E34 (1989 - 1995)
Closed Thread
Old 01-11-2013, 08:50 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
Originally Posted by Monsignor View Post
pick up another DME. they go for the price of a full tank of premium. Check which one you have
Originally Posted by BMR_LVR View Post
He has non-vanos. He should have brown label 402 DME.
There you go
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
  #27
Old 01-11-2013, 09:24 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
answer this as honestly as you can because i take everything with a grain of salt here (nobody wants to seem like a noob or an idiot and they lie about the thing that will fix the car, to their own demise)
Did the car ever right after that head gasket job by your buddy?
Also, please define "BMW Mechanic." Certified? Works at a dealership? Or is he a lot jockey with a wrench...
  #28
Old 01-11-2013, 01:51 PM
E34_Obsession E34_Obsession is offline
"The sound of the M50"
Send a message via ICQ to E34_Obsession Send a message via Skype™ to E34_Obsession
Mein Auto: 91 525i
Im troubleshooting right now. Ill get back to ya'll
1991 BMW 525iA
1999 Toyota Tacoma Prerunner
2008 Toyota Tacoma Prerunner Sport -
1995 Toyota Tacoma 2WD DX V6 - SOLD
1992 Toyota Pickup - SOLD
2003 Subaru Forester 2.5X - SOLD
2004 Subaru Forester 2.5XT - SOLD
  #29
Old 01-11-2013, 01:58 PM
Monsignor's Avatar
what are you trouble shooting?
Double checking the ICV and putting fresh gas in it? waiting on the video
2006 325i/6 48k mi
Garden State Euros
  #30
Old 01-25-2013, 06:56 AM
Mein Auto: 91 525i
Sorry I have been absent guys... Quick question... Could the sensor that measures the amount of coolant that the car has prevent the vehicle from starting?!?
1991 BMW 525iA
  #31
Old 01-25-2013, 07:04 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
No.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
  #32
Old 01-25-2013, 07:23 AM
Monsignor's Avatar
you never took that video, so lets try that.
from the 11th. two weeks ago.
No.
+1
  1. Did you ever check the cams and the dots on the top of the squares at the back?
  2. Did you pick up a DME?
  3. Did you put fresh gas in it?
  4. Did you double check your ICV?
  5. Did you ever get it started?
EDIT @ 2:14PM 1/25/13 - OP is online but silent. WTH
2006 325i/6 48k mi
Garden State Euros
  #33
Old 01-25-2013, 12:24 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
+1
Steady on
Old 01-25-2013, 01:16 PM
Monsignor's Avatar
Originally Posted by _Ethrty-Andy_ View Post
Steady on
its hard to help people asking for it when they do this...
"My car wont start. It looks okay"
then radio silence
2006 325i/6 48k mi
Garden State Euros
  #35
Old 01-25-2013, 01:21 PM
BMR_LVR's Avatar
Humble E34 lover
then radio silence
  #36
Old 01-29-2013, 07:22 PM
Mein Auto: 91 525i
  #37
Old 01-29-2013, 07:23 PM
Mein Auto: 91 525i
Allright all! Here is the video of the cars behavior!!!
  #38
Old 01-29-2013, 07:40 PM
Mein Auto: 91 525i
  #39
Old 01-29-2013, 08:15 PM
CamphorE34 CamphorE34 is offline
Banned
Mein Auto: E34
Cylinder wash. Oil in your chamber walls have been washed off too much by gas. Compression too low.
That's why your oil light goes off even while cranking and before she catches. Second and third start on the video. Too little resistance to crank, so it spins faster.
  #40
Old 01-29-2013, 08:17 PM
Mein Auto: 91 525i
How would I go about restoring the compression?
  #41
Old 01-29-2013, 08:24 PM
Mein Auto: 91 525i
Ok I will try that also I will disconnect the sensor. Is there a reason why I should? And is it the blue one in the head?
  #42
Old 01-29-2013, 10:05 PM
Mein Auto: 1989 525i M20B25
Hold the Phone, everyone.
Let's get back to square one here, that is:
-Fuel
-Air
-Spark
-Compression
Test for these, and if you have, tell us exactly how you tested for these 4 things.
see this if you havent:
http://forums.bimmerforums.com/forum...&highlight=m20
You must rule out those 4 things as problems.
Only then can you assume a bad ECU.
  #43
Old 01-30-2013, 08:52 AM
Mein Auto: 91 525i
Has Fuel- Took fuel rail off and each injector spray's, also replaced fuel filter, fuel regulator, and they are new BOSCH oem injectors...
Has Air- New air filter, MAF is good, yadayadayada...
Has Spark- All six coils throw strong spark, also replaced spark plugs...
Has Compression- Used Snap-on compression testor, all six were in the 150-170psi range but all six were around 165ish.
  #44
Old 01-30-2013, 09:15 AM
BMR_LVR's Avatar
Humble E34 lover
Have you checked the throttle position sensor (TPS)?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
  #45
Old 01-30-2013, 05:57 PM
Monsignor's Avatar
I agree with steve about the TPS. I would also check the ICV. It kind of sounds like hell, man :/
You butterflying the throttle like that is sort of a manual idle control. The ICV isnt the easiest to get to (remove intake manifold) but that could very well be your issue. The TPS could also be just as likely. The motor doesn't seem to respond well if at all to being thrown WOT. Have you tried a less extreme "Floor it! Lift! Floor it! Lift etc" approach. Like holding it at 25%?
2006 325i/6 48k mi
Garden State Euros
  #46
Old 01-30-2013, 06:31 PM
How could a bad TPS cause the engine to run as terrible as it does?
  #47
Old 01-30-2013, 06:42 PM
Monsignor's Avatar
The engine doesnt recognize the throttle position. In the video you see OP smashing the throttle wide open without any reaction from the engine
2006 325i/6 48k mi
Garden State Euros
  #48
Old 01-30-2013, 06:50 PM
The engine should run fine without the throttle position sensor. IIRC, it is just a switch to tell the ecu that the engine is at idle, off idle, or at WOT.
UNLESS, the M50 engine has a different TPS, but normally it would substitute a value in place of it.
  #49
Old 01-30-2013, 07:06 PM
Monsignor's Avatar
It seems OP was going to WOT without reaction. Even still,
ICV could cause this.
2006 325i/6 48k mi
Garden State Euros
  #50
Old 01-31-2013, 04:05 AM
Sounds like you have a massive vacuum leak after the MAF. Check the rubber boot before the throttle body
Closed Thread
