Bike Racks Again! - Bimmerfest - BMW Forums
Old 11-04-2012, 12:38 PM
robbiecarman robbiecarman is offline
Mein Auto: Mini Cooper S Clubman
Bike Racks Again!
So after figuring out that I can't actually get the EU BMW bike rack that screws into the bumper and that I don't want to transport bikes on the roof I'm trying to figure out my best options. Sure I could get a hitch installed but my X1 is leased and I'm pretty sure such modifications would be in violation of my lease agreement.
So I've been looking at various rear mounted bike rack options and I'm curious how other X1 owners have been transporting bikes around? Here are the ones that I've been looking at all claim to work with the X1 but so far using the ole' google I can't seem to find any pics with anyone actually using a rear mounted bike rack on an X1
http://www.thule.com/en-US/US/Produc...latform-2-Bike
http://www.saris.com/en/bike-racks/v...&category_id=7
These all seem to be stable and generally have good reviews but I'm concerned obviously potentially damaging the finish of the X1 or worse yet denting or pushing in various contact points because of weight of the rack + bikes.
Any thoughts very welcomed!
Robbie
Old 11-04-2012, 07:12 PM
conceyted conceyted is offline
Mein Auto: 2013 X1
In my opinion, the roof rack is the only elegant option available for the x1 at this time. Any other options will require vehicle modification or have the potential to cause marking on the vehicle. Even if you say you will be careful, eventually something will happen on one of those styles of bike racks.
Old 11-04-2012, 07:18 PM
I would agree with from an aesthetic level however I've been burned many times over the years with roof mounted options -
1. I have had hydraulic brake lines from disc brakes leak on the roof - ruining paint.
2. My wife isn't all that tall and has had issues getting the bikes on/off the roof
3. I have had all manner of aero bars, fork mount, etc and the all suck for aerodynamics and gas milage.
I guess I'm just feeling burned as I didn't look hard enough when buying - dealer told me the bumper mount was the same as the EU models and clearly its not
Old 11-04-2012, 09:24 PM
X1-tahoe X1-tahoe is offline
Mein Auto: X1
Also interested in the beat solution for this.
Old 11-05-2012, 01:49 PM
pjkad pjkad is offline
Mein Auto: Hyundai Genesis
hitch
Are you sure adding a hitch to a leased vehicle is a problem for BMW finance? It is able to be removed before you turn the car in, admittedly with the expense of doing so. And even if not removed, it has enhanced the value of the car.
Old 11-05-2012, 07:29 PM
AzNMpower32's Avatar
Tar Heel Faithful
I think you're allowed to install the OEM hitch as long as you remove it before returning the vehicle back. Check the fine print of your lease agreement.
And yes, you should have more carefully considered transport options (or the lack thereof) on the X1 before you bought it.
Old 11-05-2012, 07:45 PM
BMWNA says no - 3 hours on hold today - hitch installation involves modification of the rear bumper assembly.
I agree should have been a little more detail oriented - however ripping off plastic paneling on a bumper in the middle of a show room to inspect screw ports wasn't on the tip of my brain
Old 11-20-2012, 01:27 PM
HBWT HBWT is offline
Mein Auto: 2010 Audi Q5 3.2
Hitch...???
What Hitch? Didn't know one was available for the X1. Please advise.
Old 11-21-2012, 07:04 PM
kosmo kosmo is offline
Mein Auto: 128
Then I would meet with the dealership principal and let him know that your ability to mount a bumper or hitch rack of some kind without getting any nonsense at the time of lease return is the LEAST they can do.
Salesmen have to be accountable for things they say to close a deal!
Old 11-22-2012, 06:20 AM
x3brian x3brian is offline
Mein Auto: X3
Your best option to retain the lease...replace the rear bumper shock absorber bar with the euro spec version with two tow hook holes and use the euro bumper bike hitch you want. Plus your bumper cover already has both cutouts. Here is the part number:
http://www.realoem.com/bmw/showparts...67&hg=51&fg=17
It's an easy swap, you'll just have to find someone (maybe ecs) that can source euro parts.
BMW will never know the difference when you return the car.
Also, I did point this out as a potential issue before your purchase ....it's bummer you were not able to pop the two plugs to verify.
http://www.bimmerfest.com/forums/sho...d.php?t=643191
Old 11-24-2012, 05:06 AM
PatT PatT is offline
Mein Auto: 2011 x3 + 2010 335i xdriv
Hitch
Check out execuhitch.com I have ordered a x1 (currently on the Turandot making its way here!) and plan to have the hitch installed to carry bikes as well as tow a very small, light camper. I bought the car so I'm not worried about lease issues, but I believe that the bumper is not modified.
Old 11-24-2012, 05:25 AM
Mein Auto: 2013 X1
Original Post
I can post the installation instructions up if you'd like. You have to dremel out approximately 40% of the under fascia [See Edit Below for Clarification]. It also replaces the aluminum crush bumper with a steel post. If you are ever hit from the back with it you'll probably end up with frame damage.
Edit
I received a call from ExecuHitch today. The caller, an employee at ExecuHitch, stated he was calling to clear up any misconceptions any of us might have had about the ExecuHitch for the X1. He went on to explain that someone posted misinformation on a message board and that they are in the process of having mods remove the misinformation. He explained that the under fascia trimming is actually minimal and that their instructions might be misleading. He promised that there would be a revision of these instructions to try to clear up any issues. The under fascia apparently has most of the trimmed area already missing from the factory. He also touched on the aluminum crush bumper vs the steel post replacing it. He stressed that ExecuHitch was designed very carefully and used the stock mounting points of the original bumper. He explained that these same points are what the factory uses to hold the chassis up during assembly and that there should be no issue during a crash.
In my defense, I do not have my car yet (I pick it up in Munich via Euro Delivery on the 28th!) so I had no way of knowing how much trimming to expect other than what I saw in ExecuHitch's instructions. I have to admit that I am still worried about replacing an aluminum crash bumper (meant to crush and absorb impact) with a steel post, but I wanted to give ExecuHitch a fair chance and not sound as though I am just bashing them, so I made this edit. I hope this clears up any misconceptions that might be caused through my initial post.
Last edited by conceyted; 11-26-2012 at 12:40 PM. Reason: Clearing up any misconceptions.
Old 11-24-2012, 08:26 AM
Mein Auto: 2013 X1
Here are the instructions and cut out template.
File Type: pdf BMW X1 [E84] Hitch Receiver Installation (2012-Current) (1).pdf (465.9 KB, 489 views)
Old 11-26-2012, 12:46 PM
Mein Auto: 2013 X1
I posted an edit to my original reply about ExecuHitch. Please read the edit above.
Old 12-07-2012, 12:26 PM
Mein Auto: 2013 X1
I spoke with a rep from Curt Mfg a couple of days ago. They claim to be in the final stages of development on their hitch for the X1.
Old 12-10-2012, 10:48 AM
NateXTR's Avatar
NateXTR NateXTR is offline
Send a message via AIM to NateXTR
Mein Auto: '13 X1 3.5 M-Sport
I've been using the Saris Gran Fondo for about six months on my wife's Cadillac SRX and have been pretty happy. The extra weight of the rack can cause the automatic lift-gate to get confused. If I guide it, it lifts no problem, but if I use the remote it works about 60% of the time. I am getting the X1 and because I work in a bike shop, carrying bikes is a daily occurrence for me. I will probably look into a hitch in the spring... But it is nice to know that the Gran-Fondo works too.
Belgian Beer, Swiss Watches, French Bikes and German Cars. Life is good.
2/26/13 USA Delivery X1 3.5X-drive, Valencia Orange, M-Sport, all boxes checked.
5/26/09 ED 328XI, LeMans Blue, ZMP, 6FL, Bluetooth. Baden-Baden, Beaune, Lyon, Avignon, Nice. Re-delivered 7/24/09(retired)
2/8/07 ED X3 Alpine White, Step, PP, SP, Xenon. Re-delivered 3/17/07(retired)
7/7/06 ED 325XIT, JapanRot, Step, PP, Xenon. Luzern, Gap, Alp d' Huez, Varenna, Munich. Re-delivered 8/28/06.(retired)
Old 12-12-2012, 08:43 PM
Mein Auto: 2013 X1
I did a google search tonight for "Curt Mfg BMW X1" and guess what came up?
https://www.curtmfg.com/masterlibrar..._13140_INS.PDF
Old 12-18-2012, 09:58 AM
Originally Posted by conceyted View Post
...no way of knowing how much trimming to expect other than what I saw in ExecuHitch's instructions. I have to admit that I am still worried about replacing an aluminum crash bumper (meant to crush and absorb impact) with a steel post, but I wanted to give ExecuHitch a fair chance and not sound as though I am just bashing them, so I made this edit. I hope this clears up any misconceptions that might be caused through my initial post.
I installed my Execuhitch on my X1 this past Sunday. There was very little trimming necessary on my M-Sport. It was apparent that they were fitting a hitch to a "non-M Sport" when compiling the instructions; which may require much more trimming. The small piece I cut away was about 5/8" deep and less than 4" wide. Very easy to do.
The OEM bumper is not aluminum...it's steel. The main difference I noticed is that the OEM bumper extended about 6" farther to the left and right and, of course, the added weight of the hitch hardware makes the execuhitch much heavier. Unfortunately, not heavy enough to lower the back end and take up some of that wheel gap.
The unit is VERY well made and inspires confidence. I re-used my trim rivets as the ones provided are black and would have looked bad on my mineral white wheel arch trim. There are a few other tips that I'm willing to share if anyone is interested.
BTW, I also bought and installed the OEM BMW cross bars. They are really high-quality and the install is just too damn easy.
HaveBulldogWillTravel
English Bulldog Rescue
2013 X1 xDrive28i, Min. White, Sand, UP, LP, M-Sport, HK, Heated Seats, Satellite
Invisihitch
2006 Mazda Miata GT Winning Blue, FM Supercharged, Axial Flow SSK, FM Stage 2 Susp, Goodwin exhaust, Enkei PF01
2015 Rally Red Civic Si Coupe
Old 12-18-2012, 10:28 AM
Mein Auto: 2013 X1
Thank you! This type of feedback is exactly what we need. I have a few comments and then some questions.
Comments:
1) I do agree that the instructions for Execuhitch, along with the instructions for Curt, appear to have been written for non-M-Sport models. This is not a huge deal, though, but small things like rivet colors (non-M-Sport models have black fender trim, while M-Sport models are color matched) might be off because of this.
2) The small amount of trimming is a relief, and should be no different between M-Sport and non-M-Sport models.
3) The OEM crush bumper from BMW is definitely not made of steel. The Execuhitch replacement is made of steel.
Questions:
1) In your opinion, how does Execuhitch feel in terms of stability and strength? Do you agree with it's Class 3 rating? I am specifically concerned about putting 100-200 lbs of load on the tongue on the hitch as a non-trailer weight load. Curt requires stabilizing straps for these types of loads, and I wonder what sort of affect it would have on Execuhitch.
2) Does the change in size between OEM bumper support and replacement cause any issues with the exterior body pieces fitting onto the car (such as bulging at places or possibilities for unevenness from wear over time)?
3) In regards to your BMW crossbars, you say the install was very simple. I looked at the install instructions on the Thule versions and noticed that the mounting feet for the cross bars require torquing of two bolts per mounting foot via allen key for a total of 8 bolts. Is the BMW crossbar the same?
Lastly, please share any tips you have for these installs! I am sure they will come in handy for someone eventually. Also, please post some detailed pictures of your car with everything installed. I would love to see it.
Old 12-19-2012, 09:11 AM
It appears to be steel because a magnet jumps on it...so there's something ferrous in the "alloy". And it's not so light either.
Questions:
All I can say is that without question, it will hold my 4 bike Thule carrier and it will pull my 4-Kayak trailer. Class ABC or Z...as long as it does what I want it to IDGAS about anything else. This, and I really have no way to test whether it's 1 class or another. I can't imagine they would put into print that it's something that it isn't...liability considerations and all.
You can't tell that there's a hitch behind the cover and since the missing protrusions were not supporting anything I doubt there would ever be any problem. There are two screws that aren't re-used and they held the lower center of the bumper cover to the original bumper. Even though they aren't used the cover is ridgid enough to keep it's shape without. Again, I can't imagime a long or short term ploblem here. This hitch is well made and by no means cheap...and have NO regrets in buying it.
Install requires turning of a spring loaded flip down handle. Once the bar is in place simply lift the cover and pull down the locking handle. Turn the locking handle until the locking hex bolt no longer turns(at this point the locking handle will turn but the spring tensioned hex bolt will not). This means it's time to push the lock handle back into place...flip it up). Pull down the trim cover and lock with supplied key. The key turns HARD. I'm hoping after a few cycles it will loosen up a bit.
Tips and pics later when I get a chance
Invisihitch
Old 12-20-2012, 02:32 PM
And just in case I forgot to mention it before, the OEM bumper is STEEL. Or at least that's what my magnet says. If it's some sort of allow then it's laden with FE. Definitely NOT aluminum.
Invisihitch
Old 01-12-2013, 08:08 AM
invisihitch invisihitch is offline
Mein Auto: 2012 X3
attaching a bike rack
Hi folks. I don't generally post here and certainly do not want to spam the board, but was directed to this thread by a customer. Hopefully, I can add some value to the discussion about attaching a bike rack to the X1. Full disclosure: my company recently purchased the North American rights to the Execuhitch product line, and we are rebranding the product as the invisihitch.
In other parts of the world, our invisihitch is the BMW X1 factory hitch, so we know a bit about the design of a hitch for this vehicle, as well about the various options for attaching a bike rack.
To add clarity to a few points raised in this thread:
Why no factory hitch or bike rack for the X1?
Unfortunately, BMW North America made a strategic decision to bring the X1 to market here in the U.S. and Canada without a factory hitch option. This is unlikely to change anytime soon. So in North America we provide the invisihitch as an "aftermarket" hitch for the X1. Again, it is the exact same hitch that we provide to BMW for use as their X1 factory hitch in other parts of the world.
It is also unfortunate that the X1 in North America has only one tow eye on the factory metal bumper core. So attaching the BMW bike rack via the tow eyes is not a viable option on the X1. If you want to put a bike rack on the back of the X1, you will need to install a hitch. (This assumes that no one really wants to strap a clamp-on rack to this vehicle).
The X1 bumper and hitches:
The metal bumper core on the X1 is a fairly stout piece of steel. It's primary purpose is to transfer impact forces to the crumple zones of the vehicle in the event of a rear-end collision, the idea being to sacrifice the vehicle's body panels to absorb crash forces before those forces can reach any precious human cargo. For this reason, the only BMW-approved method of attaching a hitch to the vehicle is to replace the factory steel bumper core with a steel hitch beam that attaches to the vehicle in precisely the same way and at precisely the same points as the original bumper core. Any other method of attaching a hitch, such as bolting to the sides of the frame rails or using an A-frame support point, compromises passenger safety and is not approved by BMW.
Providing access to a hitch receiver on the X1:
There seems to be some confusion regarding any required modifications to the X1 to install a hitch. All hitches require access to the opening on the receiver in order to allow for insertion of a ball mount or a bike rack. Typically, either the bumper has to be cut or the plastic gravel guard underneath the vehicle has to be cut. In the latter case, the receiver is typically designed to drop down through an opening in the gravel guard and then stick out horizontally under the bumper The invisihitch receiver takes this approach, and then adds even more stealthiness by making the part that sticks out removable. So, when not in use, there is no visible evidence that the vehicle even has a hitch installed. And in the event of a rear-end collision, there is nothing protruding to interfere with the bumper's intended purpose of transferring the crash forces to the crumple zones.
To accomplish this, there must be an access opening in the gravel guard underneath the vehicle. Fortunately, BMW designed the X1 with a factory access opening in the gravel guard. To ease the process of inserting and removing our removable bike-rack connector, we recommend increasing the size of the factory gravel-guard opening slightly... by approximately 1 inch by 4 inches. Personally, I would be very surprised if anyone noticed a very slight increase in the size of the existing gravel-guard opening located entirely underneath the vehicle. But we are looking at ways to eliminate the need to perform any trimming of the gravel guard whatsoever, no matter how small.
I am attaching some photos of the X1 with the invisihitch receiver installed so you can see for yourself what this option for attaching a bike rack looks like. As far as I know, there is currently no better way to connect a bike rack to the back of the X1 in North America. I will, however, admit to being biased.
Cheers,
Daryl
daryl@invisihitch.com
678.400.0121 office
404.593.9887 mobile
Name:	BMW X1 [E84] with Invisihitch Receiver installed.jpg
ID:	357249   Click image for larger version
Name:	BMW X1 [E84] with 1 1-4 inch bike-rack connector attached.jpg
ID:	357250   Click image for larger version
Name:	BMW X1 [E84] with 2 inch bike-rack connector attached.jpg
ID:	357251   Click image for larger version
Name:	BMW X1 [E84] factory gravel-guard opening.png
Old 01-12-2013, 10:05 AM
nospam nospam is offline
Mein Auto: X1 x28i; 128i; S2000
Great info...thanks for contributing!
Old 01-12-2013, 03:43 PM
Mein Auto: 2013 X1
So is execuhitch/invisihitch claiming that they actually make the BMW X1 factory hitches for BMW?
Old 01-12-2013, 04:57 PM
It appears so...
"In other parts of the world, our invisihitch is the BMW X1 factory hitch, so we know a bit about the design of a hitch for this vehicle..."
Invisihitch
