BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#126
All are aktiv = 1
#127
Ok, got it to work... It only shows-up from using the steering wheel controls, not the Idrive main controller.
#128
And you get nothing in the HUD? No Entertainment, No Recent Call List, no nothing?
What about under iDrive Info Display, is every thing checked off? Same thing under HUD options?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#129
Ok. Good deal.
#130
What are these hives for:
Kombi & HU_NBT: HUD_VZA_ENABLE Kombi only: HUD_TLC_ENABLE
Minha patroa é um BMW |
#131
Tlc is lane change assistance on hud. But you need to have driver assistance package for it to work.
#132
Convinced my dealer to update my software while I had it in for maintenance! Tonight I was able to add entertainment, incoming calls, recent call list and voice commands to my HUD. Thank you all for the help with this!
2012 550i MSport 6MT - Dinan S3 - Imperial Blue Metalic/Everest Gray - 20" 373M Wheels |
#133
What does voice commands do?
2011 BMW F10 528i M Sport |
#134
It is just a visual confirmation of your voice commands. Just like it shows in your BC under the speedometer...but cooler because it is in your HUD.
#135
Thanks,
#136
That is sweet ride. Love the wheels. I am putting on the 312, put M5 grills, but I may switch back after noticing your 550.
2013 550i X-DRIVE, M-sport, Imperial Blue, Black Nappa, DHP, B&O Sound, DINAN stage 2, M5 Grille, Escort 9500ci, Coded. |
#137
Hello,
I am picking up my 550i next weekend and am interested in coding the music/phone options into the HUD as described here. A quick clarification - will the title of the song currently playing by your plugged in iPod or bluetooth integrated iPhone show up on the HUD? Does the HUD entertainment option only show stations but not the song/artist info? Can't wait to play around with this stuff!
2013 550i (Delivery ETA April 28 2013) Carbon Black | Black Dakota Leather | Aluminum Hexagon Trim| Sport Transmission | M-Sport | Dynamic Handling | Driver Assistance | Executive | B&O Audio | Luxury Seating | Power Rear Sunshade | Heated Seats |
#138
YES, it will show the song name only, based upon input selected, IPOD, etc, recent calls (if you press the phone button (the same as it does in the extended display. This is activated by the buttons on the steering wheel.
It will also show incoming call info.
#139
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats |
#140
The only thing missing from the entertainment on the HUD is song and artist info when switching satellite radio channels. That would be nice. You see song names when scrolling though USB/Bluetooth music on the HUD so maybe it is possible to turn it on for Satellite. Any ideas?
#141
Was reading through this post trying to program HUD for incoming calls, playlist. My KOMBI CAFD file is KOMBI: CAFD_00000069_008_000_042 not KOMBI: CAFD_00000069_009_000_042.
I cannot see the required options similar to others that responded. Can I rename the required CAFD file (in my folder) to the name read by the SVT? I that doesn't work, how can I copy or update it? Thanks |
#142
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on Kombi => Click on "Detect CAF for SWE" => Select newest CAFD => Select OK => Right-Click on Kombi (the ECU itself not the underlying CAFD) => Select CODE. Afterwards, you can FDL Code as normal. That said, I don't think simply updating the CAFD will add anything. In order to get the features, the firmware on Kombi needs to be updated to >= 47.1.
#143
ok thanks i thought i checked this and only saw _008 in the pop window of files to select. i'll take another look to see if i missed _009.
#144
I read this entire thread...what are the settings for a 2014 x3? I have the NBT, HUD, and extended instrument cluster....
#145
KOMBI 3000 HUD_ENTERTAINMENT_ENABLE KOMBI 3000 HUD_SPRACHEINGABE_ENABLE KOMBI 3000 HUD_TELEFONBUCH_ENABLE KOMBI 3000 HUD_TELEFONANRUF_ENABLE
#146
I clicked on detect caf for Kombi module and only options that came up were the _008 files. No option to select the newer 069_009_000_042. Any other suggestions would really heLp
Once again, I'm trying to enable HUD_Entertainment and HUD_Telephone on 2011 F01. all other coding functions seem to be available including HUD_turnsignal. Thanks. |
#147
#148
2011 F10 (6/18/10 prod) HUD coding
Just started playing around with coding this weekend. Successfully enabled turn-signals in HUD and mirror close from CA/FOB.
Struggling to understand if entertainment/telephone recents in HUD is even really an option given my production date. I did have my car flashed last week to 2.49.2 but I do not see the following in the KOMBI module in e-sys: HUD_ENTERTAINMENT HUD_TELEFONANRUF_ENABLE HUD_TELEFONBUCH_ENABLE I have searched for HUD in other modules (HU_CIC) but not seen anything similar. Any thoughts? |
#149
I would seriously consider a 6WA Kombi retrofit. The display is so much nicer, with or without HUD.
#150
Thanks Shawn. Since I already have the latest software, is it just a simple swap of the display (looks easy per youtube video) or is it more involved? What additional benefits do I get besides extended info (telephone/entertainment) HUD? Is this something i can purchase from bimmertech or does it have to be ordered from dealer? |
