Old 01-11-2013, 06:14 PM
BadboyzTn's Avatar
BadboyzTn BadboyzTn is offline
It's the Principle
Mein Auto: 2011 740i M Sport
Running Rough/Shaking
Hello everyone...... My Service Engine Soon light came on. Had it checked at Autozone (maybe not the best place?) and it read random misfires. Car ran fine really, except would barely shake at start up every once in a while. I had the plugs/coils changed and now the car shakes tremendously worse... Feels like it is going to cut off, smooths out when driving, but still rough when accelerating. I know it could be a few different things, but does it maybe sound like the vacuum line? What's the INDY cost for that repair? I dropped my car off for Diagnostic to be run on Monday morning. Any thoughts???
2011 740i ///M-Sport|Black Sapphire Metallic|Saddle|20" 303M-Sport
Old 01-14-2013, 04:01 PM
BadboyzTn's Avatar
It's the Principle
Shop switched plugs 5 & 7 and ALL is good. Light went off and running smooth as a kitten.
Old 01-14-2013, 07:14 PM
herika herika is offline
Mein Auto: 2004 BMW 645ci
Replaced ignition coils on mine and it solved the shaking/rough idle problem for me.
Old 01-20-2013, 09:32 PM
Radradrad Radradrad is offline
Mein Auto: 2008 650i
I only mention this because you had Autozone people under your hood: rough running? - check that the oil filler cap is on tight.
Old 01-21-2013, 02:32 AM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
Just one extra question. Does your iDrive show when u need to replace spark plug and microfilter? Mine doesn't show. I have 09. I know there are cars showing that.
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 01-21-2013, 03:07 PM
bismarck bismarck is offline
Mein Auto: BMW 645ci
Mine are due for a replacement soon. Will probably do coil packs too. How much did the two plugs set you back?
Old 01-21-2013, 03:09 PM
Can't speak for everyone but I presumed it would be the same on all the idrive systems - there's a service requirement indicator in the vehicle information section. Gives you mileage or dates as to when certain service parts are due. If you mean does it tell you to change them when they are faulty then no (mine doesn't anyway).
