E90/E91/E92/E93 (2006 - 2013)
Old 04-07-2011, 08:52 AM
pratik.shedge pratik.shedge is offline
Mein Auto: 325I 2006
warning sign on dashboard
I just bought a BMW 325i and it shows up this warning sign , not sure what it means..
if someone can share a view on this it would be helpful for me to fix this..
it shows a exclamation inside a triangle..besides the Parking sign..wat does that mean??
I have attached a image of the warning that it shows on the dash board
Old 04-07-2011, 08:56 AM
ctorrey ctorrey is online now
Porleau
Mein Auto: 2011 BMW 335ix M-Sport
Low pressure tire monitor. The triangle with exclamation point is just indicating that there is an alert.
ChuckieT
2011 E90 Black Sapphire| Chestnut Dakota | xDrive | M-Sport | STEP | ZCW| ZPP | ZXA | HK Stereo | CA
Gone, but not forgotten:
08 BMW 335i e90
05 Audi A4 3.0q USP
01 Audi A6 4.2q
98 Audi A4 2.8q
91 BMW 535i
87 BMW 325e
85 VW Rabbit GTI
cwinter's Avatar
cwinter cwinter is online now
Here comes trouble!
Mein Auto: 2009 328i E90 :)
The little warning sign at the top right corner of the display that shows "P" means there is some sort of warning currently active. This could include the fact that you have your seatbelt unfastened, that your low fuel warning light is on, etc etc. It just means there is some sort of warning.
Judging by the tire warning above it all, I would presume that once you clear the low tire warning it will also turn away. If not, there is a means to look up all active warnings.
Reading the manual is your friend. Welcome!
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 04-07-2011, 09:13 AM
okay, will try looking for that . and post what i see .
Thanks guys.
Old 04-10-2011, 08:17 AM
I performed a reset for flat tire by just parking at one place and all the warnings went off. guess it was just a faulty result before.
thanks for the help..
Old 04-10-2011, 01:25 PM
AzNMpower32's Avatar
Tar Heel Faithful
Mein Auto: X3
Ok. but did you actually check the tire pressures (when cold) with the tire pressure gauge?
Old 04-10-2011, 02:36 PM
noho335 noho335 is offline
Mein Auto: 2011 MINI S
Not the way to do it. If you just reset the system it could accept the low pressure as baseline. You need to check your pressure, as said above.
Old 06-01-2011, 02:22 PM
thanks guys had got that fixed by actually checking the tire pressure.
one more question, when it shows any error like suppose a "brake error" and if we reset it would it clear it out, or you have to fix it to clear it??
Old 06-01-2011, 02:55 PM
indeed330 indeed330 is offline
Mein Auto: '02 330i, '07 335i
I don't think something as critical as brake issue could just be reset to clear the warning. Why would someone want to do that anyway without actually fixing the problem...
2002 330i sedan, premium, cold weather packages, hk
2007 335i coupe, premium, sport, cold weather packages, nav, comfort access
Old 06-01-2011, 03:03 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
That exclaimation make has saved me, my tires and my rims.
Good feature.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
13 Porsche Cayenne Diesel
BMWCCA 4215
Old 06-01-2011, 05:11 PM
it was showing that error for me, i just tried reset it was still showing ...then the next day it just went off on its own ..
Old 06-01-2011, 05:48 PM
pointandgo's Avatar
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
Your tire pressure monitoring system (TPMS) is designed (as regulated by law - federal vehicle motor vehicle safety standards) to alert you if one or more of your tires is under-inflated by 25% or more (from your door placard pressures). In such case you will receive a dashboard warning/icon such as you have received. You need to check your tire pressures.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 06-01-2011, 06:13 PM
yeah..i have got that fixed..thank you ..
this time it was the brake sign..but it went off later on ...
also the driver seat door look doesnt open with the FOB , all the other doors open .. but i looked up and i think i need to replace the Fuse for that
Old 06-01-2011, 06:15 PM
pointandgo's Avatar
DON'T buy any lottery tickets this month.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 01-10-2013, 09:37 PM
Sunny328i Sunny328i is offline
Mein Auto: 328i Conv
New Owner trying to decode warning symbols
I'm a very newbee owner by 3-weeks. It appears I have similar warning symbols as "pratik" (see attached). This past weekend, I had a big RED bold explaination mark with triangle warning... took it in to dealer, they found a nail in one of the tires, plugged it and all was good until about 2 days ago then the other symbols appeared. Any suggestions?? I'm pretty annoyed at this point. Do yall think it's still a tire issue?
Help in... Sunny328i
Happy New YEAR
Name:	Dash Errors.jpg
Old 01-10-2013, 09:52 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: BMW X3
Pump all tires to correct pressure then reset
06 130i
07 320i
08 E92 325i
Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton, Argon 18E114
NEXT CAR : Golf Gti R
