Old 01-09-2013, 09:31 PM
kazzz kazzz is offline
Mein Auto: X3
Originally Posted by shawnsheridan View Post
And still, this to me is not a preferred method anyway. I would simply use my original FA, and VO Code each ECU to reset it. It is a much simpler and cleaner process.
I'm confused with this one. How do you VO Code each ECU? Do you click on Code Default Values under Esys/Coding while certain SVT is highlighted?
Old 01-09-2013, 09:35 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
NO! Don't ever hit Code Default Values, or you will likely be watching your car flatbeded to the dealer.
VO Code:
Connect => Read FA => Activate FA => Read VCM => Right-Click on ECU XYZ (the ECU itself not the underlying CAFD) => Select CODE.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 01-10-2013, 04:22 PM
Mein Auto: X3
VO Code:
Whew!!!... good thing I didn't try that. If I accidentally press that button, would Esys ask me for a confirmation if I really want to do it? (more like a second line of defense).. or would it just start bricking my car? Do I need to have the original ncd files inside the CAF folder to VO code?
Thanks...
Old 01-10-2013, 04:27 PM
Thanks...
I don't recall if it pops up a warning or not, but stay away from it as it will set your ECU(s) to a factory condition that has nothing to do with your actual car's configuration.
No, you don't need .NCD files to VO Code. An .NCD files is the as coded (read) state of the ECU. When you CO Code, it will use just the CAFD and the VO and write to the ECU.
- BMWCCA #446923
- flick
