e39 540i Body Shell Project
Hello,
I'm in the middle of replacing the passenger side shell on my e39. I have a parts car shell, and have been drilling out the spot welds. I'm at a point in the project where I could use some advice. (Do's, dont's, problems that I may encounter, etc.) Not sure exactley how to proceed from this point to get to the shell that I need. I need to replace the door jams, (from just in front of the passenger door to the tail lights. The parts piece that I have has plenty of excess material. Has anyone ever done this kind of work before? I would really appreciate any advice and knowledge about this project. I have attatched some photos. Thanks! Noah Added on 1-6-13 Ok, as I'm getting more into this project, things are starting to make sense. I have found how the skin has been seamed to the car. I have removed a kind of putty sealant, which was covering the seams. Question - Will the skin seperate without diffuculty once the spot drills and putty sealant has been removed from the seams? Last edited by EmpScorpion; 01-10-2013 at 09:47 PM. Reason: adding 1 |
How do I get to the spot welds that I can't see? I need to remove the excess material, to get to what I need to replace. Major project, overwhelmed.
nice!
I want to save the car. It has 100k miles and is mechanically sound. I've had to replace the entire front suspension, motor mount, and the positive battery cable. (The HPS airbag deployed)
That putty stuffis called "seam sealer" and must be re-applied after welding. You should really brace the original body tub up/down, sideways, and criss-cross so as not to lose original alignment of body. If you are good at oxy/ac welding you could weld the entire replacement piece onto the original after matching up the cut lines. Finish off with proper metal finishing process.
If you are going to just cut out spot welds and replace that is probably the better route especially if you are going to mig it all together. Take copious measurements off original tub and go at it. I would probably start at the "A" pillar then move onto the quarter panel. A bit of a job but can be done. After cutting out the spot welds you may have to do some prying to get the panels to separate. Good luck! Last edited by fortunateson; 01-11-2013 at 11:13 AM. |
Thanks very much Fortunate Son! I have some help with the welding, and we are going with mig wire feed. The more I get into this project, the more things seem to be falling into place. I have the Bentley shop manuals for the E39, but it doesn't get into this type of work at all. Thanks again, as I needed to hear some feedback that it CAN be done! I'll post more pics as the project moves on.
You are undertaking a project of proportions that the majority of us wouldn't dream of! Most of us would have started parting out the vehicle and bought another one. I commend your perseverance and wish you luck on your endeavor.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot. |
Thank You! The car has been sitting for a couple of years. I slid off a road in the Sierras after hitting some black ice. Thanks to BM Tech in Rancho Cordova, used parts have been plentiful, and not very expensive. I bought a couple of 17" style 19's from ECS Tuning, which saved a lot of money. I've decided it was time to start this project, as I LOVE this car. I had a 79 320i and a 71 2002 when I was in my twenties, and have been in love with BMW's ever since. I want the satisfaction of being able to put her back on the road, and put that scary crash behind me! It's a project of love!
ADDED: If the "b" pillar isn't too bad I would definately get a body shop to pull/push it out with a "Porta Power" rather than cutting all that material out and trying to replace it. It can be done but it is a lot of work that may not be really required. Shops that do this kind of work do it smartly as well as correctly. I just don't want to see you get over your head and go to far and not being able to go back. Best of luck whicheer way you choose! Last edited by fortunateson; 01-11-2013 at 11:21 AM. |
Thanks again Fortunate Son! I've attatched a few more pics. The rocker panel took the brunt of the impact. The B pillar (without a measurement) seems to be approx 1/4 to 3/8's pushed back. That is just by eyeball of how much the passenger rear door gap overlaps the door well. From these pictures, do you think that these dents can be pulled, or is it way too far gone for that kind of repair? I have started pulling parts out of the car, (backseat, passenger seat, trunk lid, passenger tail light, sunroof, headliner, ABC pillar covers,) and have been bag n tagging things for an easier reassembly. This site and the Bentley have been a huge help with removing things. I have more pics, or can take specific pics of the car if needed. I appreciate any help with this project!
Where do you plan on making the cuts? From what I can tell from the pictures you should only need part of the A & B pillars and the full rocker panel. Did the rocker damage make it to the inner floor metal? This is a big project to be done in a garage, especially if you have never done anything like it before. A port-a-power and BFH will help you greatly!
Kingshanker Stable; 2001 530i 2002 325ci 2000 740il (sold)
A
The passenger floorboard has a small ripple, not very big at all. The skin behind the rear passenger door doesn't look damaged. With the skin being one piece, I was thinking that the whole passenger side would have to be replaced. I was going to follow a diagram I found on the net, (see attatched) and seperate near the tail light. The outer skin goes about an inch under the car, and about a 1/2 inch in the wheel well. The roof seems more tricky to find where the outer skin seperates from the roof panel and the side sheet metal. If it is possible for a body shop to repair this, and the cost wouldn't be too steep, then that would be great. I wouldn't mind paying a couple grand to have this fixed professionally. If the cost was more than that, I do have the time and parts to fix it on my own. (With help from my Bimmerfest friends!) I'm a machinist, not a mechanic, and this project has been an educational experience. I am having fun with this, so I wouldn't mind DIY if it is possible.
Why not section in the rocker the the a pillar? The quarter does not look like it is messed up bad at all. Make sure to get the car pulled properly before you start cutting parts off.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
Yes, the rear quarter panel looks ok. I think I'm going to see how far I can get with disassemble of the parts piece. If I can be successful with that, then I will start on disassemble of the car. If it is too difficult, then I will scrap the parts piece, and go with a professional body shop.
Thanks Fortunate Son, this is a wealth of information! There is a Harbor Freight about ten minutes away. Do you think I should get as far along with the parts piece, as to minimize the labor cost, if I do have to have a professional complete the project? Maybe a combination of pro and DIY? I've attatched some more pics, as I can't find the seam on the roof panel. Last edited by EmpScorpion; 01-15-2013 at 03:01 PM. |
I'd try the Pro/DIY path for "fun and profit"! Seriously, this can be a lot of fun, a great learning experience, and a source of pride. Re: the roof joint. I would get one of those 3m stripping discs that look like and an oversize brillo pad and chuck it into the drill and then strip off the paint down to bare metal around where the filler strip fits between the main roof panel and the door jam areas. Do this on you salvage unit. I bet you'll see small indentations indicating spot welds. Voila. The got to be there somewhere, probably burried unde rseam sealer. As an alternative call or visit a body shop that has experience in working on BMW's, especially E39's, and ask them. You may find a sympathetic shop willing to guide you through this and perhaps willing to do the Porta power thing.
Fantastic idea! That's the tool and method I will use for finding the seam. Awesome!!! Here are some misc pics of what's been going on with the project since the wreck. I don't have the steering set properly, (alignment) but that's another job for another day. Also I bent the rear suspension, as the wheels wobble, which I noticed when towing the car. Three of the rims were ruined, (style 19's are very soft). The only rim that wasn't damaged was the driver front. I have two new style 19's and tires, along with my spare. (So I know the rims are not bent.) Things that I'll need to address later. I will keep you updated as things progress! Thanks again!!!
I really like those rims. I have style 44's which are my favourite but yours are a close 2nd. You just don't see many style 19's around. How is the supply of interior parts down in CA? I may be needing a couple of things if I can't find anything good locally. And whereabouts is Rocklin?
The 44's are NICE! Rocklin is about 20 minutes north east of Downtown Sacramento. For used parts, I go to BM Tech in Rancho Cordova. (About 15 minutes east of Downtown Sacramento)
http://www.bmtechautoparts.com/ For new parts, ECS Tuning out of Ohio, has the best prices in my opinion. http://www.ecstuning.com/ Both businesses ship anywhere. BM Tech has a huge selection of used parts! I hope this helps! |
Wow, what a project.
Thanks BK!
#25
I had a professional body guy come out and assess the car. He told me that the torque box is rippled. I was told that to get the car back to perfect, that it would be about 8k for the job. I don't want to put that kind of money back into the car. I'm not sure which way to go from here. Should I part it out, or sell the whole project in one shot? If I part it out, how should I go about doing this? Also, what is it worth? Any suggestions?
| Tags |
| body work, e39 540, need advice, shell |
