Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 11-08-2011, 11:25 AM
kuyaedou kuyaedou is offline
Mein Auto: 2003 BMW 330i
good job!
This post saved me $260+ from the dealership to have it fixed! Thanks for sharing your detailed work for the sunroof man!
Old 11-10-2011, 02:12 PM
jordanfanx23x jordanfanx23x is offline
Mein Auto: 2000 BMW 328i Sports Pack
No Problem! Glad it helped!
Old 01-13-2013, 09:14 PM
monkeyhead monkeyhead is offline
Mein Auto: 2003 330i
Hey Chris, thank you for the sunroof DIY, it saved me mula
Old 07-19-2013, 03:44 PM
ejkuch ejkuch is offline
Mein Auto: 2001 330ci Coupe
Thanks for sunsadediy! Fixed my problem in 15 minutes!!!
Old 08-24-2013, 05:24 PM
bcain79 bcain79 is offline
Alpha Phi Sigma
Mein Auto: 2001 BMW 530i
This is a great thread! Thank you for putting the DIY together for this!
2001 BMW 530i e39 / Automatic / Orient on Dove
Old 12-01-2013, 01:07 PM
mrgilbert mrgilbert is offline
Mein Auto: 2005 330i
do all cars have a "driver" i have an 05 330i and my sunroof rattles when i try and open it the shade doesn't close all the way either and no clips are broken what i do notice is that the passengers sliding tab doesn't move. i have no problem sliding the drivers side back and forth
Old 12-01-2013, 04:10 PM
maybe you shade doesn't close all the way because the glass is sitting to low, readjust the glass to a higher height, unscrew the lid retaining screws, push the glass up, then tighten the screws and see if you can close the shade
Old 12-01-2013, 04:16 PM
hey thanks for the reply i failed to find out what is keeping the passengers tab from sliding back and forth, as a result the window is piped out just a bit but when i put the shade back on it worked fine x)
i guess thats a plus haha
Old 12-01-2013, 09:09 PM
That's definitely a plus... Lol... Glad u fixed it
Old 12-30-2013, 08:16 PM
MIflyer MIflyer is offline
Mein Auto: 2002 325i
Great thread - the DIY was accurate and it's an easy job. Thanks for saving me a trip to the dealer!
Kevin
Gulf Shores, AL
Old 01-04-2014, 12:35 PM
gamarosado gamarosado is offline
Mein Auto: Puerto Rico
I have a 2006 BMW 330i, the information was helpful I took of the sunroof glass but when I was going to remove shade the clips are different they don't have screws, do you know how can I remove them?
Old 11-18-2014, 04:00 AM
CrazyOneToo CrazyOneToo is offline
BMW Roxxx
Mein Auto: 1999 328i, 2002 X5 3.0i
Originally Posted by BM-MAN View Post
How exactly did u achieve that? There is a tab that automatically pulls the sunshade back when you open the glass? Seems to me that holding it shut would break something?
My problem right now is the Driver; the metal that holds the plastic driver in place is bent. I just don't see how to bend it back in place...
I have the same problem and my plastic driver part is missing also. It fell back into my headliner bowels I'd imagine.
Can that plastic piece or the driver be bought separately? And how would you get the old driver out and the new one back into place?
Thanks for any help on this.
My 1999 328i and 2002 X5 3.0i.....both always in progress.....
Similar Threads
Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions EPBB E46 (1999 - 2006) 119 05-09-2010 05:09 PM
Is there a DIY for fixing a broken sunroof shade? wag-zhp E46 (1999 - 2006) 11 07-21-2005 06:23 PM
2001 e46 sunroof shade guide broke sun3301 E46 (1999 - 2006) 10 06-03-2005 08:25 PM
Has the horrible sunroof cover 'clip design' been fixed on the E90? missing23 E90/E91/E92/E93 (2006 - 2013) 5 05-26-2005 02:57 PM
Sunroof problems MStewBoy 3 Series & 4 Series 5 01-23-2004 12:12 PM
