F12 / F13 (2012 - Current)
The future is now! The all new 6 series coupe (F12) and convertible (F13) details are out and dealers are taking orders. Still no word on when the 4 door Gran Coupe will go into production. |
Tire Pressure
What are you guys running?.. Just for my car back from the dealer and he ride seems softer.. I normally inflate the front to 39 psi and the rears to 40psi per the door sticker for driving over 100mph..
Truth is I don't go over that number much of at all.. I just like having the security of knowing that if I ever did I would be fine. What psi are you guys driving on?..
'14 M6 vert- montreal blue over amaro brown • 6 speed manual • Münich delivery this summer '13 X5M - carbon black over black • BBS SV • "it's our truck" '12 650 vert - alpine white over cinnamon • 6 speed manual • Münich delivery '11 Z4 - mojave over beige • 6 speed manual • Münich delivery ...and a bunch of old English motorcycles |
38/41 summer (staggered 245/35 x 275/30 - 20)
42/42 winter (245/45-18) |
38/38 per the sticker.
650i xDrive Coupe (2012), Carbon Black/Black/Gray Poplar, M Sport, Full LEDs, 20" 373M Wheels, ARS, HUD, CWP, Premium Sound, Nappa Dash w/ Contrast Stitching, Ceramic Controls, BMW Apps, PCD http://www.youtube.com/user/Southern6er22 http://southern6er22.blogspot.com/ |
What's the benefit of the front/rear difference? Is this a RWD thing, or is it something I should consider for my xDrive?
heh heh heh. Sent from my SCH-I605 using Bimmer App |
![]() BMW is still on my poopy list after The Great Engine Debacle of 2013. If Bönz says it, it must be true. I may just lose it one day and do something crazy like pump those babies up to 40 psi
43 rear, 40 front.
This thread will tell you most of what you want to know. http://www.bimmerfest.com/forums/sho...d.php?t=651450 R.
///M _650i Coupe (Sapphire Black) |
I just re-read the thread linked by roadsta. Although the manual has a section on FTM, our cars are equipped with the more advanced TPMS (also described in the manual). As stated, FTM looks for a difference in rotational speed of the tires. This is accomplished via the ABS speed sensors and therefore, FTM systems do not require pressure sensors mounted in the wheels. My E39 M5 had this system.
TPMS use pressure sensors mounted in the wheels that can read actual pressure - and in our case temperature as well. Unfortunately, US 6ers are not coded to display the pressure and temperature (although this can be changed). Both systems require reset after changing pressure, but not if you are only bringing one tire back to nominal (although it doesn't hurt). For what it's worth, my M3 had TPMS which only provided low pressure warnings (like the US 6ers). One day, after a scheduled oil change and SW update, the car could display actual tire pressure, by corner. I will never understand why BMW codes things like this differently in different regions - and then changes its mind. There is nothing regulatory about providing actual PSI readings in a TPMS equipped vehicle. It pisses me off. ![]() I would probably do the coding thing if I used a PC. I don't think the software works on a Mac. The IT schmoes at work have my work laptop all locked up. I can't install anything on it. Last edited by Bönz; 01-09-2013 at 09:04 AM. |
Off topic (what else is new), but I'm currently waiting to pick up my dead MacBook Pro. The motherboard died and will cost $700 to fix. I think I'm in the market for a new MacBook Pro...
Install a Virtual Machine on your Mac and install the software on the VM. Works great!
I have both a Mac and a PC if there is way to get the PSI to show up on iDrive and any of you awesome fellows know how to do it.. Would kindly post it here.. Please.. Thanks...:-)
You need a cable and software, I'll PM you information because we cannot post links to downloads.
![]() Quote:
I've attached it!
Hmmm. I will still struggle to build this cable myself. My soldering skills are a little iffy...
Can one buy them somewhere? Anyone who privately puts these together and is prepared to sell them? R.
Thanks Triple O. I appreciate that!
Roadsta. I am sure you can buy these cables, but if I recall they're pricey at over 100 bucks. You can make your own without soldering if you use a strip and crimp pin connector like this. I got mine from work (not that I can't solder, it's what we use) but if you google OBD II you will find them. Try carplug.com |
I'll PM you info.
