Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 E84 (2011 - current)
The new to the US BMW X1 will arrive at BMW dealers in the fall of 2012 as a 2013 model year. Get your X1 28i with either sDrive (RWD) or xDrive (AWD) or get the US exclusive I6 N55 powered X1 35i dDrive.
Old 01-11-2013, 10:07 AM
vbbuilt vbbuilt is offline
Mein Auto: X1 xDrive28i
My BMW Remote - iPhone app
I have the iConnect. I downloaded this app for the iPhone 5. One of it's features is to locate your vehicle, but no instructions came with the app.
I'm wondering if anyone has experience with this app?
While sitting in the vehicle, I selected the locate button, but the app responded "Vehicle location unknown. Update vehicle status and try again." Obviously, I'm not doing something correctly. How do I update the vehicle status?
Thanks, vince.
Old 01-11-2013, 11:12 AM
Perlova Perlova is offline
Mein Auto: X1 28i xDrive
Thanks, vince.
Here is the essence of what it can do: On the X1 you can only do the locate and lock/unlock function as far as I know.
•"Remote Door Lock & Unlock" allows the car to be locked and unlocked from a smartphone.
•"Climate Control” makes it possible to control the interior temperature by adjusting the auxiliary ventilation and heating settings, and programming the systems by timer.
•With “Horn Blow” for sounding the horn and “Flash Light” for briefly switching on the exterior lights, users can trigger acoustic and visual signals to help them find their vehicle in crowded car parks, for instance.
•If the car is out of sight and hearing distance but within a radius of up to 1,5 km, the “Vehicle Finder” function is able to display a map on the smartphone screen showing the way to the vehicle’s location. This function is only available when the ignition is switched off, thereby making it impossible to track the vehicle’s movements.
•Finally, using Google Local Search, users are able to import points of interest (POIs) from their smartphone into the vehicle’s navigation system via the message list.
Old 01-11-2013, 11:57 AM
I''m not sure what you're looking at, but this app has no function for controlling climate control, blowing a horn/flashing lights, nor interface with vehicles navigation system. You must be referring to another app?
Old 01-11-2013, 12:23 PM
vbbuilt....depending on which vehicle you have, this app can do more control functions. On some vehicles it can honk the horn, flash the lights and turn on the climate control system. On the X1 it can only unlock doors, find the location of the vehicle and send map data to the car.
Old 01-11-2013, 08:48 PM
nospam nospam is offline
Mein Auto: X1 x28i; 128i; S2000
Since it is an Exx series vehicle, the X1 should be able to support Google Local Search (w/send to iDrive), Remote Door Unlocking/Locking, and Vehicle Position. My parent's F30 does even more.
This FAQ doesn't include the X1 unfortunately: http://content.bmwusa.com/microsite/...remote_faq.pdf
I hit the BMW Assist button in my E90 and they helped me get the app working properly (since we have multiple vehicles and my parent's car was also linked to my account somehow).
Old 01-13-2013, 03:40 PM
the_fox's Avatar
the_fox the_fox is offline
Custom User
Mein Auto: X1
I can confirm Google search works with this AP, and it's great for sending destinations to the Nav.
Do not fold, staple, or mutilate. Void where prohibited.
Old 01-15-2013, 05:43 AM
Thanks for all the responses! How do I get the "Google Local Search " to work? Are there instructions somewhere?
Vince.
Old 01-15-2013, 07:39 AM
Vince.
Its pretty straight forward.
Click on the Control icon, then click on "Google Local Search".
That takes you to Google Maps. On the top search line put in your address or point of interest. If your address is found, google maps will put red push pins on the map. Touch one of the push pins to reveal the address. If that address is the one you want, press the blue arrow pointing to the right. It will show the details of the search. Now press "Send to Vehicle" to have the address sent to your car.
You will find the address in your cars messages menu. From there you can initiate a GPS navigation session.
Of course this all assumes that you have configured the application to talk to the account associated with your car.
Old 01-15-2013, 07:48 AM
Thumbs up
Thanks! I actually found the user manual for this app, on the BMW website. It's attached.
Vince.
Old 01-16-2013, 08:44 AM
Each time I try to do the location function. I get this error (attached)
Eventually if I push enough buttons the location comes back or I get a status but why the message and how do you update the cars status sat the message requests?
Old 05-10-2013, 02:57 PM
chefkahn chefkahn is offline
Mein Auto: X1, 128
I called BMW Assist today because I couldn't get the app working either. At first they said it was me, but then I walked them through the process of trying to log in. It comes up with the error of "no vehicle found, try again later". Then the dug into it and saw a old Assist account I had a couple years ago and cleared it out... No dice, didn't fix it. Then they saw that it took 3 different calls to get Assist activated over a weeks time, so now I'm waiting for them to call me when it's resolved... I like tech stuff and I just want to play with the app...
