Old 01-10-2013, 03:40 PM
Kamal Baydoun Kamal Baydoun is offline
ULTIMATE DRIVING MACHINE
Mein Auto: 2003 BMW-Z4
#-#-# need help with turnsignal issue#-#-#
Hi to everyone and thank you in advanced for having me.
2003 Bmw z4
Issue im having is with my RIGHT TURN SIGNAL. everything seems to be working GREAT but i have a glowing indicator on my cluster that says i have a light thats burnt.
When i turn my right signal on it blinks MUCH faster then when i use my left signal. but everything seems to be okay
running lights side signal rear signal front signal all work fine. problem im having is the glowing indicator and the turn signal flashing\/blinking fast, can it be a relay? i tried removing the battery cable for a few hours with no luck
Old 01-10-2013, 04:04 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
The car is telling you that you have a burnt out bulb. The faster blinking is another indicator of a burnt out bulb. It could be a faulty relay but you better make SURE all (I think three maybe four) turn signal bulbs are good.
You are going to have to turn on the blinker, walk around the car and find the bulb...
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 01-10-2013, 04:06 PM
I did the turn signal in the front should stay on at night for running light it should also blink when turn signal is applied so should the side and so should the rear and they all work they just blink VERY FAST and i have a indicator light on the cluster.
where would the relay be located?
and if the relay is faulty shouldnt the left signals have the same issue because they dont
Old 01-10-2013, 04:31 PM
shipkiller's Avatar
Mein Auto: Me
Went back and looked. No relay. The turn signals are controlled from the Light Switch Module (LSM).
Here is a rough looking schematic of the circuit.
Unless your LSM is bad (most unlikely) you have a burnt bulb or a bulb on the way out and it's resistance is off so the LSM is reporting a bad bulb.
Name:	Turn Signals upto 09_2004.jpg
Old 01-10-2013, 04:44 PM
What else can it be i just ran outside with my father we looked at everything and it all looks fine?
Old 01-11-2013, 03:35 AM
brock5ga brock5ga is offline
Mein Auto: Z4
You may need to remove the bulbs and verify the proper bulbs have been installed. The vehicles with the lighting modules and bulb out indicators typically measure the resistance of the bulb to verify function. If the bulb is not replaced with a proper bulb of the same number, you will get the indication that a bulb is out, even if all are working. If you have recently changed a bulb, go there first. While bulbs may look and fit the same, they have different brightness and resistance characteristics. Start there first. Unplug the bulbs when inspecting and check for corrosion which may change the resistance characteristics.
Old 01-11-2013, 05:44 AM
FZbar FZbar is offline
Mein Auto: 2002 Z3 2.5 Roadster
How about a corroded light socket to bulb connection which could increase resistance.
Fred
Old 01-11-2013, 10:51 AM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
^ that was the problem with my car. I removed the bulbs and re-inserted them. Problem fixed.
Old 01-16-2013, 11:17 AM
DFREASE DFREASE is offline
Mein Auto: BMW Z3
Z3 river
I had the same problem. I found all the lights worked ok. The problem was a brake light bulb.
