E90/E91/E92/E93 (2006 - 2013)
Old 09-05-2009, 01:16 PM
redrum06 redrum06 is offline
Mein Auto: 2006 bmw 325i
interior paint peeling help.
ID:	200140 does anyone know how i could paint this it looks like i could sand it down and paint it. above is a pic of my driver side door handle the paint is peeilin off i also have the same problem with my cup holders peeling too
Old 09-05-2009, 02:18 PM
zymmee's Avatar
zymmee zymmee is offline
Do,do not.There's no try
Mein Auto: 2007 335i, maxima
remove it
320 grit sandpaper
spray can in a dust free area.
wear a mask
use a matt paint so it will hide your imperfections
Old 09-05-2009, 03:20 PM
ok thanks do you know what kind of paint and where i should get the paint from?
2006 325i red/tan interior
Old 09-05-2009, 03:56 PM
zymmee's Avatar
you can see if there is something specific at an auto supply store. like a vinyl paint
There is an automotive flexible trim paint available but your colour choice is limited to flat black.
If not, a home building center will have a plastic specific spray. I belive the name brand is Krylon.
Something else you may want to consider is doing a colour match on a few interior peices to match your body colour.
You will have to do a base coat then clear it. It's a little more tricky but the results are nice and you can go with a nice glossy finish.
You can buy this by the can at an automotive supply store.
BMW has a glossy black interior trim package available and it is stunning. You really have nothing to lose. If you totaly mess up go
find a high school that has a body shop and pay a student $20 to do it for you.
Old 09-05-2009, 06:09 PM
thanks for the help thats what im going to do, every time i open my door the site of the door handle makes me sick lol. thanks again
Old 09-05-2009, 07:13 PM
suncountry suncountry is offline
Mein Auto: 06 330i
Take your door handle to an Automotive Paint Store and see if they can match the color. They can probably look the color up in a book and get a good match. The paint needs to have an additive mixed with it so it remains flexible. I repainted my interior pieces on my 76 Corvette a few years ago. They are holding up well. Ask the guy at the paint store what you should use for a cleaner to prep the surface. Some of my parts I ran through the dishwasher as part of the cleaning operation. It took some work to clean all the years of dirt and smoke off.
06 330i Sport-Prem-Nav-Titanium Silver-Black Interior
01 F150 Supercrew
76 Corvette
66 MGB
Old 09-05-2009, 08:33 PM
philo98's Avatar
philo98 philo98 is offline
Mein Auto: 2007 335i; 2006 325i
Better yet. Take it to the dealer if your still in warranty. There is a tsb out for that. The 06's had that painted and then BMW realized the paint will peel and now that part is injection molded. I just had mine replaced under warranty. But the whole side panel needs to be replaced.
Old 01-10-2013, 01:35 PM
George Ab George Ab is offline
Mein Auto: 325i
I have a 2006 325i which is the year known for peeling paint on the vinyl door handles. Just search forums on "peeling paint". Finally got around to resolving. Took my OBD cover off and used as a swatch at autopart's store. Found vinyl paint by SEM and chose Medium Gray 15393. I heard on the forums that Presidio 15163 is also a good match. It is darker. I was pleased with the match of the Medium Gray.
I prepped surface area with hot water and dish soap using a grey scratch pad. I then used Goof Off to wipe down area using a shammy cloth. I then carefully masked off area. I removed trim piece as I contemplated removing the door panel to remove handle, but thought better of it. It was cold so I opened the garage door and turned the cars heat on. The can had been in the house so it was 70°F. I then sprayed some paint on a box as it initially will sometimes spit chunks. I then applied four thin coats waiting ten minutes between coats. I waited an hour and removed masking. I am pleased with the result.
ID:	356987   Click image for larger version
ID:	356988   Click image for larger version
ID:	356989   Click image for larger version
Old 01-10-2013, 06:29 PM
xdriver xdriver is offline
Mein Auto: 328i Xdrive
Wow! That came out great!
Old 04-21-2013, 06:14 PM
AVPM AVPM is offline
Mein Auto: 2006 E90
E90 center console peeling
My 2006 E90 console pint was rubbing off. I removed it, cleaned it all with Mineral spirits, taped it off and painted it with some spray paint. It did the job see pics.
Old 04-21-2013, 07:27 PM
kamigawa120's Avatar
kamigawa120 kamigawa120 is offline
* A BLUE PANDIAN SMURF *
Send a message via Skype™ to kamigawa120
Mein Auto: BMW F25 X3
That Plastic vinyl that Zymee is mentioning is called PLASTI DIP :3
Works wonders~
