Old 01-09-2013, 11:26 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Lubricating Sun Shade?
This is actually on the E38 but the systems are basically the same as far as I know.
The shade went down and wouldn't come back up again. I can hear the relay for the motor when I press the switch, but no movement. The motor was not trying to run from what I could hear. After having the battery disconnected for a bit tracing down a current draw (I tried the sun shade again, and it popped up. Movement was a little jumpy, though.
So, I think some plastic is binding in bad spots and needs to be lubricated. I've left it in the up position so I can access it. Does anyone have instructions for where to lube the mechanisms, and is white lithium grease fine with these plastics?
Thanks!
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-10-2013, 12:09 AM
energizedmortal's Avatar
energizedmortal energizedmortal is offline
Mein Auto: 2003 530i
some report that white grease is fine but try to not add too much. Don't want things to gum up and clog drains. If anyone does have pdf on where to lube that would be great.
Old 01-11-2013, 09:17 AM
I Am The Machine
Friday bump....
Sent from my Galaxy Tab using BimmerApp
// Chad //
You're a derbanana
Old 01-11-2013, 11:17 AM
fullthrottle540's Avatar
fullthrottle540 fullthrottle540 is offline
DINAN 5
Mein Auto: E39
for mine, i greased up the upper rail (the part that actually goes to the top of your window when you move the shade up). I've never accessed the lower part of the mechanism though....
