Old 01-07-2013, 06:37 PM
jbonly21's Avatar
jbonly21 jbonly21 is offline
Mein Auto: 02 525I SPORT
E39 suspension setup
Been doing some research on lowering my car. I know everyone says to go with bilstein, but if I wanted to go with Sachs sports. What is the best spring for this set up? My car is my daily drive. Thanks for any info, Remember I know bilstein and koni are the best, but I am trying to keep it stock. I am looking for opinion from people running Sachs sports springs.
02 525I Sterling Gray, 18" M Parallels, M Tech bumper, Magnaflow Highflow cat, Resonator delete, 3" OBX muffler, H&R spring and Bills sport shocks.
RIP ALPINE WHITE 97 528I
Old 01-07-2013, 10:55 PM
jbonly21's Avatar
Up up.
Old 01-08-2013, 04:36 AM
Fudman's Avatar
Fudman Fudman is offline
You may want to consider using the sport suspension setup (springs & struts) from later models (01-03) although I cannot confirm that they would fit (I believe they are compatible). I find they give an excellent blend of ride quality and handling. And they would lower your car just a bit without risking bottoming out.
Old 01-08-2013, 08:08 AM
540nj 540nj is offline
Mein Auto: 03 540i6
Why not just get the stock sport spring for your car? I put Koni Sports to replace my stock struts (M5 for 03 540), ride is very close to OEM. Kept same springs.
dave
03 540i6
Old 01-08-2013, 08:52 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
For springs, very close to OEM, you could get the Vogtland 951027 JDM Werks has them (e-bay linky) for 219.62$.
OEM sport springs are more expensive I believe (if new).
Old 01-08-2013, 08:35 PM
jbonly21's Avatar
How do I tell if these really are stock sports spring.
Old 01-10-2013, 07:56 PM
jbonly21's Avatar
Is there really a difference between those two?
Old 01-11-2013, 05:28 AM
Fudman's Avatar
One will lower the car more than the other. Typically a shorter spring will also be stiffer than a longer spring to reduce the likelihood for bottoming out due to the shorter travel length.
