Old 01-12-2013, 03:26 PM
LSG LSG is offline
Mein Auto: bmw 745i
Transmission leak!!!! Help
Ive been searching through through out the forum and with no luck...I have a 2005 745i I have a transmission leak. It's not leaking from the pan I check it. It seems to be leaking from where the wire connectors are right in front of the trans pan. My question is... How do I know if it's the mechatronics sealing sleeve leaking or the torque converter seal leaking... Please any experience techs on here please respond...
Thank you in advance for your assistance!!
Old 01-15-2013, 03:51 PM
LSG LSG is offline
Mein Auto: bmw 745i
No one has any advice????
Old 01-15-2013, 03:54 PM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
AFAIK leak from wires = mechatronics sleve
Old 01-15-2013, 05:22 PM
collins912's Avatar
collins912 collins912 is offline
Mein Auto: 745i
Originally Posted by piers1989 View Post
afaik leak from wires = mechatronics sleve
+1.
'11 Acadia Denali
'07 Tahoe(SOLD)
'02 745i
'00 Avalon
'06 GSXR1000(SOLD)
Old 01-15-2013, 05:32 PM
flash_n flash_n is offline
Mein Auto: 745Li
Had it replaced at the Indy yesterday for about 250.
AT Plug adapter sealing sleeve - 24 34 7 588 725
Pan Gasket - 24 11 7 571 204
5Qts Transmission fluid
Hope this helps!
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer
next up:
headlight vertical aim, VCGs, P0492
Old 01-15-2013, 08:18 PM
LSG LSG is offline
Mein Auto: bmw 745i
Thank you, that was very helpful...I will probably tackle this job myself...tomorrow... Wish me luck!
Old 01-16-2013, 03:33 AM
Mein Auto: 745Li
Good luck.
Please take some pictures and consider opening a DIY thread, if you want.
next up:
