Old 01-09-2013, 12:50 PM
Rob13567 Rob13567 is online now
Mein Auto: 2000 528i
Exclamation New alternator help
So the red battery symbol has shown up on my 2000 528i and my car has started dying alot. What alternator replacement should i get? is there any deals or can i do something else like a rebuild or something?
Old 01-09-2013, 02:07 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
I have had bad experiences with alternators rebuilt by Bosch, i.e. noisy brushes or bearings; One would not even rotate right out of the box. More recently, I have had good luck with rebuilt alternators from Pep Boys.
Old 01-09-2013, 04:53 PM
how much did they charge? did the work on it take long?
Old 01-09-2013, 07:09 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Search forum for "alternator rebuild" using:
* New bearings x2 ---> $50 for both bearings
* Voltage regulator (HUCO brand) ---> $55
Look for posts by:
"Takechan"
"aioros"
"cn90"
This way you know you get quality alternator.
The rebuilt alternator from local autoparts store is usually a crap-shoot as people take short-cut when rebuilding alternator these days. Very often you end up trying 3 different alternators before you get a good one.
Old 01-10-2013, 01:42 AM
Type /alternator into the bestlinks and you'll get, among others:
- How to test your generator (1) & how to determine exactly what alternator you have (1) & a DIY for replacing the E39 I6 alternator (1) (2) (3) (4) (5) or E39 V8 alternator (1) (2) (3) (4) & why you want to clean out the air-cooled alternator air duct & cooling vents (1) (2) (1) (2) & why rebuilding an alternator is preferable to replacing (1) & cn90 DIYs for rebuilding a 1998 air-cooled BMW Bosch alternator (1) (2) or his VW Bosch alternator (1) & cdawg246's quest for materials for a Bosch water cooled alternator rebuild (1) & Aioros' 1999 Valeo Alternator rebuild DIY (1) and his quest for materials (1) & Cn90's explanation of where to get hard-to-get alternator rebuild parts (1) & how to tell from the part number if a replacement alternator is actually rebuilt "by" Bosch (1) & a DIY for replacing the brushes in an (Audi) Valeo alternator (1) & a Bosch alternator bearing replacement from a 1997 MB S600 (1) & from a Range Rover (1).
Old 01-10-2013, 06:18 AM
Mein Auto: '03 525i
Did it myself in about an hour and the cost was around $250 for the part.
Old 01-10-2013, 07:14 AM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
I would get a Bosch rebuilt. I dont know of any other brand that would be better.
Old 01-10-2013, 07:37 AM
Bosch rebuild alternators these days are a crap shoot.
As I mentioned above, some people have to try 3 diff alternators before getting a good one.
This tells you something: rebuilders take short cut and do a bad job rebuilding the thing and sells it to you for $200-$250.
Rebuilding an alternator is so easy, I don't know why people don't do it more often.
Two (2) bearings and a VR and you are done.
The only special tool you need is a gear puller ($10-$15) to pull the bearing.
Old 01-10-2013, 02:08 PM
So how much do you spend in total rebuilding your alternators cn90? and where can i get the gear puller at? and is it really that easy because i dont wanna mess up my car.
Old 01-10-2013, 02:13 PM
Go through this post by "Takechan", and click on the links I posted in that thread:
http://www.bimmerfest.com/forums/sho...d.php?t=668350
Old 01-10-2013, 02:20 PM
Thank you, much appreciated
Old 01-10-2013, 04:25 PM
nedmon nedmon is offline
Mein Auto: 1998 528i, 1987 Carrera,
I got a rebuilt Bosch from Rock Auto for $117. It is working fine.
Wife was a little nervous regarding the $ downside of a failure on the road as the car 98 528i has 150k miles on the clock so I did a preemptive changeout.
Ned
Old 01-10-2013, 05:31 PM
barneyhyphen barneyhyphen is offline
Mein Auto: 2000 323i sedan
Are we SURE you need a new alternator? Sure it's not a new drive belt you need?
BH
Old 01-11-2013, 03:31 AM
4given 4given is offline
Mein Auto: 1999 BMW 540i auto
I had mine rebuilt at a local starter/alternator shop for $127. It has a 2 year warranty.
Old 01-11-2013, 07:10 AM
Back in the 1980s and 1990s, I used rebuild Bosch alternator all the time, zero issues.
For the last 5-10 years, the quality of the rebuilt alternator has gone down a lot (do a google search and you will see). My theory is they use short-cut or using Chinese parts etc.
Just when you think you put a good rebuilt alternator in, it fails 6 months later.
Considering that the laternator is a crucial item (whn it fails, you are stranded), I take no chance.
This is why when you rebuild it yourself, you know for sure you put quality parts in there:
- Bearings x2
- Slip rings are optional.
- VR: stick to Bosch or HUCO and nothing else.
Old 01-11-2013, 08:51 AM
BH
how would i check? the car is 13 years old with a bosch 120a
Old 01-11-2013, 09:20 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
Maybe you just need to clean it? Debris overtime can get lodged in there and block airflow to cool it. I also agree, rebuilding it yourself would be better than gambling. It's also cheaper. This all depends on how much down time you can afford.
Old 01-11-2013, 10:21 AM
Serpentine belt. just start up the car, open the hood and look down the front of the engine, between the engine and the radiator. There's a long 3/4" wide ribbed rubber belt, driven by the crankshaft pulley at the bottom of the engine, which drives the water pumt, alternator etc. also travels around an idler pulley/wheel and tensioner pulley/wheel.
If this belt breaks, the alternator will stop working immediately, along with the water pump and, if you drive long enough, with it broken, the engine will overheat and you will blow the HG.
Good luck with your fix.
BH
Old 01-11-2013, 10:44 AM
BH
The belt looks fine, I've noticed with a multimeter that the battery is at 14 with the car on but when off it slowly starts to drain below 11.75 when off for couple hours( i have no amps, speakers etc completely stock) and the red battery symbol is lit, which i read in the manual means alternator problem.
Old 01-11-2013, 11:57 AM
Is the meter showing 14v at the same time the red battery light is on?
Must be honest, if I were getting 14v across the battery, whilst the car's running, not sure I'd run straight to thinking i had an alternator problem.
However, I think I might take the alternator out, pop the end off and at least clean it thoroughly with some electrical component aerosol spray cleaner. Can only help. Could perhaps be a VR problem in the alternator internal wiring?
could it actually be a battery problem, rather than an alternator problem? How old is the battery? Do you have another battery you could briefly swap in?
Good luck.
BH
Old 01-11-2013, 01:01 PM
Don't by chance have a power steering fluid leak from one of the PS hoses under the PS reservoir? They have a tendency to leak all over (into) the alternator. Such could very likely cause VR problems inside the Alt'
BH
Old 01-11-2013, 04:14 PM
Good luck.
BH
What is a VR problem? The red battery is only lit when I turn the key to the second position without turning on the engine.and the alternator is completely clean. Here is a pic of the battery
Sent from my SCH-I605 using Bimmer App
Old 01-12-2013, 08:45 AM
The battery light should be on if ignition key in 2nd position but engine not running.
You don't have a problem.
BH
Old 01-12-2013, 10:01 AM
rdl rdl is offline
Mein Auto: 530i 2003
From your description above, your alternator is fine.
However a battery reading of 11.75V after a few hours of rest means that you have either a bad battery or a parasitic drain problem.
See Bluebee's best links thread in the stickies on page 1 of this forum for help on diagnosing both.
Regards
RDL
alternator replacement battery
