E36 (1991 - 1999)
Performance chip
Hello guys, can someone help me plz? I need a performance chip for my 1992 bmw e36 316 ia (auto), any recommendation?
An auto 316?
Don't bother. Enjoy the fuel mileage and work on handling and braking instead. There are motorcycles with bigger engines. Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
Seriously. Do not waste money trying to add power to a 316 auto.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
Lolll guys i know, but i thought that can make some extra power in a cheap way, so the only way is to do an engine swap, right?
Btw i have another e36 with a tunned 325 engine, the 316 is for daily use only, i am enjoying the low fuel cost
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Hahahaha
Well While were on the topic, is the chip a decent option for the 2.8?
Up to you. (I'd also recommend an exhaust to pair with it)
I think you're looking for a reflash, not a chip.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
Turner is what I have in my car and I'm happy with it. Well that's with the M3 cams working together as well
errr.....reflash? no clue what that is..??
It's having your car's computer reset to a usually different standard.
"It doesn't do any good for me to know more than you if you aren't going to listen to me" |
On older cars and the M50 BMWs, the fuel maps and other engine control data are hard coded onto a removable EPROM chip. Simply pop out the chip and put a new one with different parameters and your engine program is different from
Newer OBDII cars don't have these removable chips. Instead you plug a unit into the OBDII port and it will upload the new programming to the DME. This is called a reflash. Sent from my Galaxy Tab using BimmerApp
http://en.wikipedia.org/wiki/Eeprom
The term comes from regular EPROM, which required a flash of UV light to reprogram. The EEPROM does this electronically, but the term stuck. Your Engine Control Unit has an EEPROM that stores timing information for the car. You can 'reflash' it to get a boost of power with properly programmed timing info. "Today I Learned..."
I always thought EPROM was electronically erasable, I've never even heard of wiping a chip with UV like that.
Interesting.... Sent from my LG Revolution 4G using BimmerApp
Yea it's pretty awesome. We learned how to do it at Virginia Tech, then the professor let us use EEPROMs, which you just stuck into a special circuit that would do it all really easy. "Gotta learn to crawl before you can walk, bitches!" - Our TA.
Most complex circuits with an EEPROM were designed with the flashing circuitry built in, so the engineers could reprogram the chips without removing them. This is what we have in our cars.
Ill have to look it up to wrap my head around it. thanks for the info.
So what your basically telling me is that the EEprom reflash is just as good as buying a new chip?? |
I'm saying that the chip in your car is not removable. Buying a new chip is a waste of money. What you really need to buy is a reflash. (Example) Usually they're sold with the equipment you need to hook it up to the connector inside the engine bay that allows you to reprogram your ECU.
You wouldn't buy new rollerblade wheels for your ice skates, would you? If so, I have some awesome ones you can buy...
AHA! its all comming together!
Ill be doing this project this weekend. if I can find the "Shark" |
Man it's definitely been a while. I'm fooling thinking that I can suggest a chip for an OBDII car.
