Old 01-10-2013, 08:26 AM
ktono ktono is offline
Mein Auto: '13 X5 50i
Just took the car to the dealer for checking the alignment. I told them to provide me with the current specs. The car does pull a little to the right and is more noticeable at low speeds. From reading and being part of other alignment threads, I am interested to see where the toe is set. I will keep you posted.
Old 01-10-2013, 08:32 AM
I assumed he was clueless. He did say "30 to 50%"...
But lets step aside and let the real automotive geniuses carry on the real conversation
That's pretty harsh but whatever. If you want to check out their website I can surely send it to you. I have been in their dyno room when they were doing some R&D work on a regular 87 octane 350 V8 that had dual superchargers and at the flywheel it produced 2,000+ HP. Now that's no slouch. Maybe I should have mentioned that they are the leaders in Supercharging. Did not realize I needed to go into every minute detail, that's why I said "on a side note". Yes, I meant replacing.
Carry on geniuses...
Old 01-10-2013, 09:25 AM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
Originally Posted by ktono View Post
Yes I do understand that. Wish they were dual superchargers. Fun to have their techs check it out as they will give me some stats on what their system could do. Since they manufacture the supercharges locally they love the Turbo vs. Supercharger debate and I like hearing about the power!
Superchargers require horsepower just to run where Turbos do not require HP to run. There is no need to add 2 superchargers which actually doubles the para-static HP drag on the motor effectively reducing the HP even more. You are not going to get any more HP or boost out of an X5 using 2 instead of 1 Supercharger. Actually I don't know of a single street car and not 1/4 miler that actually has more than one SC.
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 01-10-2013, 09:54 AM
Agreed, two SCs would be overkill and wasted for this application. I have only see it in R&D work, turbos are a completely different story though with the temp of the boosted air. I get to hear these discussions with each visit to their plant. I like all discussions about HP and speed. They have some VERY fast Mustangs, Corvettes, Harleys and even jet-skis and ATVs.
Old 01-10-2013, 01:57 PM
Here are the alignment specs. Told them to set the toe closer to .01 - .02 and the camber looks way off on the rear. Am I reading this right? Negative 1.31 and 1.29 with the fronts at negative .03 and .06. Need some quick advice prior to pickup.
Old 01-10-2013, 01:58 PM
Sorry here's the specs:
Old 01-10-2013, 04:52 PM
ard ard is offline
Resident Curmudgeon
Prolly too late.
You told them right, but they just didnt follow your instructions. Your toe in the rear was BETTER BEFORE they changed it!
They gave you more toe in the rear, more toe on the right front.
That drives me nuts- especially when you say DO THIS.
The specs appear to be 0.0 to 0.10 for the front
0.02 to 0.08 for the rear.
Note their spec is 0.05 target, wwith a 'plus-minus' of 0.05 on the front; 0.03 on the rear.
Old 01-10-2013, 07:03 PM
Prolly too late.
Thanks for the quick feedback! I will post in the alignment thread to combine the discussion.
