Old 12-24-2012, 10:14 AM
raffles999 raffles999 is offline
Mein Auto: 2007 750I
Key fob
recently I had dsicussed an issue with a message that flashed on my panel stating
Remote battery discharge. I learned that my comfort access BMW came with fobs that carried the CR2032 batts. I replaced these batts but found that this message is recurring. Is this normal, can I cancel it or is it referring to something else?
Raffles999
Old 12-26-2012, 12:58 AM
rippjd rippjd is online now
Mein Auto: '05 745i / '00 740i
I had the same issue with one of my keys.. Despite changing the CR2302 batter I still would get the warning in the instrument cluster. I just assumed I reached the end of the life for the internal rechargeable battery.
I then had the recall performed for the soft close + comfort access and after the Dealer had the car for 2 weeks due to programming difficulty, the error has not returned. Perhaps my short trips were never enough to charge it?
-edit-
I stand corrected. There is no rechargeable battery in the CA key fob. According to the BMW training literature:
"Since the key does not need to be inserted into the holder to start the vehicle the battery
of the remote control/ID Transmitter is no longer chargeable, therefore requiring the battery
to be replaced. Under "average" usage the the battery may need to be replaced
once a year."
2005 745i Individual
Old 12-26-2012, 03:50 AM
Tenn's Avatar
Tenn Tenn is offline
Mein Auto: 2007 BMW 750Li
I had similar issues and started keeping my fob "plugged in" and that has ended the message of low battery for the key.
Old 12-26-2012, 06:50 AM
Pardon my ignorance but I don't understand how a non rechargeable cr2032 batt. can be affected by how far you travel. Typically I don't plug my key fob into the car. Is this wrong? Does everyone drive with said fob inserted. I am mystified by what should be so simple. If my fob has an unchargeable batt why is the remote batt. discharge being activated??? Thanks for your comments.
Raffles999
Old 12-26-2012, 08:24 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
If you have Comfort Access, you have a non-rechargeable, replaceable battery in the fob. No amount of driving with it in the slot will charge it. If you have a non-CA car, the rechargeable battery must be in the slot to recharge the battery (you can't start the car without the fob in the slot). The rehcargeable battery is not supposed to be replaced when it reaches it's useful life span but there are DIY's on how to do it.
Old 12-26-2012, 08:42 AM
1bad540's Avatar
1bad540 1bad540 is online now
sometimes I install it and sometimes I dont, I have changed the batterys a few times with radio shack ones.
[SIGPIC]
99 540i sport, acs type 2's chrome, acs spler pdls,Euroclrs
04 745i aw sport,21's aib's acspedals& rf splr(sold)
00 328i Prem Aw18" 335spt whls(sold)
02 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav
05 X5 3.0, pana rf,nav,xenon,cldweather, premium.ipod hookup, 20"4.6rims staggered 315rrs.
06 750I aw, sport. chrome21's,acs pdls,acs rfsplr,mtecs,8k hid fogs,Leds.oem ipod&sirius
03 VIPER, forgelinewheels,tune,exhaust,intake.
Old 12-26-2012, 09:42 AM
Okay this confirms what I thought. I sometimes insert the fob because rightly or wrongly I think maybe any changes to settings might overwrite over old stored data...does that make sense?
Raffles999
Old 01-12-2013, 11:57 AM
I checked my car and the yellow warning "remote batt discharge" is still showing even though I replaced the batts in both fobs. Any ideas on how to reset this warning?
Raffles999
Old 01-12-2013, 12:42 PM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
... dont know for sure... but w/o obd2 scanner.... worth a shot... its free lol
Old 01-12-2013, 02:56 PM
mrbmwx5 mrbmwx5 is offline
Mein Auto: 06 750Li
Got to love the black tape on that cluster Hiding the check engine light...
2001 X5 3.0i 200k miles & counting...( SOLD)
Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights
06 750Li with 19k miles.
Bone stock.
Old 01-12-2013, 03:19 PM
I use duct tape... i think the silver goes with the chrome better....
Old 01-12-2013, 03:39 PM
Thanks for the feedback....
Raffles999
