own. (With help from my Bimmerfest friends!) I'm a machinist, not a mechanic, and this project has been an educational experience. I am having fun with this, so I wouldn't mind DIY if it is possible.
ID:	357703   Click image for larger version
ID:	357704   Click image for larger version
ID:	357705   Click image for larger version
ID:	357706   Click image for larger version
ID:	357708   Click image for larger version
ID:	357709   Click image for larger version
ID:	357710   Click image for larger version
ID:	357711   Click image for larger version
ID:	357713   Click image for larger version
ID:	357714   Click image for larger version
ID:	357715   Click image for larger version
ID:	357716   Click image for larger version
ID:	357718   Click image for larger version
Old 01-14-2013, 08:05 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Why not section in the rocker the the a pillar? The quarter does not look like it is messed up bad at all. Make sure to get the car pulled properly before you start cutting parts off.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 01-15-2013, 02:24 PM
Mein Auto: 525i
Smile
A lot of times when you pull/push surounding imperfections will almost disappear due to the reversal of the impact forces. The passenger side floor ripple could be an example. You may get away with the pull/push process for a lot of the damage repair. Then sectioning in a good piece of rocker panel (I would go from near the rear wheel well to the "a" pillar for a nice smooth look with less hassle on welding) should get the bulk done. Looks like a new left fender is needed as well. Re: the sectioning, cleco fasteners, magnets, butt weld clamps will greatly help in maintaining the pieces together as well as the proper gap for butt welding. Try to avoid lap welding if you can. Spray the pieces being welded together with weldable primer so they are protected from corrosion after welding. Either way, seam seal the snot out of the area; you wouldn't want any moisture sneaking in and starting corrosion. Magnets and butt weld clamps can probably be found at Harbour Freight. Paint prep and paint could be $$$ at a shop but I'm sure a machinist could learn how to do that NO problem! I need up-date pics as I've become addicted to this thread!!!!!
Old 01-15-2013, 02:51 PM
Mein Auto: BMW 540i
Yes, the rear quarter panel looks ok. I think I'm going to see how far I can get with disassemble of the parts piece. If I can be successful with that, then I will start on disassemble of the car. If it is too difficult, then I will scrap the parts piece, and go with a professional body shop.
Thanks Fortunate Son, this is a wealth of information! There is a Harbor Freight about ten minutes away. Do you think I should get as far along with the parts piece, as to minimize the labor cost, if I do have to have a professional complete the project? Maybe a combination of pro and DIY? I've attatched some more pics, as I can't find the seam on the roof panel.
ID:	357823   Click image for larger version
ID:	357824   Click image for larger version
ID:	357825   Click image for larger version
ID:	357826   Click image for larger version
ID:	357828   Click image for larger version
ID:	357829   Click image for larger version
ID:	357830   Click image for larger version
ID:	357831   Click image for larger version
Old 01-15-2013, 03:04 PM
Mein Auto: 525i
I'd try the Pro/DIY path for "fun and profit"! Seriously, this can be a lot of fun, a great learning experience, and a source of pride. Re: the roof joint. I would get one of those 3m stripping discs that look like and an oversize brillo pad and chuck it into the drill and then strip off the paint down to bare metal around where the filler strip fits between the main roof panel and the door jam areas. Do this on you salvage unit. I bet you'll see small indentations indicating spot welds. Voila. The got to be there somewhere, probably burried unde rseam sealer. As an alternative call or visit a body shop that has experience in working on BMW's, especially E39's, and ask them. You may find a sympathetic shop willing to guide you through this and perhaps willing to do the Porta power thing.
Old 01-15-2013, 03:37 PM
Mein Auto: BMW 540i
Fantastic idea! That's the tool and method I will use for finding the seam. Awesome!!! Here are some misc pics of what's been going on with the project since the wreck. I don't have the steering set properly, (alignment) but that's another job for another day. Also I bent the rear suspension, as the wheels wobble, which I noticed when towing the car. Three of the rims were ruined, (style 19's are very soft). The only rim that wasn't damaged was the driver front. I have two new style 19's and tires, along with my spare. (So I know the rims are not bent.) Things that I'll need to address later. I will keep you updated as things progress! Thanks again!!!
ID:	357836   Click image for larger version
ID:	357837   Click image for larger version
ID:	357838   Click image for larger version
ID:	357839   Click image for larger version
ID:	357841   Click image for larger version
ID:	357842   Click image for larger version
ID:	357843   Click image for larger version
ID:	357844   Click image for larger version
ID:	357846   Click image for larger version
ID:	357847   Click image for larger version
ID:	357852   Click image for larger version
ID:	357866   Click image for larger version
Old 01-15-2013, 05:59 PM
Mein Auto: 525i
I really like those rims. I have style 44's which are my favourite but yours are a close 2nd. You just don't see many style 19's around. How is the supply of interior parts down in CA? I may be needing a couple of things if I can't find anything good locally. And whereabouts is Rocklin?
Old 01-15-2013, 06:42 PM
Mein Auto: BMW 540i
The 44's are NICE! Rocklin is about 20 minutes north east of Downtown Sacramento. For used parts, I go to BM Tech in Rancho Cordova. (About 15 minutes east of Downtown Sacramento)
http://www.bmtechautoparts.com/
For new parts, ECS Tuning out of Ohio, has the best prices in my opinion.
http://www.ecstuning.com/
Both businesses ship anywhere.
BM Tech has a huge selection of used parts! I hope this helps!
Old 01-15-2013, 07:37 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
Wow, what a project.
"And if you no longer go for a gap that exists, you are no longer a racing driver because we are competing, we are competing to win."-Senna
Old 01-16-2013, 02:36 PM
Mein Auto: BMW 540i
Thanks BK!
Old 01-27-2013, 04:52 PM
Mein Auto: BMW 540i
I had a professional body guy come out and assess the car. He told me that the torque box is rippled. I was told that to get the car back to perfect, that it would be about 8k for the job. I don't want to put that kind of money back into the car. I'm not sure which way to go from here. Should I part it out, or sell the whole project in one shot? If I part it out, how should I go about doing this? Also, what is it worth? Any suggestions?
ID:	359426   Click image for larger version
ID:	359427   Click image for larger version
ID:	359428   Click image for larger version
ID:	359429   Click image for larger version
ID:	359431   Click image for larger version
ID:	359432   Click image for larger version
ID:	359433   Click image for larger version
ID:	359434   Click image for larger version
ID:	359436   Click image for larger version
ID:	359437   Click image for larger version
ID:	359438   Click image for larger version
ID:	359439   Click image for larger version
ID:	359441   Click image for larger version
ID:	359442   Click image for larger version
ID:	359443   Click image for larger version
ID:	359444   Click image for larger version
ID:	359447   Click image for larger version
ID:	359448   Click image for larger version
ID:	359449   Click image for larger version
ID:	359450   Click image for larger version
ID:	359452   Click image for larger version
ID:	359453   Click image for larger version
ID:	359454   Click image for larger version
ID:	359455   Click image for larger version
body work, e39 540, need advice, shell
