E90 Krytox door seals - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 12-25-2012, 10:21 AM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
I wanted to contribute something back to the forum as a return for all the searches I did prior to picking up my E90.
Many use the 1Z Gummi stuff, which works for a majority of the rubber seal areas except parts of the sedan doors where the seals both touch the frame of the door, as well as the frame of the B pillar and associated areas that are painted.
You need an EXTREMELY small amount of this expensive stuff, seriously, you can just rub it into the rubber and it absorbs and lasts for months, up to 400F!
The areas on the door itself need some Krytox around the entire surround of the seal, where the seal touches the top part of the frame.
One photo I didn't take was in the window guide (roll window down and you'll see it. Don't let any Krytox get on the glass, you'll be there FOREVER removing it!
I hope this helps some folks with the door "tick", which is now eliminated.
Other uses for Krytox were the areas where the center trim panel meets the HVAC controls; the rubbing is eliminated with this stuff as well. I've had this tube it seems for 2-3 years and continue to revert to this stuff.
ID:	354565   Click image for larger version
ID:	354566   Click image for larger version
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 01-13-2013, 09:26 PM
aRangel aRangel is offline
Mein Auto: e92 BMW M3
I didn't understand what this is for
Old 01-15-2013, 06:59 AM
thekurgan's Avatar
Bad Lieutenant
Creaks/squeaks etc noises from the door seals.
Ilse
Bruna
BMWCCA #453648
krytox, seals, weatherstripping
