E36 (1991 - 1999)
Old 01-14-2013, 12:35 AM
E30sixer E30sixer is offline
Mein Auto: 94 325is
Heating issue
I have an issue with my cars heat when I first bought the car it worked great ,, as does the AC too now the AC still works but the heat doesn't blow hot air only cold . I live in Pa definitely need heat ..I've tried narrowing down this issue but it doesn't seem to be neither thermostat nor water pump I replaced even have new hoses not that it would solve the problem but replaced only because they were there can't think of anything else .. Any suggestions would be greatly appreciated ..
Old 01-14-2013, 05:05 AM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 1993 BMW 325IS
I'm assuming coolant level is good and you bled the system properly after the hose replacement.
You should check the valve that let's coolant into the heater core.
Sent from my ADR6300 using Bimmer App
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Buy stuff!
E36 parts: http://harrisonburg.craigslist.org/pts/3696167489.html
E36 5 speed swap: http://harrisonburg.craigslist.org/pts/3696120610.html
E46 parts: http://harrisonburg.craigslist.org/pts/3696151076.html
Old 01-14-2013, 10:44 AM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
wait....wut???
if you replaced the thermostat and bled the system properly, and are not overheating, then you should have plenty of heat.
you *could* have a restricted heater valve, or heater core, but you will need to use a proper infra red thermometer to get accurate temp readings.
otherwise you're going to be guessing.
and guessing gets expensive....
i say go back and double check the cooling system is bled. these are tough enough for experienced automotive technicians, so it has been my experience that almost 90% of diy'ers that have done this have not done it properly.
df
Old 01-14-2013, 11:32 AM
Mein Auto: 94 325is
Correct no overheating issues , though I was once told about the heater valve i don't know where it's located ,, and assuming the bleed system wasn't done the correct way what would be the proper way to bleed my system ,,,?
Old 01-14-2013, 12:51 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
From here:
http://www.bimmerdiy.com/
Id suggest going here:
http://www.pelicanparts.com/BMW/tech...lant-Flush.htm
and following the steps they recommend.
Once you've gotten all the air out, start from the beginning and do it all over again, because you've still missed some air.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 01-15-2013, 04:49 PM
Mein Auto: 94 325is
I couldn't help to remember . And I know it sounds stupid but . Could it be that from leaving the cap off on your rad an blowing coolant everywhere then putting coolant back in it cause this problem which would mean that there is air in the cooling system ?? Lol I know it sounds foolish but I did forget to tighten the cap on it one time
Old 01-15-2013, 04:53 PM
Mein Auto: 94 325is
I will be doing a complete coolant flush on my e36 this weekend updates will be posted ..
Old 01-15-2013, 04:59 PM
jonesin's Avatar
The Canadian Prick.
Yes, having the cap open while driving will induce air into the system.
Old 01-15-2013, 06:20 PM
Mein Auto: 94 325is
of coarse hey thanks a lot jonesin
Old 01-18-2013, 02:41 PM
Mein Auto: 94 325is
I did the coolant flush as instructed in the links an the car only has heat when running after I'm stopped for a little while the heat goes away .. I dont know what else to diagnose I'm stumped right now ... ??? I need heat in my e36 I live in a very cold area I'm originally from SoCal not used to this **** ...
Old 01-18-2013, 03:33 PM
Mein Auto: 94 325is
Help anyone I'm trying to get my e36 up to par I just bought it not too long ago and I want to be able to have it running at 100% this isn't the first issue I'm sure ill be throwing tons of things out there to pick your brains .. And mine
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
You still have air in the system. If you drive it like that it's going to overheat.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 01-18-2013, 03:41 PM
Mein Auto: 94 325is
I took it around the block nowhere too far . Just trying to figure out how it still ha air in the system how long do I let the car sit for with the bleed plug open .. ??
Old 01-18-2013, 03:43 PM
Mein Auto: 94 325is
Another thing I was going to ask is it normal for an e36 to run just a tad hotter on the temp gauge like just barely .. Or does that mean I'm overheating ? Because it never shoots up just stays there steady
Old 01-18-2013, 03:54 PM
D'oh, You kids!
Until the bubbles stop. Even the tiny ones. Then do it again/more.
The temp gauges on BMWs are buffered. It will indicate straight up if it's anywhere in the neighborhood of normal temperature. If it's indicating a little high, it may just be a gauge glitch, or it might be actually running a little hot.
Quotes to live by:
BMW-CCA #441426
Old 01-19-2013, 10:17 AM
Mein Auto: 94 325is
Hey thanks a lot seems to just be a gauge glitch I hope .. I'm actually going to be bleeding the system again today.. Hoping I can get all the Air out this time
Old 01-21-2013, 06:57 PM
Bimrpwr's Avatar
Bimrpwr Bimrpwr is offline
Mein Auto: 93 325 and 91 K2500
try to clean the heater core. Lot of people will flush it out with CLR for about 30mins. and then Back flush it as well..
Old 01-22-2013, 11:22 PM
Mein Auto: 94 325is
How would I flush heater core because when I was doing the coolant flush I let the car run for a lot longer than 30 min to let air bubbles out but still not any heat coming through only when I drive it around the block did it throw a little heat then as soon as I came to a stop it blew cold air ... compete fail
Old 01-22-2013, 11:40 PM
Mein Auto: 94 325is
And also how would you even begin to back flush the system this is a sad sad story I feel like a fool that I haven't been able to get this fixed
Old 01-23-2013, 05:07 AM
Theo podges Theo podges is offline
Mein Auto: '96 328i, '98 318is.
I think this must be your heater valve.
On the right-hand drive cars they are situated on the fire-wall by your inlet manifold (two metal dome like pieces with coolant pipes running into them). When mine was disfunctional they kept the heat on no matter how you adjust the climate control.
Old 01-23-2013, 11:23 AM
Mein Auto: 94 325is
Many thanks I was aiming towards the heater valve after all this nonsense .. I haven't been able to have my fun this winter cause no heat .. Ill be checking the heater valve Friday it's a little cold out 5 degrees cold right now
Old 01-23-2013, 01:05 PM
Mein Auto: 94 325is
And another thing my car Is LHD ?? Don't know of its any different
Old 01-23-2013, 02:24 PM
cj32769 cj32769 is offline
Mein Auto: e36 318is, e36 325is
I had the same problem and had to add more coolant and bleed it even more now my heat has two settings off and cremate.
Old 01-23-2013, 07:13 PM
Mein Auto: 94 325is
Haha sounds like the setting I need
Old 01-23-2013, 07:14 PM
Mein Auto: 94 325is
.. I will be bleeding this car again and again till it blows heat I mean everything was replaced Idon t understand this is definitely turning out to be a huge headache
