Old 01-06-2013, 05:41 PM
robzues09 robzues09 is offline
Mein Auto: 740il
2000 740il NO START
Replaced the valley pan gasket intake gasket valve cover gasket, also new coils and spark plugs and OSV ran when i parked now wont stay running, start it then it dies all most instantly, give it more gas revs up then dies... any ideas
Old 01-07-2013, 10:35 AM
Nervous Nervous is offline
Mein Auto: 01' 330CI 6MT / 00' 540i
any codes? vacuum leaks (forgot to connect some vacuum hoses)? MAF is fine (disconnect and see if it works better)?
Old 01-10-2013, 02:28 AM
BMW 3-SERIES BMW 3-SERIES is offline
Mein Auto: 2000 540i Sport (E39)
I am like 90% sure its your CPS (cam position sensors) heres what mine did.
** Removed **
Old 01-11-2013, 09:58 AM
kupplung kupplung is offline
Mein Auto: 2009 BMW z4 sDrive35i
@robzues09, This is my situation exactly. @BMW3-SERIES, that video is exactly my problem. Did either of your cars throw codes? No codes here.
They will tell you these symptoms are also consistent with fuel starvation -- like a clogged filter or a weak pump. But in my case, fuel pressure at the rail is good (53psi), and I have already replaced the pump and filter. Today I am going to drain the gas tank, because I have no way of knowing how old the gas is. Robzues09, was your car sitting for a long time? Can you check your fuel pressure? (A gauge is fairly cheap at Autozone.)
I have changed out my crankshaft position sensor, but not my cam position sensors. No codes. I'm going to try new fuel then shell out 200+ for new CPSs, but at that point, I'm just throwing parts at it. Might as well try a new MAF and upstream o2 sensors, too
Old 01-12-2013, 06:51 AM
Mein Auto: 740il
Nervous Have not been able to scan for codes yet, all vacumn line are hooked up, i will try to dissconnect the MAF to see if runs better !!
BMW 3 Series it is doing the same thing as in your video i will look into replaceing cps
kupplung not sure on the codes but i will looking in that direction first...my bmw sat for bout 3-4 weeks before i got all the parts around!!
When i had someone try to start it when i would listen close to the motor it sounds like maybe my intake gasket moved on me i hear what sounds like a vacumn large vacumn leak all my vacumn line are fine
Old 01-12-2013, 01:06 PM
My car sat for the same time! That when I went to start it, it wouldn't. CPS 100%
** Removed **
HTML code is Off
