Old 09-30-2007, 01:06 PM
footballer footballer is offline
Mein Auto: 07' 335
Sliding/tilt sunroof fault
Has anyone seen this on a e9x? What's bizarre is that I was programming the homelink/garage opener when this came on and I had not touched the sunroof in a week or so.
The full error message is:
"Anti-trap function deactivated. Have the system checked by the nearest BMW center."
The sunroof won't open but it will do the tilt/vent.
Old 09-30-2007, 01:48 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
try to reinitialize it by opening it fully (hold the switch in the back position if its not doing the one touch) then holding the switch in the forward position to close. hold the switch forward untill the sunroof pops down slightly, then back up.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 09-30-2007, 01:53 PM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
DO NOT USE YOUR SUNROOF!
If it's closed, keep it closed and DO NOT touch it. I can't stress that enough. This is another pretty common thing. Just take it in to your dealer and have the fault fixed. It could just be a very simple software thing, and F-ing with it could complicate the problem.
Old 01-30-2008, 05:21 PM
BMW Power's Avatar
BMW Power BMW Power is offline
Mein Auto: 2012 X5 35d
I just got this message as well. I guess it's the first "issue" with the new car. A little over 2 months old.
2014 i3 Rex
Retired 2012 X5 35d DSB - Prem, SAV, Cold, Sound, Tech packages, Apps Delivered 6/6/12
Retired 2011 335d AW, M Sport, Premium and Convenience pkg, Heated Seats, Nav, HK, iPod/USB, smart phone. ED 8/31/10
Retired 2008 335i Coupe 6-speed Manual, Montego Blue, Sport, Premium, CW, Nav, PDC, AS, Shade, HD, Sat, Ipod/USB, Logic 7, CA
PCD 11/07
Retired 2004 545i Sapphire Black/Black 6-speed Manual, Sport.
Old 01-31-2008, 12:47 PM
BMW Power's Avatar
FYI
My SA told me to do the reinitialize procedure. Press the center of the sunroof button and hold it for up to a minute until it goes through all the motions and that fixed it. I had tried the procedure listed on this site but I don't think I help the button long enough. Also make sure the car is running.
2014 i3 Rex
PCD 11/07
Old 04-22-2008, 07:00 PM
Tamudoc04 Tamudoc04 is offline
Mein Auto: '09 BMW 335i X-Drive
I just got the same error after getting the oil changed by my dealer. It was an after hours pickup and so I couldn't ask them about it. Fortunately the reinitializing procedure worked perfectly. Any ideas about the cause?
Thanks for the tip!
Greg
Old 06-29-2008, 02:00 AM
JeffInSeattle JeffInSeattle is offline
Mein Auto: 2011 Z4 sDrive35i
Originally Posted by BMW Power View Post
FYI
This "reinitialize" routine worked for me - while moving my hard wired radar detector from my '06 330i to my '08 335i, I considered wiring it into the power in the sunroof area and ran into this fault when checking for voltages on the wires.
The re-init sequence cleared the fault, thanks a ton for the web guys!
  • 2014 435i ZMT - ZMM ZPP ZDH ZTP ZDA 5DL
  • 2011 Z4 sDrive35i ZMT - ZCW ZMP ZPS ZTP PDC
    Past models:
  • 2008 335i ZMT - ZPP ZSP ZCW iDrive CA HD iPod
  • 2006 330i - 5/12/05 European Delivery - ZPP ZSP ZCW iDrive
Old 06-29-2008, 04:49 PM
Blue1 Blue1 is offline
Mein Auto: 2011 M3 Convertable
I got the same message on Thursday. I took it to my local dealer and they could not fix it on the spot. I will try the reset proceedure.
Old 06-29-2008, 04:56 PM
The reset procedure worked. All is workimg now.
Old 07-08-2008, 09:05 PM
gmusinov gmusinov is offline
Mein Auto: 2008 BMW 328i
Sunroof not working
If your sunroof is not working, just as the others said, push the center of the sunroof button and hold it for a minute. At that point, the sunroof will reset, and the problem should be fixed.
2008 BMW 328i, bronze metalic, tan leather, light poplar wood, premium package, manual transmission.
Old 08-10-2009, 08:37 PM
kwabena98 kwabena98 is offline
Mein Auto: 2007 BMW 335i Sedan
You guys are awesome
I can't thank you guys enough. This thread and forum as a whole has made owning a BMW much easier. The sunroof trick worked for me as well. I just read it 5 minutes ago, tried it for 1 minute and it cleared the code and the sunroof works fine now. Appreciate the help. Thank you!!
Old 08-13-2009, 02:14 PM
jagold jagold is offline
Mein Auto: 335xi
Thanks!
Just got the car and the error on the sunroof started two days later. My salesman had no idea and wanted to schedule a service date way into the future. Checked the site, held the button for a minute and all is well. Thanks everyone!
Old 08-13-2009, 02:15 PM
BMW_GAL BMW_GAL is offline
Mein Auto: 2009 335i Coupe
Very awesome, quick and easy fix
Sig by Solidjake
2009 335i Coupe, Titanium Silver Metallic, Coral Red Dakota Leather, Gray Poplar trim, Premium package and Sports package with 19s.
Previously Owned: 2006 Audi A4 S-Line Quattro with all the belles and whistles and a B5 Imola Yellow Audi S4
Old 08-13-2009, 02:19 PM
jo59's Avatar
jo59 jo59 is offline
The new jojojo
Mein Auto: --
very nice
Old 10-09-2009, 07:17 PM
AzNMpower32's Avatar
Tar Heel Faithful
Props for the instructions. Dealer replaced the instrument cluster but the anti-trapping fault developed. Followed procedure above and cleared fault.
Old 12-08-2010, 09:01 PM
bluescoupe bluescoupe is offline
motorhead
Mein Auto: 2011 335is
Worked for me!
Code came on earlier today, sunroof wouldn't work right or close properly.
A search got me to here and--- the problem is now resolved.
THANKS!
Old 08-05-2011, 07:37 AM
GG Hyundai GG Hyundai is offline
Mein Auto: '08 328xi
I did the hold for a minute thing...
It worked and the sunroof is working fine, but I still get the error notice. Please help?
Old 03-01-2012, 01:19 PM
haley197567 haley197567 is offline
GearHead67
Mein Auto: 2005 545i
I've tried the calibration process multiple times on my 2005 545i. All the sunroof will do is go through the venting motions and eventually stops just above flush with the roof line. The error code is still in iDrive and the sunroof will not retract or close the vent with one touch. Is there anything else to try before taking it to the dealership? I have one BMW dealership in my city and they charge a minimum of $115 to diagnose the vehicle. Any and all help would be much appreciated, thanks.
Old 04-05-2012, 03:21 PM
rambalu80 rambalu80 is offline
Mein Auto: 2016 BMW 340i
Thank you guys! I got the sunroof error this morning and I live an hour away from the closest dealership. I have an appointment scheduled next week for another reason but with all the rain we've been getting I was concerned. Google led me to this post and I pressed and held the middle button with the car running. In about 15 seconds the sunroof did its initialization test and soon after (total 30 seconds), the error disappeared on the OBD.
Old 04-27-2012, 05:32 PM
JimmyDaegu JimmyDaegu is offline
Mein Auto: BMW
BMW 328i sun roof reset
this morning woke up and saw sun roof was left opened!
shocked because clearly i left it close the night before.
start the engine and the sun roof error came on.
search bimmerfeast and found the answer.
press the center switch for 15 seconds and
the sun roof did its automatic reset.
now the error on the computer is gone.
things are back to normal.
BMW 328i rider.
Old 01-13-2013, 12:04 AM
ztoom ztoom is offline
Mein Auto: 2006 E90
I just had my battery replaced and this error appeared on the dash, I don't have iDrive. I landed on this excellent thread. I pushed the the button upwards and within 30 seconds it started to go through the motions. Needless to say all is well and fixed!
2006 325i
Old 03-08-2013, 02:03 PM
chowdarygm chowdarygm is offline
Mein Auto: BMW 318i E46, 735i E65
thank you so much...worked on E65 735i also....saved me a trip to dealer
Old 03-08-2013, 03:16 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
The whole sunroof cartridge was changed on my car. Once you get something "software" related, get worried.
Old 03-10-2013, 05:46 PM
e612007 e612007 is offline
Mein Auto: 530xiT (e61)
I have the same problem as OP. it won't go through o complete the initialization. It tilts up/down but that's it. Neither the liner nor the window will move back.
Any ideas?
Old 07-31-2013, 01:29 PM
moliveira moliveira is offline
Mein Auto: 2007 328XI
Thanks for the tip!
Greg
Same exact thing here - oil change resulted in sunroof problem on my 2007 328 xi. Reset procedure worked for me too! Thanks
