7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#76
Lol if they are not iridium you're doing it wrong
2007 Kawasaki Ninja ZX-14 2006 BMW 750i 1972 Dodge Charger 1968 Dodge Charger 1967 Austin Healey Sprite |
#77
I just completed this job and I have a few things to point out. I used the following link to get started but I would also add the following points:
The taped extensions are designed to keep you from leaving your tools in the engine when you are installing the new plugs. I did not find this to be needed because I put some lithium grease on the white portion of the plugs thus keeping the plug from sticking to the spark plug socket. I also used one 1 1/2" extension and three ratchet size adapters. I left the third one loose as in the picture until I had the plug started in the hole and then I added the third and then hand screwed the plug in before using the torque wrench 19 newton meters or 14 foot pounds. Then wiggle your extensions back and forth and it will come right off the plug. Remove the last extension if needed for clearance. I also put lithium grease on the boot of the coil. This conditions the rubber, improves the seal and at the same time makes them easier to get out next time. It's also MUCH EASIER to remove the coils with the wiring harness disconnected because you have something to pull on yet nearly impossible to get the harness unplugged (depending on orientation) with your hands and you don't want to break anything using a tool. HOWEVER, if you slide a small flat edge screwdriver in from middle toward the outside, slide it to one side and gently twist the blade back toward the middle, at least one or both sides of the harness latch will come loose. If only one, you can try the other side while applying some traction with your free hand. This is the ONLY METHOD I can recommend using a tool to get these open. If however, you can't or don't want to get the harness loose before breaking the coil loose, rotate the coil so one of the flat edges is away from you and just pull back toward yourself in one direction (rotating won't help), these are basically in there by suction, and if you keep pulling you will feel it eventually give way (and it will feel like you are pulling the plunger out of a syringe). I also saw no need to remove or loosen anything aside from the engine covers. I took me a couple hours but knowing what I know now, I bet I could do yours in 30-45 minutes so feel free to stop by.
| Tags |
| 745i spark plug diy, e65/66 spark plug diy |
