The latest X3 brings some added style and some new features to the BMW SUV family. Talk about the new F25 now!
Old 08-28-2012, 01:12 AM
hjno72 hjno72 is offline
Mein Auto: BMW X3 xDrive20D 2012
USB Tips for X3 F25 using a Mac
This may work for other Beemer models but I cannot gaurentee that. For instance I found that my sister's 2012 1 Series can playback music on a NTFS usb drive whereas my 2012 X3 F25 could only do FAT32.
I use a SanDisk Cruzer Fit 16GB formated FAT32. The tiny form factor makes it the perfect disk for the beemer's usb.
http://www.sandisk.com/products/usb/...?capacity=16GB
The entertainment option I chose was the 6NH, the cheapest of the lot but gave me decent features, plus... and this is really a plus the center compartment does not have extra phone connectors in it taking up space.
So here is the tips:
- Format your USB drive to FAT32 (NTFS does not work)
- When using a Mac all sorts of dot files are created, that the BMW interface can see. This is very annoying as you see these shadow files and they give you cannot play messages.
- the following commands when run from the root of thumb drive connected to a Mac will eliminate this problem
DO NOT RUN THESE COMMANDS FROM THE ROOT OF YOUR MAC
GOTO TERMINAL (if you don't know what this is DO NOT CONTINUE past this point)
cd /Volumes/[your disk name]
find . \( -name '._*' -o -name '.DS_Store' \) -exec rm {} \;
rm -r .*
You need to run this every time you connect the thumb drive to your mac.
Guys, I will write a program which I will post for free shortly for those with lesser abilities to cleanup these shadow files.
Old 01-14-2013, 01:19 AM
lahiruwan lahiruwan is offline
Mein Auto: F25 2.0D
Hi
I have the same car with 6NH. I also am using the Cruzer Fit 16GB.
I took the USB drive out of the socket in the center compartment and now its not recognizing the drive when I plugged it back. There is a tick in front of the Aug-in input but the USB is grayed out.
It happened once before but sorted itself out the next time I started the car. Tried everything this time but no luck!
Have you come across this problem before? Thanks for your time.
Regards
Lahi
Old 03-29-2013, 08:58 AM
Unfortunately I can't help, all I know is that it intermittently recognizes NTFS formatted drives. Fat32 formatted drives are always recognized.
I now use a 32gb Fat32 formatted drive and its working.
