Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 01-15-2013, 09:36 AM
thrush40 thrush40 is offline
Mein Auto: 2007 328xi coupe
oil filter question 2007 3 series N52
EDIT: Ignore. Found what I needed. Thanks for looking.
Hi all,
I did search, but didn't find the information I was looking for.
2007 N52 (E92)
At the dealership a couple months ago, they told me I was due for a new oil filter. They would not change it, however, when they discovered that a performance filter had been installed. The SA told me: "buy a cleaning kit...easy to do...available at any parts store...oh, had here's a BMW filter just since you're owed one." BTW, he also said the tech remarked that my filter wasn't very dirty and that this wasn't an issue or immediate concern
Questions: is the performance filter really as easy to clean and replace as he suggested?
Is there a good DIY video or write up for this?
Could I remove the performance filter and just put in the BMW paper filter for a while?
In other words, what do I need to know OR should I just go to my indy place and ask them to do it?
Cheers and thanks in advance,
Ben
