Old 11-20-2012, 05:57 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2003 745Li
Originally Posted by TUF-FKR View Post
Holy $hit that was a PIA! On a scale of 1-10, that is a 7. They are back together and the adhesive is drying. They will be re-installed in the morning. I have about 6 hours into the whole project. You really hack up your lights, but its in areas that are not going to be seen. I also found Black adhesive RTV at Autozone for $10. I took a couple of pictures that I think will help explain a little more. I blew out my dremel and it took about 4 cutting blades to get through both lights.
Soapy water doesnt get rid of the haze on the inside. I tried clay bar with spray polish, everything I had in my arsenal. What ended up working the easiest and best was an "all purpose adhesive remover". This applies easily and wipes clean. I took a high speed buffer and polished the outside of the lenses too while they were off. I painted the corner lense (was yellow) black and I removed the tint over the outside of the lenses. I will post finished pics later this week. START THIS PROJECT FIRST THING IN THE MORNING! Buy everything first..
Damn bro congrats on tackling that task.. Can't wait to see how they came out.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 11-20-2012, 11:32 PM
TUF-FKR TUF-FKR is offline
Mein Auto: 2002 BMW 745i
Here are a couple of pics. The first one is the headlight with the flange removed with the dremel and now I am cutting the rubber to remove the lens. "Apomerans" drew a good diagram of what it is like and he labels them Cut #1, Cut #2. You cannot complete this task with cutting #2 only. I did not realize this with the first headlight I did and I had to then go back and cut all the way around again with his Cut #1. The second headlight I skipped cut #2, and went right to his cut #1 angle (still follow me?). I had better results cutting #2 first, then going back and cutting #1 (all still referencing Apomerans diagram drawing).
The problem with going right to cut #1 is you are cutting blind and can go too deep into the inner housing (making a hole into the headlight). I made a small error, this but was able to re-seal when I RTVed the lights back together.
The first pic shows the rubber is UNDER the lens that has to be cut out. All in All, it was SO worth it to me. The front end of the car looks so much cleaner and new. If you have angle eyes it makes them ALOT brighter!!! I do NOT regret this mod at all. The good news is, if you have to re-do it again, you only have to cut the RTV, no more dremeling next time...
ID:	350323   Click image for larger version
Old 11-20-2012, 11:46 PM
(I made a couple of edits after I re-read my post).
Oyeah, whoever said you could get this apart by "baking" them?? I want what your smoking... This $**** is like tire rubber. An angled blade would have helped me, less stuff to dremel around to get my box knife into. Someone mentioned a dentist tool kit, that probably would have been better.
Old 11-21-2012, 06:01 AM
Nice!how long did it take to make the actual cuts? I would think that's the part one would have to pay close attention to and be patient with.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 11-21-2012, 10:23 AM
The dremel work took about 20 minutes per headlight. The cutting of the rubber under the lens takes about 1 hour each.
***IMPORTANT NOTE*** Your side markers are snapped in, if you remove them to paint them, glue them in place. I have one side marker that is moving around a bit.
Old 11-21-2012, 10:45 AM
blackedout5 blackedout5 is offline
Mein Auto: BMW 745li
Good job Glad to see other people successfully doing this to their cars. Hope my pics and description helped out.
745li Black on black- 22'' Makaveli Trionfo 3pc. wheels, H&R front lowering springs with home made adjustable rear end links, blacked out window trim, cheap ebay Angel eye bulbs
Old 01-06-2013, 09:05 PM
Joe Tamez Joe Tamez is offline
Running Again!
Mein Auto: BMW 745
There hasnt been much discussion on it, and Im still very intersted in where (if possible) I can order just the headlight lenses for this car. Headlights themselves work fine, and since its a unit that was assembled in pieces Id assume (somewhere, some how) I would be able to purchase the lenses only. Please advise guys
Old 01-07-2013, 07:35 PM
verbals verbals is offline
Verbals
I plan to take on this project on Wednesday or Thursday. Couple quick questions/concerns before I pull the trigger. #1. Do I Dremel around the entire headlamp assembly or just the top lip that covers the lens seal? #2. If I want to paint the orange side marker black (or Anthracite Grey), which kind of paint do I use? #3. How long do I let the sealer bond/cure before putting the headlamps back in? Sorry for the rookie questions but I'm still a little hesitant due to the fact that our headlamps are a couple months rent. I have to do it tho because I hate the inside haze more than I fear f*<%ing up. Thanx, 'Fest!
Old 01-07-2013, 07:36 PM
Verbals
... more than I fear fouling up ...
Old 01-13-2013, 07:40 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Did this today took me all day practically nice sunday project. Drivers side was HORRID. 100x better. Light cutoffs look perfect now. Thanks for the writeup and giving me the courage to dremel my headlamps open
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 01-13-2013, 09:00 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
Glad to see it worked for you bro. How about some pic so we can see how well you did.
Old 01-13-2013, 09:32 PM
745iguy's Avatar
Ill post some up tomorrow of it on the car. Heres a pic of the lens and the housing without it. Didn't take many pics but being an 02 you can imagine how they looked before. Dremel i bought from home depot for 50$ and came with attachments. The light output was well worth the cash and the time
Also would like to add the lens pic was taken after i used some goo gone spray on the inside. It took most of the grime off before more thoroughly cleaning and polishing. Used 3m, and meguiars. Buffed and polished. Didnt sand it as i did not have much but crud on the inside and out.
ID:	357596   Click image for larger version
PREVIOUS 2002 745i
Old 01-14-2013, 12:41 AM
javier1605 javier1605 is online now
Mein Auto: 735i E65 2002
I think this is generating a new generation of seven's owners.... the one's that have cleaned the interior of their headlights and the one's that are supossed to do so in a short time!!!
Well done!!!!
Old 01-14-2013, 08:15 AM
745iguy's Avatar
Daytime
ID:	357651   Click image for larger version
PREVIOUS 2002 745i
Old 01-27-2013, 05:36 PM
flash_n flash_n is offline
Mein Auto: 745Li
First I was afraid, then scared s#§%less. Once you dremel that case YOU ARE commited.
And no joking, cutting the seal all around is multi-hour PITA.
Just put the glass back in with the 3M window weld urethane. Can't wait to see it back on the car.
Thanks for all the good advice in this thread.
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer
next up:
headlight vertical aim, VCGs, P0492
Old 01-28-2013, 11:45 AM
blackbeast blackbeast is offline
head lights
Nice! Thank you for blueprint man.
Name:	BLACK BEAST 2.jpg
ID:	359571   Click image for larger version
Name:	BLACK BEAST 1.jpg
