E30 (1982 - 1993)
Old 01-10-2013, 07:13 PM
Titan_Omega Titan_Omega is offline
Mein Auto: 89 325iX and 97 328is
Getting a 318iS any suggestions?
I will be getting a 91 318iS from a shop where i live the guy has always owned a E30 and is a really good guy. Well what im wanting to do is i herd that this is knows as the Baby M3. Well I want to maximize the performance of the M42. When i have the cash ill get a S14 and throw that in there but that's in a few years.
What i want to do is:
- MAF conversion ( cant find much on this i have a M20 and that seems a lot easier to find info on than the M42 )
- Shift/E-brake boot black with tri-color Motorsport stripe stitching $180.00 http://www.uucmotorwerks.com/ultrasuede/
- COP Kit -
M42 Plate, & Installation Hardware (no coils)
http://www.hqautosport.com/products1.html
Bavarian Autosport High-Performance Ignition Coil Set - Set of 4
- UUC Evo3 Shifter
- Fuel revamp -
19Lbs injectors
http://www.precisionautoinjectors.co...02?productId=1
markD91 chip
http://www3.sympatico.ca/mdsylva/products.htm
- BMW E30 M3 Sport Evolution real leather front center console
- E30 Quick Ratio Steering Kit ST-3
- EVO3 Steering Wheel for E30 Alcantara Suede
- Supersprint exhaust manifold
- BMW E36 Vader seats
- BMP Multi-throttle intake
- VAC - M40, M42, M44 Lightweight Race Flywheel & Clutch Kit
- Head work -
- Schrick Cam shafts 256/256
- M42 High Performance Valve Spring & Retainer kit (48 pcs) Titanium
- VAC - M42 / M44 High Performance Valve Guide
- VAC - M42 High Performance Stainless Valve Kit [7mm Valve Stem] (16pcs)
And what would a 2.1L stoker do to this car?
and what ever elts you may suggest ill think about.
so anyhoo any suggestions?
Old 01-10-2013, 08:57 PM
BMWFatherFigure's Avatar
Old School
Dunno about stroker but 'fast road' cam and free flow exhaust can work wonders. Decent headers also can give gains. Insp 2 serice plus whel alignment and tune up and see exactly what you have B 4 spending lots of folding.
Current:
E38 Parts Car
Previous:
Old 01-10-2013, 09:23 PM
well I know what i want to do with this car. I do want to eventually have it a high revving engine. I have been doing some research on the stroker and its not a easy thing to do. the crank is a pain in the ass to get cause it comes from a M47 i guess an engine BMW made for Land Rover. So thats not high on my list lol but i would like to completely revamp the heads. Polish, Porting, Over-sized valves, i mean the works. then move to the bottom end and that will be the stroker. I would just transplant a S14 and tweak that but i rather destroy a M42 that a S14.im willing to put the money into the car thats needed I just need more research.
I will be putting in performance cams from schrick along with a free flow exhaust.
My main concern at this time is a MAF conversion and i understand thats no easy feat. I wanted to know if i could simply take the MAF off a E36 318 and drop it in the E30 and replace the AFM driver with a MAF driver in the ECU and if that is possible then ill do that.
I just sent a Email to VAC Motorsports to see if they can make a M42 stroker kit with a 11.5:1 compression ratio with a 88mm Crankshaft stroke and 86 mm bore. i hope i put the right numbers if not ill sound like a total moron lol
Old 01-10-2013, 09:40 PM
VAC has this for 4 cylender cars would anyone use this on there 318?
http://store.vacmotorsports.com/aem-...ecu-p2650.aspx
Old 01-11-2013, 11:00 AM
I am going to get a Megasquirt system for the engine management so i can just delete the AFM totally. and with that I can pretty much do anything to the engine. ill be doing a lot of research before purchasing and doing this so any info on megasquirt you think would be helpful I welcome it.
Old 01-11-2013, 02:29 PM
well i have been making some calls around to see about a price on a carbon fiber valve cover for the M42 similar if not exactly like the S42. Ill post when i get more info and pricing.
Old 01-11-2013, 03:19 PM
it looks like the best option is to take the valve cover to be machined down a bit and put a carbon fiber layer over it thats about the best that can happen........that sucks........
