Old 01-13-2013, 02:19 AM
jimikins5226 jimikins5226 is offline
Mein Auto: 2012 BMW 328i
DS Mode and Sport Mode combined at the same time?
Hi guys, just a quick question:
So I understand that DS Mode that you activate by turning the gear lever left, and Sport Mode on the DDC settings are slightly different, but what happens if you turn both on at the same time? Does it harm the car in any way? other than destroying mpg of course.
thanks!
Old 01-13-2013, 11:16 AM
jdong jdong is offline
Mein Auto: 2013 ActiveHybrid 3
No it doesn't harm the car. This actually is the way to fully disable Auto Start Stop without using the button. In fact on my ActiveHybrid there is no ASS disable button and this is the only way to defeat it (though there's less of a reason to want to on the AH)
The shift program feels identical to me.
Old 01-15-2013, 06:40 PM
Enigma123 Enigma123 is offline
Mein Auto: 328xi 2013
I have a question. When you press the lever to left do you press the small button on left and can you press it while driving
Old 01-15-2013, 06:48 PM
408Racer's Avatar
408Racer 408Racer is offline
Life in da fast lane!
Mein Auto: F30 328i Sport 6MT
thanks!
Two girls, one car. LOL.
Old 01-16-2013, 06:38 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
No need to push the button on the left and yes, you can goes to DS mode while in motion.
Old 01-16-2013, 07:18 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
It is not. Sport mode will hold a gear to higher RPMs before upshifting under part throttle, downshifts earlier under braking, allows fairly aggressive engine braking and will generally be at least one gear lower than Drive at any given speed. DS also will not use top gear so leaving it there all day on a long highway run will hurt fuel economy a bit. The differences are most apparent when you start to push the car; in relaxed driving you may not notice anything unless you look at the tach.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 01-16-2013, 09:32 AM
MonkeyCMonkeyDo MonkeyCMonkeyDo is offline
Send a message via AIM to MonkeyCMonkeyDo
Mein Auto: 2013 335i
It is VERY different. If your car doesnt show S1-S8 in the dash and SPORT for mode then it isnt in the correct mode. There is a SUBSTANTIAL difference between the sport shift mode and regular.
Just a note if you are accelerating and take your foot of the gas as you click the lever over to S you may confuse the transmission. There has been a few time now where the car will downshift while accelerating and stick in a gear at redline for 3-4 seconds before it realizes what is going on and then corrects itself. I now try to make sure I am either switching to S when I am stopped, going slowly or continuously accelerating.
Old 01-16-2013, 03:07 PM
Elk Elk is offline
Mein Auto: ~
DS will shift into eighth at approximately 100 MPH.
DS is obviously not for cruising.
Old 01-16-2013, 05:32 PM
I was saying that the SPORT mode + D and SPORT mode + DS shift programs feel almost identical. Both keep engine revs high and hold onto the gear after spirited runs. Of course that's very different from COMFORT + D.
Are you guys seeing a different behavior out of D vs DS with the experience switch set to SPORT mode? (other than ASS defeat)
Old 01-16-2013, 05:41 PM
Zeichen311's Avatar
Well that certainly explains why I never saw it happen in the loaners.
Old 01-17-2013, 01:22 AM
loosenit2 loosenit2 is offline
Mein Auto: 2012 328i Luxury
I actually talked to my ca about this on delivery, in Germany. He told me that the ds mode on the gear selector just puts the transmission into sport mode, higher shifting rpms etc. Putting the drive experience button puts the whole car into sports mode, tightens suspension, steering, makes pedals more responsive, and puts the transmission into sport mode. So no benefit to putting car into sports mode and ds mode. He said the ds mode was mostly there in case you needed a little extra engine power for passing or going up a hill. Full sport mode when you wanted to driver more aggressively overall, like curvy mountain roads. My driving experiences have confirmed his statements, I can't tell any difference in transmission function between sport and sport plus ds.
Lance
Old 01-17-2013, 08:25 AM
That is not true. If it were when you change the car mode to sport the transmission would show s1-s8 instead of D. It does not change and the shift changes are VERY different in sports mode than in D.
Old 01-17-2013, 08:48 AM
I have to disagree. Transmission in ds and sport act the same in my car, only difference is in sport other things change as well like gas pedal gets more responsive, steering tightens up, and suspension tightens.
Lance
Old 04-15-2013, 04:20 PM
odessa91 odessa91 is offline
Mein Auto: 335i M Sport, 330i
Well, M Sport line with sport AT has only S1-S7 when you shift to the left. And I noticed, when I am in sport mode (D) at around 80mph and shift lever to the left, it down shifts and shows S7 and RPM slightly jumps. I drove loaner Luxury line with regular AT and yes DS mode has S8 and no difference when you shift to the left while in sport mode.
Old 04-15-2013, 09:15 PM
Interesting, hadn't considered that the sport at would behave differently than the regular at.
Lance
Old 04-15-2013, 09:24 PM
HokieXDriver HokieXDriver is offline
Mein Auto: 2013 BMW 335i M Sport RWD
The user manual states that if the sport transmission is in M/S mode and the car is in Sport+ mode, the transmission will not shift except through the paddles. No kickdown, no shift at redline. If that's true, it's the first automatic transmission I've seen with that behavior.
Old 04-16-2013, 02:51 AM
live4wknds live4wknds is offline
Mein Auto: 2012 328i Sedan
Very interesting. I'll have to check out any differences tomorrow morning. BTW, when I'm in manual shift M/S mode, my gears are indicated M1-M8. Due to my 'regular' A/T, maybe.
Old 04-16-2013, 09:06 AM
jacar jacar is offline
Mein Auto: 2013 AH3
I find this gives me the best of all options: I have the Sport mode (button selection) set only to change the chassis settings to sport (with the Dynamic Chassis and Variable steering this tightens the car up and if feels like my 2010 328i) but the transmission shifts stay as in Comfort. If I want the Sport shift points I just push the lever over to DS. As I have an AH3 this lets me push it to the left to keep the engine running (in stop and go traffic, driving through malls over speed bumps the constant on/off of the engine gets annoying) and keep the suspension soft, if I want full sport mode I push the lever to DS and hit the button to put the chassis into Sport mode.
There are times I want the suspension and steering tighter but less aggressive shift points, times I want the engine always on and ready for a quick acceleration but still have the chassis in comfort mode, and times I want everything in comfort or everything in sport mode: this allows me to to this.
Also, in D/S mode the transmission is in full Automatic with higher RPM shift points, until you use it to manually change gears: after that it will automatically downshift at stop lights or slowing down, but you need to manually upshift. It can be re-set to full Auto mode by pushing the lever back to D and leave it in standard D, or then push it back to D/S for fully automatic shift points. There is still Sport+ for the most aggressive auto shift and sport chassis settings.
I really like it, I tend to drive quite a bit in D/S but manually upshifting when in heavy traffic or neighborhood with a lot of stop and go, then put it back into D once on the open road.
I don't have the paddles as having had manuals in my early cars I like using the shift lever.
Old 07-15-2015, 02:08 PM
larryshomework larryshomework is offline
Is this your homework?
Mein Auto: 2009 335i
I too am trying to get clarification on this.
The simplest way to ask is whether or not there is any additional transmission change to putting the transmission in S1-S8 (moving lever left; not manual shifting) while in Sport Mode over simply putting the car in Sport Mode. Visually the difference is the dash indicator shows S1-S8 vs D.
I haven't changed my Sport Mode settings and switching to it definitely affects the transmission in addition to the steering and throttle response. Wondering if the S1-S8 is just show at this point or even more aggressive transmission.
http://filmyear.typepad.com/photos/uncategorized/2007/05/11/lebowski.jpgIs this your homework Larry?
2008 Porsche Boxster (White/Tan/Brown, 5spd)
2003 530i (Titanium Gray/Black, auto)
1990 325iC (Red/Tan, 5spd, convertible)
Old 12-01-2015, 07:42 PM
ML ML is offline
Mein Auto: 2016 328i xDrive
Shift points are higher in Sport/"S" mode than in Sport mode alone
EDIT: As cardsdoc was quick to point out, the transmission always downshifts one gear when you move the stick to the left. After further testing, the shift points appear to be the same during acceleration (see follow-up post below.) Sorry for any confusion.
I realize this is an old thread, but I'm hoping to help clear something up. In short-- "S" mode is not equivalent to Sport mode, from a transmission standpoint. In Sport/"S" mode, the shift points are even higher than they are in Sport mode alone.
Per Larry's suggestion, I decided to conduct a little experiment to prove it out. I started out in Sport mode, then switched from "D" to "S", while maintaining constant speed. Sure enough, the RPMs increased from ~2500 to ~3000.
Here's the video clip:
Old 12-01-2015, 08:30 PM
Mykatie's Avatar
Mykatie Mykatie is offline
2015 328x
Mein Auto: 2015 BMW 328i xdrive seda
Thanks for all the effort put in.
Old 12-02-2015, 05:12 AM
Remyrw Remyrw is offline
Mein Auto: 320xi
Just for another confirmation, my 2015 320xi has the same behavior. Regardless of whether you are in eco, comfort or sport, moving the shifter to M/S from D effects shift points. I'm not sure it effects shift speed or top gear or anything else, I have yet to push the car that far, but like the video, at pretty much every speed I've done it I see an increase in RPM and more aggressive shift points. It's most apparent for me at moderate speeds in town, since the rpms are noticeably higher and if you're puttering along you can actually feel the change as it tries to accelerate and you have to ease off the gas to maintain speed. Since I don't have any other sport related features I honestly don't feel much else changing when the car is in sport mode. To me it is pretty much all engine/transmission changes. I'm honestly not sure if the steering firms up or anything else really changes between driving modes in my car. The steering seems to firm up under more aggressive driving, but it does that in all modes. I need to go to an autocross day to really mess with it and feel the differences.
Old 12-02-2015, 06:17 AM
cardsdoc cardsdoc is offline
Mein Auto: 2016 340i xDrive msport
I haven't played with my 340 too much to see how it behaves but my on 2013 335 putting it into DS with sport mode already activated does not change anything. I do see the behavior seen in your video. It will always downshift one gear when you first move the shifter over. However after several seconds it will upshift again to prior gear and then behaves no differently than D.
On a related note my 340 will actually now shift into 8th gear while in sport mode with normal highway speeds (I was going 80). Sport + limits it to 7th. I'm very happy about this as I always had to put it into manual for 8th gear when cruising to save gas.
2016 340i xDrive, msport, estoril/saddle/anthracite, blk kidney grills, 400m mixed summer, adaptive m, technology, lighting, cold weather, drivers assistance, enhanced usb
Old 12-02-2015, 11:43 AM
keylime503 keylime503 is online now
Mein Auto: 2015 F32 Mineral Gray
Using the DDS button to go into SPORT mode is enough to fully disable ASS. There's no need to move the stick to the left if you want to disable ASS.
Old 12-02-2015, 07:16 PM
ML ML is offline
It appears I was wrong...
Doc, now that you mention it, you're absolutely right; thanks for setting me straight. I guess my science experiment wasn't so scientific after all... and now I'm worried I may be the one disseminating incorrect information, which is the exact opposite of what I set out to do
I recorded 2 more video clips just for fun: a 0-60 pull (albeit a slow one) in Sport mode, and one in Sport mode w/ the stick to the left ("S"). As much as I hate to admit it, the shift points seem to be about the same. I'll let you guys be the judge.
(Sorry for the shaky camera- bumpy road.)
