unlocked OBC, but cant test while running?
So I unlocked it, and checked my coolant temp with the car off, but how do you check the temp and other data with the car running???
The same way.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
Thanks, all the instructions I read said the key had to be in position 1.
Nope, works just fine in 2 as well. Exception is you can't do the cluster bulb test while driving for obvious reasons.
The readout resets every time you turn off the ignition. So, to read parameters whilst driving, first start the engine, and then activate the readout and call up the parameters of interest. They'll stay up there all the time the engine is running.
Warning messages will not be displayed, however.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
There is a trick you can use to cross check the 2 thermistors in the dual temp sensor in the engine.
Start the engine, unlock the cluster and step through the menu to engine temperature. Turn the engine off by turning the key from the "2" position to "1" position but not the "0" position as to remove the key. The unlocked cluster test stays active in the display, but the reading at position 1 will likely be different from 2 by a degree or two. You can toggle between 1 & 2 to see them swap. Works hot engine or cold. It there is a significant difference between the readings, it's time to change the DTS. Apparently the display is switched between the thermistor that drives the gauge & the temp signal from the DME which reads the other thermistor in the DTS. I've no idea which is which. Nor whether the gauge needle and overtemp warning light share a common input or one is drive by the DME and the other from the thermistor.
Regards RDL |
