Old 01-11-2013, 05:54 PM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
D1S Headlight
Does anyone know the temp of the bulbs that come with the car..
2007 750Li with dynamic D1S headlights
I want to get Fogs and Brights to match.... also high beams bulb type? I looked on e92 lighting and real oem.... not much to go on..... dont want to pull apart just to check... want to order everything and then do install at one time
if anyone knows can you confirm bulb types for fogs? i got hb4/9006, but want to make sure.
also mtec halogens for angel eyes.... has anyone got those or did everyone go with the LEDs? want brightest white maybe with a blue-ish tint, know what temp I shoud go with?
Old 01-11-2013, 06:21 PM
Nygel's Avatar
Nygel Nygel is online now
Mein Auto: BMW 750Li
fogs are 9006 do not change high beam to HID's
DFEL750I's Avatar
DFEL750I DFEL750I is online now
Mein Auto: 750I
Stock temperature is 4300K. You won't find fogs to match. You will need to upgrade headlights to 6000K and get fogs to match that
Old 01-11-2013, 06:29 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
Originally Posted by nygel View Post
fogs are 9006 do not change high beam to hid's
+1
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-11-2013, 06:30 PM
Exactly
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-12-2013, 10:34 AM
I am aware of this and its not what I wanted...... HIDs are not meant to be turned on and off like halogen I know..... thanks for heads up tho..... i only asked for temp because I want color to match..... in halogen bulb tho....
By the way my D1S head lights are the xenon HID... the temp is up at the 6k range already... no way they are 4300k.. the brights and fogs are haolgens yes and in the warm temp of 4300k....
Old 01-12-2013, 11:58 AM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
The stocks if not 4300k are 5k (white). Those are the only two options. Mine came new with white 5k headlight bulbs pre-installed. DDMTuning will have 5k and 6k. Get new bulbs all around. I made the mistake of just getting 5k fog lights and they are whiter/brighter than my headlights since those bulbs are old and not a bright.
HID Guide
LED Guide
Old 01-12-2013, 12:07 PM
my HIDs (that came with the car) have a blue tint to them but are still very white.. i must say according to the chart they would be the 6k.... the lens for the dynamics is clear so i dont think that is giving it the blueness.... if the bulbs are 43 or 5k where does the blue come from , there is definitely no yellow or warm tone to the white so the cant be as low as 43k can they?
Old 01-12-2013, 12:17 PM
6K is usually pure white with just a blueish outer ring. Anything "yellowish/warm" would be 43k. Pure white is 5K. So yours could be 6k stock. But if they are the original bulbs, thats 6 years. HID changes color over time as it gets old. But either way, best to just start fresh. 5k or 6k, it really doesn't matter.
HID Guide
LED Guide
Old 01-12-2013, 12:51 PM
hmm good point... if i can get the bulbs cheap then maybe... wasnt planning on chagnign the HIDs.... unless one went out..... i have seen them for 120 a bulb and then ddm tuning at 30 a bulb..... but i dunno.. the reason i didnt want to upgrade the angel eyes to led is partyl hassle of going bad, but mostly price lol... i am cheap... I know it...
Old 01-12-2013, 01:24 PM
DDMTuning.com has them at $30 for the (pair) not each. Thats pretty cheap. But I understand your point. I left mine as is. They dont match exactly but its close enough.
HID Guide
LED Guide
Old 01-12-2013, 01:53 PM
GEE WILLIKERS BATMAN... you're right.... might have to get those after all
what is that stock color that comes on the new 3 series angel eyes. If I get 5k hids i dont want the angel eyes to blend in all the way...
maybe 5k lows, 6k angels, 5k brights and 5k fogs
or 6k lows, 5k angels. 6k brights and 6k fogs.
which way would all of you go?
Old 01-12-2013, 02:31 PM
I think both of those are going to look about the same. Pound for pound it really hard to tell the difference between 5k and 6k. I would run all 5's, but all 6's would be ok too.
HID Guide
LED Guide
