Tires for BMW X5 - Bimmerfest - BMW Forums
Old 01-12-2013, 09:09 AM
wkt20 wkt20 is offline
Mein Auto: X5
Tires for BMW X5
Hi,
I'm at Les Schwab now and they are recommending Toyo 255/50R19 103V Proxes All Seasons tires. Has anyone used these tires before? How are they and are these good tires?
Thanks.
Sent from my SAMSUNG-SGH-I777 using Bimmer App
Old 01-12-2013, 09:39 AM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
No. These are the wrong tires. The load rating is wrong for one thing at 103.
Go home and do research before buying tires.
Old 01-12-2013, 09:53 AM
Mein Auto: X5
I noticed that too and asked about the 107 load rating but Les Schwab would guarantee their tire. But I've now walked away as I don't feel comfortable with the lower load rating. I'll stick to Costco but don't like their waiting times.
Old 01-12-2013, 09:55 AM
Is there an urgent need to buy tires? You seem to be in a rush. I researched tires for a few weeks before I bought.
Old 01-12-2013, 10:08 AM
Mein Auto: X5
Not really. I've already walked away from les Schwab now and can afford to look around. Costco and discount tires are my next choices. I plan to stick with Bridgestones.
Old 01-12-2013, 11:10 AM
Tire Rack is a great website for research. I bought my chosen tires locally however.
Old 01-12-2013, 12:42 PM
DCC DCC is offline
BMW Fan
Mein Auto: '02 Z3 M Coupe
The slightly lower load rating is ok if you are not using the vehicle at its max rating per the manufacturer...very few people do.
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 01-12-2013, 01:28 PM
I don't consider that load rating as "slightly lower".
Its significantly lower.
Old 01-12-2013, 01:30 PM
ard ard is offline
Resident Curmudgeon
I do my research, shop prices on line...call my tire store,see if they can match or come close. They order them if necessary, call ,e when the arrive,best up an appointment to pop them on.
Screw driving around ....
Old 01-12-2013, 02:56 PM
DCC DCC is offline
BMW Fan
103 is rated at 1.929lbs
107 is rated at 2,149lbs
That equates to about the weight of a regular adult male...
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 01-12-2013, 04:15 PM
ndabunka's Avatar
ndabunka ndabunka is offline
'12 X5 35d Black-on-Black
Mein Auto: X5d Ski Machine-Blk Betty
Yep, not much of a difference AT ALL but a lower rating also typically equates to a softer sidewall as well so I'd skip it simply due to that fact alone
'12 X5d Sapphire/Black/Bamboo, Sport (ZAP), Premium (ZPP) & Premium Sound(ZPS) packages: 20" 214's, OEM Hitch
Old 01-12-2013, 04:18 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Times 4, no?
Old 01-12-2013, 06:51 PM
DCC DCC is offline
BMW Fan
Originally Posted by Penguin View Post
Times 4, no?
Correct
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 01-12-2013, 07:58 PM
I don't know what the manual says but my BMW came with 109 load rated tires
Old 01-12-2013, 08:00 PM
DCC DCC is offline
BMW Fan
I wonder if the run flats have a higher load rating by default due to a harder sidewall
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 01-14-2013, 01:13 PM
soldmystang's Avatar
soldmystang soldmystang is offline
Mein Auto: e70, e36, e90, e46iT, 6.0
I'm on my second set of Toyo STIIs. Love them, got over 40K miles out of the last set.
Get the XL version only however. 107V
