X1 Driver Side Mirrors - Page 2 - Bimmerfest - BMW Forums
Old 01-10-2013, 07:40 PM
Perlova Perlova is offline
Mein Auto: X1 28i xDrive
Originally Posted by nospam View Post
I feel like I've asked this before: Why do you need to see the driver's side door? I guess I just adjust mirrors to see traffic, not my own vehicle. A bit of my rear quarter panel is all I need to see.
That's my point, I can't see anything of the car, unless I move my head closer to the window.
The curious part is that the passenger side mirror moves freely left to right to any position.
Old 01-10-2013, 08:20 PM
Wolfex Wolfex is offline
Mein Auto: X1
Originally Posted by Perlova View Post
Wolfex:
In my X1, I can't move it enough to the right to see the window or drivers side door.
I only adjust the mirror until I can barely see any part of the car. I never had a need to go further. In that position the blind spot is minimized and you can get a sense of where the car is in relation.
Old 01-11-2013, 10:42 AM
Wolfex:
I also position my mirror that way. But my observation is that regardless of the optimal position, the mirror should move more than that to take account of different sized people and seating positions. When my mirror is positioned as you inicate above, it is at its extreme right travel. And I still need to move my head to the left (closer to the window) to barely see the car.
I'm curious, how much further your mirror will travel to the right after you have set it to your desired position.
Old 01-15-2013, 08:48 AM
nonali nonali is offline
Mein Auto: 330i and X3
Believe or not, I've had this lack of travel range on the driver side mirror on my '06 330i for a long time. I am 6' 1 so I have not problem, but my wife is 5' 3 and she could not get the mirror to travel to the right enough so she could see the proper view.
She hates this so much now she refuses to drive the 330i and bugs me to get rid off it. (she is very safety conscious and very demanding in being able to see all the views around the car while driving.) I do notice that the '07 and onward 328 and 335 have gone to a larger and more squarish side mirrors. I wonder if any mechanic know how to make the internal adjustment so the mirror has a more range to travel to the right?
Old 01-15-2013, 01:08 PM
I would assume that there is no option for adjustment. They had my car in for this and decided to replace the mirror. New one is no better.
Old 01-15-2013, 04:14 PM
Farkled Farkled is offline
Mein Auto: Varies
Has anyone tried getting the euro convex mirror?
Old 01-15-2013, 04:38 PM
Mein Auto: X1
Wolfex:
My mirror seems to have a full range of motion from my seating position. I can move it all the way to the right and only see car and far the the left too.
Old 02-23-2013, 12:40 PM
amaynard amaynard is offline
Mein Auto: X1
Picked up my X1 a few weeks ago - exactly the same problem. Took it in for a service yesterday - was told the mirror movement was to spec, with the strong hint that I was complaining about nothing. It's livable with, but leaves a nasty taste in the mouth - first beemer, and may be my last at this rate!
Old 02-24-2013, 07:55 AM
e1322739 e1322739 is offline
Mein Auto: '13 X1 s28i & '12 X3 35i
I have been adjusting my mirrors as per the linked article for many years. No issues on my X1.
Old 03-26-2014, 07:54 PM
Böhme417 Böhme417 is offline
Mein Auto:
I found this thread after searching for the same issue. Upon examining the mirrors more closely, the whole driver's mirror is angled wider away from the car than the passenger's. I first noticed it from standing behind the car. The passenger mirror could barely be seen, but I could clearly see the driver's mirror. I measured them, and the angle of the passenger's mirror is smaller. Why?!
Old 03-27-2014, 05:30 AM
Von_W Von_W is offline
Mein Auto: 2013 X1 sDrive28i
Interesting that the article linked on page 1 of this thread does not address the drivers side mirror.
My X1 carries a Jan '13 production date.
Notwithstanding an actual defect in you mirror mechanism, I find my mirror has adequate design to provide visibility for me. I'm 6'0" and have the seat adjusted to near full back.
Having said that, in addition to preferring that my stock driver side is adjusted NOT to show the side of the car in my 'average' driving position. A quick tilt or lean of the head allows me to see the side of the car or to see a greater distance laterally if necessary.
Disclaimer: I have (always) added a round 1-1.25" convex mirror to both of my side mirrors on all my cars.
Tastes vary but my round mirrors are placed in the upper corners closest to the windows.
The confidence in knowing I won't miss something and peace of mind with these is tremendous.
Von_W
Old 04-03-2014, 05:29 PM
2013x1 2013x1 is offline
Mein Auto: 2014 X3
I also never have the side mirror adjusted to the right, showing my car. No problems. In fact I just moved it a bit further left.
Sharon
2017 X4 28i
2016 Mustang GT
2014 X3 28i - sold, 2013 X1 x28i - sold
2006 Mustang GT Vert - sold
Old 04-06-2014, 05:18 PM
imua1 imua1 is offline
Mein Auto: 2014 X1
I posted on this thread on Sept 13, not sure why its not here but again: Dealer has fixed the mirror problem. My short wife had troubles using the mirrors. There is actually a service bulleting for it, # SIB 51 06 13. Involves moving the mirror bumper stop. BTW there is also an SIB for wind noise on the mirrors. Involves putting glass tape between the gap between the mirror cap and housing.
Old 04-08-2014, 02:21 PM
mojo1 mojo1 is offline
Mein Auto: bmw 135i
Question Drivers side mirror issue
Is there an issue with driver (left) side mirrors on these cars. I test drove an X1 and notified the dealer that the mirror could not be adjusted enough to the right (Could not see the car door).In fact it warped the mirror glass as I moved it to the right stop.
I ordered the car anyway and when mine came in, I have the same problem.
Going in for repair but two cars with the same problem seems strange. Anyone else with this problem?
I have a 2014 with same issue. It won't adjust far enough inwards. I planned on taking it in for warranty work for the mirror at its first service. But it looks like its a factory defect.
Old 04-08-2014, 02:29 PM
Mein Auto: bmw 135i
Thanks for SIB
Before I saw your post I figured it was a factory defect that I would have to live with. Thanks to your post i realize the problem can be fixed. Thanks.
Old 06-30-2014, 02:01 PM
ccae92 ccae92 is offline
Mein Auto: 2014 X1 xDrive28i M Sport
Hi all, new to the forum but I have to thank you all for the info.
I just picked up an X1 xDrive28i M Sport, and I'm loving it, but my wife is way shorter than me, and can't adjust the mirror to a comfortable angle. I went to the dealer service shop here in Vancouver once, and they didn't think they could do anything, so I went back today armed with the service bulletin number.
Being Canada, they don't have access to all the US service bulletins, but my service manager here was able to find a relevant PuMA measure, which I think may be more international than US SIB numbers, so I thought I'd post it here for anyone in Canada with this issue. (The measure report says "US Market", but I presume that all North American BMWs are US Market spec. I don't think it's a defect so much as a lack of consideration for North American mirror glass. European ones likely have the convex magnifying mirror on the driver side.)
The relevant number is PuMA Measure No. 53675293-01, and the fix detailed on the description is to grind or sand off the upper pin (ie. bump stop) on the mirror glass carrier plate.
It also may affect newer F30 and F31 3 series models, FYI.
Old 11-07-2015, 03:32 AM
gpsmith01 gpsmith01 is offline
Mein Auto: X-1
I think your advice has been helpful to another idiot, me. My problem is the same but I also have a problem that after I back up they auto-adjust downward but when I go forward the mirrors stay down or return up only slightly, rather than returning up to their original position. I will try to adjust the mirrors properly and hopefully that will take care of it. But, could there be another problem...and an easy fix? Just thought I would throw the question out while on the internet. Thanks.
Old 11-07-2015, 04:47 AM
12 Handicap 12 Handicap is offline
Mein Auto: 2013 X1- Midnight Blue
Wolfex:
How far can you move your mirror to the right? In my Subaru, while seated in a comfortable drivers position, I can move it so far that all I see is the car window.
If I move the seat all the way back, the angle is better for me but then my feet can't reach the pedals.
I don't normally respond this way. Not trying to start anything here, but if you want to see the window or the door . Wait for it.....turn your head. I am 6' tall my wife is 5'2" and neither of us have an issue because you are using the mirrors wrong. the more you see the car the bigger the blind spot you are creating, Period.
Old 11-07-2015, 10:27 PM
MajorTranq MajorTranq is offline
Mein Auto: X1
Is turning mirrors out still not taught in driver's education? Surprising how few people use this technique. I learned it in a defensive driving class at work. About 20 years ago, and hadn't heard it again until visiting this forum.
That said, the side mirrors should have a full range of motion. Mine do.
Old 11-08-2015, 01:36 PM
vstolpner vstolpner is offline
Northern BMW Fan
Mein Auto: 2013 BMW X1 xdrive28i
I did an advanced car handling course that went through the adjustment as well and seems it's now different from what I was taught before - it's no longer that you want to see the tiniest edge of the car on the mirror, but you want the side mirror to pick up where the center mirror drops off. This reduces the blind spot but makes the parallel lanes look like they're coming at you at an angle. Takes a bit of getting used to but you end up seeing more
Old 11-08-2015, 02:19 PM
DjD-X5 DjD-X5 is offline
Mein Auto: '13 X5 xDrive 35i Premium
I'm in a 2015 x1 xdrive loaner right now and the drivers rearview mirror stood out about 30 seconds after I sat in the car! It's not a matter of proper adjustment, it's that the mirror doesn't adjust in far enough compared to other cars like my 2013 X5 or any of the other cars in my driveway that have power mirrors... I'm 5'11" and could not see more than a sliver of the car with my head against the window in my normal comfortable position; I really don't like my legs stretched out fully when my feet are on the pedals.
I was able to adjust the seat back and extend the steering wheel out and have a little less bend in my knees than I prefer in order to use the mirror properly. Anyone shorter than myself (enough to want the seat closer to the dash) will find the mirror on his car un-usable based on what I have experienced.
For anyone else reading this and having the same issue raising or lowering the seat cushion might also have a small effect on this too.
Dennis,
Old 11-08-2015, 10:18 PM
Northern BMW Fan
I'm 5'11" and my wife is 5' even and neither of us have an issue with it.
We have a 2013 - wonder if BMW changed the mirror at some point and the new one isn't as good? Could be defective pieces too?
Old 11-30-2015, 06:42 PM
autonomy autonomy is offline
Mein Auto: X1 xDrive28, Accord Coupe
I have my mirrors adjusted such that the rear view is centered on the road and the driver's side is adjusted as much to the left as possible so that as soon as a vehicle leaves the rear view mirror, it shows up in the driver's side. There is a tiny bit of a blind spot for me where when a vehicle to my left exits my driver's side mirror, I can't see it for a fraction of a second until it enters my peripheral vision. But at that point I am either aware of it, can hear it, or check for it. With this setup I have pretty much 100% coverage.
If you adjust your drivers side mirror to see your car door or in some way where you can see a car directly behind you, in the word of Steve Jobs, you're holding it wrong.
