Old 01-14-2013, 08:34 AM
Emeer18's Avatar
Emeer18 Emeer18 is offline
Mein Auto: BMW 745Li
L7 amp ????
So i took my 7 in to the local dealer. My bass goes in and out. The dealer says my subs are blown. I know car audio and i highly doubt it. When subs are blown they dont just work one day and stop the next. Thats a connection or amplifier issue! What do you guys think? They also wanted $900 per speaker to repair. Insane!
Old 01-14-2013, 08:46 AM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
well the subs are pretty easy to access... four bolts connect seat to floor... lean seat back and viola - access to subs.... check for yourself.... test the leads on sub with volt meter on ohm setting or continuity.... check cable from amp for voltage (presence of signal) (while audio is on).. hook up sub to another source see if it works at all (dont keep it on another source for long, impedance mismatch can damage speaker and amp) and wrong frequencies not good for sub... try another sub to connections to car amp... \
even if subs were "blown" you will still get sound but distorted as hell... usully spyder becomes disconnected from cone or coils burn out.... the latter could cause no sound (which is what continuity test is for)
Old 01-14-2013, 08:51 AM
Emeer18's Avatar
Thanks for the quick response. What size subs are under the seat and whats the ohm load on them?
Old 01-14-2013, 09:34 AM
8"..... as far as impedance, 6ohm is standard for most car applications, and 8ohm for most home applications, but I dont know for sure for this car..... someone else on here will tho.... 2 and 4 ohm are usually set on afteramrket subs, but I have found on cars with integrated subs (stock) the subs impedance matches the whole system
Old 01-14-2013, 11:20 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Stock subs are 4 ohms
Old 01-14-2013, 11:25 AM
Emeer18's Avatar
Thanks, what subs would you recommend. I see bmw tis is down aswell. How do i remove them?
Old 01-14-2013, 01:49 PM
Emeer18's Avatar
So i got the subs out. Seems like they are fine. I think the dealer is messin with me. 4ohm single voice coil by the way.
ID:	357692   Click image for larger version
Old 01-14-2013, 02:05 PM
DFEL750I's Avatar
Mein Auto: 750I
If you want to replace them with aftermarket subs you can buy the earthquake shallow 8 inch subs. Here is a link below
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old 01-14-2013, 03:09 PM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
It's not your speakers it's your L7amp. Subs Ch. goes bad first.
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 01-14-2013, 03:36 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is online now
Mein Auto: BMW 745LI/ F02
Originally Posted by rideme2 View Post
it's not your speakers it's your l7amp. Subs ch. Goes bad first.
+1
Old 01-14-2013, 04:05 PM
Sebringx Sebringx is offline
Mein Auto: BMW 750i
Emeer18 it is l7 amp ....Rookie is so right. I have the same problems with mine. A INDY told it was the subwoofer ....NOT. Soon your Sub's will stop working all together ......it's RARE for Both subs to go out....unless its the channel powering them from the amp go out.
Old 01-14-2013, 04:20 PM
theres a thread on here to fix... or send to ilya.... price is right, but he's ~~~~~~~~~ alright...
Old 01-14-2013, 09:13 PM
Emeer18's Avatar
Thanks guys for all your input! I had it out with the dealer today. I got my seats out and got the subs out easily. I tested each speaker. They sounded crisp and clear. Then went to two local car audio shops. They backed up my conclusion. Went back to the dealer sat the sub on the mans desk and demanded a real diagnosis. The amp is barely a year old! Its under a 2.5 year warranty. I think the dealers trying to avoid replacing it!
Old 01-14-2013, 09:14 PM
Emeer18's Avatar
The subs already stopped working, they jus have popping now. The doors are the only things working
Old 01-14-2013, 10:25 PM
of course... that amp is $1200 (retail at dealer) so the invoice cant be less than 1000...
Old 01-25-2013, 06:35 PM
Emeer18's Avatar
Update: So they finally diagnose the L7 again and determine its not sending a signal to the speakers. Big surprise! And they wont give me the diagnosis fee back even thou they agreed to!
Old 01-26-2013, 09:46 AM
KingSilverback KingSilverback is online now
The Silverback
Mein Auto: 2006 750Li
Just send it to ilya he'll fix it and it'll sound better and last longer than whatever the dealer would replace it with.
Old 01-26-2013, 10:35 AM
Mein Auto: BMW 750i
Don't miss out on item BMW OEM FACTORY AMPLIFIER L7 LOGIC65-12-6-961-389 BMW TOP HIFI DSP SYSTEM AMP (181068146593)
this on eBay
Old 01-26-2013, 10:37 AM
Mein Auto: BMW 750i
Here is the link::: I just a Ordered one for $250
Mein Auto: BMW 750i
Hi! I found this on eBay and thought you might like it! "BMW OEM FACTORY AMPLIFIER L7 LOGIC 65-12-6-961-389 BMW TOP HIFI DSP SYSTEM AMP" http://r.ebay.com/uufoHX
Old 01-27-2013, 05:28 AM
Emeer18's Avatar
Thanks but its already getting replaced under warranty.
Old 01-31-2013, 05:21 PM
Mein Auto: BMW 750i
Just replaced my Logic 7 amp....it took about 15-20 to replace amp. My subwoofers are working excellent now!!!!
Old 02-01-2013, 09:53 PM
Emeer18's Avatar
Im still waiting on mine to arrive, its always the amps.
