Variable intake system Problems and misfiring - Bimmerfest - BMW Forums
Old 01-12-2013, 01:17 AM
KINAMULLAH KINAMULLAH is offline
BIGGIE
Mein Auto: bmw 745
Question Variable intake system Problems and misfiring
Hi all,
Problems with my e65 745i after putting it on the Launch pad the problems that keep coming back are bad 02 sensor heater on bank before cat, code 2715
rough idling on all cylinders, this does clear up after a reset but then comes back after around an hour, several misfires detected.
Variable intake system, plausibility and temperature warming threshold, code 2820 and 2821
Thermostat stuck code 279b
I need help guys......
Old 01-13-2013, 03:08 PM
BIGGIE
Mein Auto: bmw 745
i really need help guys..........
Old 01-13-2013, 03:16 PM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
what ever controls timing for intake.... VANOS no? they go bad.... thats what i can think of... i mean if something literally broke in ther, your car would not run right, or at all... as far as misfires go...
thermostat does go out, thank the gods for it being stuck open and not closed... need to replace TS..
replace TS first.... maybe it is stuck half open or closed... other errors are temp related my first thing.....
have you checked running temp with OBD scanner...?
Old 01-13-2013, 03:35 PM
BIGGIE
Mein Auto: bmw 745
Nope havent checked the running temperature.....
car is running absolutely fine.... accelerates perfect and no other issues.....
I dont know what to do. Have ordered a new Thermostat unit so waiting for it....
Old 09-03-2014, 08:29 AM
itscoo2pyopants itscoo2pyopants is offline
Mein Auto: 04 325ci, 05 4.8is, 09 M3
Any update?
Old 09-05-2014, 08:04 AM
spyders 745li's Avatar
spyders 745li spyders 745li is offline
Mein Auto: bmw745li
From what I remember when I had that problem. I started cheep. Try replacing o2 sensors and thermostat. Then re check codes. As far as misfires check the seating on spark plug modules. Recheck codes. If codes for misfire reappear try swapping spark modules to check if codes follow the module. Question when was last spark plug change?
Old 05-02-2016, 01:41 PM
nilsnilsen's Avatar
nilsnilsen nilsnilsen is offline
Mein Auto: BMW 735i
Did you ever solve it? I have the same codes now
Old 05-03-2016, 03:33 PM
nilsnilsen's Avatar
Mein Auto: BMW 735i
