X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
I noticed that too and asked about the 107 load rating but Les Schwab would guarantee their tire. But I've now walked away as I don't feel comfortable with the lower load rating. I'll stick to Costco but don't like their waiting times.
Sent from my SAMSUNG-SGH-I777 using Bimmer App |
Not really. I've already walked away from les Schwab now and can afford to look around. Costco and discount tires are my next choices. I plan to stick with Bridgestones.
The slightly lower load rating is ok if you are not using the vehicle at its max rating per the manufacturer...very few people do.
2013 X5 xDrive35i 2011 M3 Sedan 2002 Z3M Coupe |
I don't consider that load rating as "slightly lower".
Its significantly lower. |
I do my research, shop prices on line...call my tire store,see if they can match or come close. They order them if necessary, call ,e when the arrive,best up an appointment to pop them on.
Screw driving around ....
Keep it as simple as possible...but no simpler. |
103 is rated at 1.929lbs
107 is rated at 2,149lbs That equates to about the weight of a regular adult male...
Yep, not much of a difference AT ALL but a lower rating also typically equates to a softer sidewall as well so I'd skip it simply due to that fact alone
![]() '12 X5d Sapphire/Black/Bamboo, Sport (ZAP), Premium (ZPP) & Premium Sound(ZPS) packages: 20" 214's, OEM Hitch![]() GONE - '06 750Li Sapphire Black/Creme&Black (Loadeddddd)
Times 4, no?
I wonder if the run flats have a higher load rating by default due to a harder sidewall
I'm on my second set of Toyo STIIs. Love them, got over 40K miles out of the last set.
Get the XL version only however. 107V
