Old 06-30-2012, 04:33 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by cn555ic View Post
Asked him to check his CAFD files and he has yet to respond, so until he posts his findings, I will be quick to say BS
As soon as he posted that on 6/24, in the very next post I challenged his assertion as the Missing CAFD error is related to a PSDZdata file, not an E-Sys file, and asked him to confirm it, and he hasn't yet. He said he was going to check it last night though and confirm it, but still no update yet.
In any event, besides the fact that we go though this every single time a new ISTA/P comes out, and E-Sys v.3.18.4 has yet to not work with the new PSDZdata files, in this specific instance, we have already seen where both users DESI4life10 and RASHID007, using E-Sys 3.18.4 could not code the FEM_Body ECU on brand new F30's using the v.46.3 CAFD_00000794-002_020_026 file; however, when it was updated with the v.46.6 CAFD_00000794-002_020_029 file, they were able to successfully code FEM_Body ECU with E-Sys 3.18.4.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 06-30-2012, 05:58 PM
Losco Losco is offline
Mein Auto: 2010 528i M-Sport
Originally Posted by mjgood View Post
I just got my car back from dealer, I have some problems with BMW Assist...
They had it almost 2 weeks and have been working with BMW Engineers, and no fix yet..
Dealer was told to put latest update on to try and fix, but it will be a week or more before they get the update, so I have my car back until the updates come in.
What I'm reading from this is that 46.6 may not be at all the service departments yet, once it gets out there the PSDZDATA files will probably start showing up...
E-Sys is probably the program we should all pool together on....
we're slightly off topic, but yes, last year e-sys 3.13(one that had est crack) did not work with new 44.0(I think), hence no one could code new cars... we're good now but don't know what will happen from here. we need java gods in our forum now
Old 06-30-2012, 08:43 PM
cn555ic cn555ic is online now
The Coder guy in N.Y
Mein Auto: bmw
I still think it will work regardless of E-sys version. How does one obtain these newest versions of the ISTA data is where we need to channel our collective energy. WIth the community as large as it has grown, a group effort to get enough funds to get these updates should not be a problem. We need to find the source of where to get it from. Anyone have any ideas how and whom do we contact as a direct source to get this data???
Old 11-17-2012, 11:31 AM
dodeemad dodeemad is offline
Mein Auto: BMW 750
Hello gu
I need your help. look i have the 48.0 data file but when im running the e-sys its giving me error which was coming with our firned Big Sarge !
Any one can help? im using I com and with 3.20 V
Old 11-17-2012, 03:04 PM
April1 April1 is offline
Mein Auto: X3 2011
READ FA ERROR:
Few have reported "READ FA Error........"
This kind of error you will get when after clicking the Connect button and picking up the right SELECTOR, you do not select "CONNECT via VIN".
You might get a messge that EYS connection established (..162) but infact it is NOT.
Old 11-17-2012, 05:13 PM
Originally Posted by April1 View Post
READ FA ERROR:
Or incorrectly selecting the target with the _DIRECT after it.
- BMWCCA #446923
- flick
Old 01-11-2013, 12:59 PM
DaKoren DaKoren is offline
Mein Auto: 2006 Black Sapphire M6
I'm having some trouble connecting to my car all of a sudden.
I can run the ZGW search and it will find the car but esys gives me a grayed out box for connecting via vin and a message that says "No ZGW Available"
I have tried ripping out Esys and reinstalling to no avail. Firewall is off for this connection. and I am able to see the list of Targets just no connect bus.
I was also able to do some coding before on this laptop with no issues, this problem just cropped up.
Any ideas?
2013 - Monte Carlo Blue M5
2011 - X5 35d
------Retired----------------------
2007 - Jet Black 335i
2003 - Silver Gray Metallic M3
2006 - Black Sapphire M6
Old 01-11-2013, 01:06 PM
Any ideas?
And nothing is different about either your setup, or your car since when it was working with no issues?
- BMWCCA #446923
- flick
Old 01-11-2013, 01:10 PM
Not that I am aware of on the laptop. The laptop is exactly the same it only gets used for coding.
The car was in for service and had an update run but I had been able to get in to it since then but only once.
Edit: got it working on another computer... odd but at least I can code again.
2011 - X5 35d
Old 04-24-2013, 06:02 PM
jeremy480 jeremy480 is offline
Mein Auto: na
connection problems
I was using E-Sys a while ago and had everything working fine. Fast forward a year, I took my 2012 328i to the dealer to take care of a recalled sensor and they reset everything I programmed. Well, I now have a new laptop so I had to download and re-install all the coding software.
The issue I'm having is that I cannot connect to the E-Sys software. In E-Sys the Connect via VIN box is grayed out and says No ZGW Available even though the ZGW software is clearly reading my VIN.
One of the first tips in this thread was to make sure the "dist" folder is located within each of the mainseries folders, which it is. I also made sure the EDIABAS.ini file has ENET listed next to interface as another thread suggested. Attached is a screenshot of the grayed out VIN connection.
Any thoughts? Am I not making a proper connection to my car somehow and if not how was the software even able to pull up my VIN if it isn't?
UPDATE: Turns our one of my network cable wires broke at the solder joint. I can connect just fine now.
Now I just need to find an updated HU_CIC data set or something because I cannot edit the file at all. O_o
HU_CIC [63] [F343228]
readCPS o.k.
cafd_000000f9-007_006_009 Fehler:
File for "cafd_000000f9-007_006_009" not found! [C012]
Name:	esys screenshot.jpg
Old 04-24-2013, 09:02 PM
readCPS o.k.
If you need that CAFD, you have ISTA/P 2.49.2 on your car. Besides needing cafd_000000f9-007_006_009 for the Head Unit, it also means you won't be able to code anything until you update both your E-Sys and PSdZData.
PM sent.
- BMWCCA #446923
- flick
Old 04-24-2013, 09:14 PM
Mein Auto: na
PM sent.
Yeah, I'm learning all sorts of new things today. A lot has changed since I first did all this coding to my car about a year ago. I also just learned that I now need to pay for a patch/token this time which wasn't necessary before.
I guess someone wanted to get a piece of all this hacking action and pad their pocketbooks a bit with some extra $$!
Thanks for all your help, Shawn. You seem to be the resident expert around here.
Old 04-24-2013, 09:22 PM
Not exactly. BMW made some security chnages to the PSdZData beginning in version 48.2. This rendered the old E-Sys 3.18.4 everyone was using useless. Fortunately, someone developed a solution, and while it does come with a price, at least it is a very reasonable one.
- BMWCCA #446923
- flick
Old 04-26-2013, 05:06 AM
dmattiazzi dmattiazzi is online now
Mein Auto: BMW 120D Sport F20
PM sent.
Hi, i have the same problem on my F20 after a bmw service....
now i have the psdzdata 2.49.1, is possible to have a link to 2.49.2
thank Donato
Old 04-26-2013, 06:15 AM
thank Donato
PM sent.
- BMWCCA #446923
- flick
Old 04-26-2013, 11:14 PM
webb webb is offline
Mein Auto: korea
Hi my friend.
PM sent.
Hi Shawn,
I need the 49.2
Can you please PM me the links for 49.2
Thanks advance.
Old 04-27-2013, 03:38 AM
Originally Posted by webb View Post
Hi Shawn,
I need the 49.2
Thanks advance.
PM sent.
- BMWCCA #446923
- flick
