Old 02-04-2012, 08:42 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Removal of signal and trim on the front fenders
Old 02-05-2012, 10:27 AM
Ron Stygar's Avatar
19,585 Miles
Main Groups
Main groups are in the TIS (repair) , EPC (parts), WDS (electrical) etc.
If you purchase the cover trim it starts with 51 13
If you purchase the Signal lamp it starts with 63 13
http://www.penskeparts.com/DiagramsR...iagram=51_6112
http://www.penskeparts.com/DiagramsR...iagram=63_0759
If you have the part number you can find the TIS.
Notice the 13 in the middle of the trim and signal trim.
Old 02-22-2012, 05:51 PM
Ron Stygar's Avatar
19,585 Miles
Z4 Fuel Pump Bulletin
SI B 16 02 06 October 2006
01/10/06 up 09/08/06
Z4 M roadster LE89047 - LE89999
----------------LY52002 - LY52816
Z4 M coupe LL93008 - LL93334
Wiring harness may have been pinched.
Reroute away where it's pinched with tape.
Old 03-24-2012, 02:31 PM
Zuzax's Avatar
Zuzax Zuzax is offline
Calvinball Professional
Mein Auto: '07 M Roadster
Link to installation of Duralast Platinum H6-AGM battery in place of stock BMW 61 21 7 553 951 in 2007 M Roadster.
2007 Z4 M Roadster Sepang/Sepang-X/Black, Premium, Nav, BMW Strut Bar, Stubby Antenna, Dice, UUC clutch stop, Star Specs, and the rest joyfully stock.
Old 03-27-2012, 03:30 PM
Ron Stygar's Avatar
19,585 Miles
Pass Key
TCU
Old 03-27-2012, 05:27 PM
MitchSF MitchSF is offline
Mein Auto: 08 Z4 3.0si, RR Evoque
Triple blink for pre-facelift cars - Komfortblinker, http://www.jalt.de. I added one to an 02 330Ci, and it worked perfectly. It helps to speak German, but English instructions are available.
Old 03-27-2012, 06:40 PM
Ron Stygar's Avatar
19,585 Miles
34 00 ... General Information
Part of 34 00 ...
Old 08-31-2012, 04:35 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
FYI.
MZ3 coupe was formally (ie: OE window sticker) called "M coupe"
MZ4 coupe is formally called "M Coupe"
Not sure if roadster/Roadster is in the same boat or not.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Old 10-30-2012, 07:51 PM
tyz4 tyz4 is offline
Mein Auto: 2006 z4
just made a video on how to change a xenon low beam light for 2006 bmw z4. not sure where to post the info but this spot seems like a good start.
http://www.youtube.com/watch?feature...&v=Ooh16mEY3hQ
Old 01-13-2013, 12:00 PM
RonRock RonRock is offline
Mein Auto: 07 Z4
New member here. Good thread lots of good info.
Are the manufacture numbers correct in post #22? Those numbers seem very low to me.
Old 01-13-2013, 01:01 PM
Ron Stygar's Avatar
19,585 Miles
NA includes Canada.
Old 09-16-2013, 09:42 AM
Vladi Vladi is offline
Mein Auto: Z4 M (2007)
Z4 headlight polishing
Hi all,
Since the headlights are off the car now, decided to get rid of the extremely annoying "milky" look. Although it was nothing to worry about, it drove me nuts. Not very well seen on the picture, though:
So I started with sandpaper grit 600:
Then grit 1200:
And, finally, grit 2000. Not sure it was absolutely necessary since I could see no difference between 1200 and 2000 but I did it nevertheless. After grit 2000, used an alumina-based commercial polishing product :
After polishing, used the wax from the kit:
And the final result:
You should count not less than 10 minutes per grit. I worked by hand, maybe if you use a vibro-polisher it would take way les time. After every grit, wipe carefully the surface and check for deep scratches left from the previous stages. Remove them by further sanding. Remember: sanding is the most critical stage! Failing to do it properly will result in visible scratches even after polishing, so be meticulous!
For polishing I used a general-purpose drill with variable rpms. This stage takes a bit more than 2-3 minutes and is very easy, there are very few things that can go wrong there.
If you have deep scratches on your headlights, start from grit 240 or so and continue the same way as described.
Good luck!
Old 01-10-2014, 09:39 PM
mini-me mini-me is offline
Mein Auto: F80M3, Z4MR, X5d
Attached are the (v3) install instructions from the motion sensor alarm 65 73 0 309 944, have fun!
Originally Posted by Ron Stygar View Post
Just installed the alarm retrofit kit (without interior protection).
Part # 65 73 0 302 424 $112r
Initially wasn't going to add it, but an experience in VA on the way to HC changed my mind.
Basically a under hood switch and a siren with built in tilt sensor.
The siren assembly gets installed underneath the car between the two mufflers.
Instructions say you have to remove the rear bumper cover to do that.
Having the car apart before, that didn't make sense.
Turns out that you just have to remove (8 screws and 2 plastic nuts) the black bottom diffuser
plastic piece cover which gives you the same access that removing the bumper does.
Non M part:
Old 05-25-2014, 12:11 PM
dc_wright's Avatar
bimmerfest Supporting Member
Ship Killer's top motor replacement guides, guide on replacing the lift cylinders, and my DIY on relocating the pump motor to the trunk..........
Last edited by dc_wright; 04-27-2017 at 02:25 AM. Reason: Added my DIY on relocating the pump to the trunk area
Old 05-27-2014, 11:38 PM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
**Z4** How-tos (post links here)
Originally Posted by Brosenberg View Post
Hi I have a BMW 2004 Z4 3.0 liter and I'm looking for the amplifier part number. My dealership is looking for $1200.00 and I'm trying to beat the price?
See if your dealership accepts BMWCCA discounts. 20% off that price!
So net about $960.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 05-28-2014, 04:42 AM
dc_wright's Avatar
Look up part number on realoem.com or bmwfans.info and google search. BMW of South Atlanta looks like they'll sell it on line for $1K.
Old 07-13-2015, 10:05 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
All,
This thread is NOT for questions. This thread is to post DIY or How-To's. If you have a question about your car, please start a new thread. Do NOT post your question here. Your post will be deleted in the interest of keeping this thread on topic.
If you have a question about a DIY posted here, feel free to ask away here or int he original thread.
Old 01-29-2016, 08:28 AM
dc_wright's Avatar
I've essentially done a "rebuild" on the soft top on my car and here are the DIYs I've created as part of that work. I also relocated the pump to the trunk while I was doing this.
DIYs created:
Relocate pump motor to the trunk - Status: Posted
Replace your lift cylinders - Status - Posted
Replace your top canvas and headliner - Status - Under Construction
Old 04-02-2016, 01:12 PM
impreza276 impreza276 is online now
Mein Auto: BMW Z4 3.0si 2007 AT
A dashcam installation for the E85:
Old 04-11-2016, 03:46 PM
Uhaul trailer hitch installation
Cleaning the convertible drain holes
Old 04-11-2016, 03:47 PM
Sound generator mod
Old 08-11-2016, 10:49 AM
burlovgolf burlovgolf is offline
Mein Auto: 2006 Z4
Sticky Steering-Z4 2006 3.0si
I bought a complete steering column for a Z4 2008, 3.0si. After I received it I took it to a European Garage. They looked at the steering and said they couldn't satisfactorily install it since they did not put in"a Locking Key" before its removal. He told me to return it. My question is are they right that it can not be satisfactorily installed. Please advise
Old 08-11-2016, 12:10 PM
Bucko521's Avatar
Bucko521 Bucko521 is offline
Proud Canadian, I'm Sorry
Mein Auto: 06 Z4 3.0i & 01 Z3 2.5(2)
Please start your own thread with this question. This entire section is ONLY for DIY items. Not questions.
This reply and you question will both be removed soon.
01 Z3 2.5i Sapphire Black, 01 Z3 2.5i Topaz Blue(SOLD), 06 Z4 3.0i Jet Black
ZSCCA Area Rep and Member - Prairie CruZers
