I am looking for a cheap way to wire my subwoofers into my e39. I have the stock radio and love it. I am in no rush to replace it. How would I go about this?
How can we help if you don't identify what subwoofer you have?
Im sure he is asking about "any" subwoofer that is non oem. Could be wrong
![]() Touring the nation, one state at a time |
In the trunk where locate the amp and the main wire harness. This is what you will tap your line into with a line output converter ($20)
What year is your e39? Do you have DSP Depending on the year and whether or not you have DSP factors the wire pins.
TRUELY OEM. |
Search YouTube for BSW installation guide. You'd need an amp to power those separately from the stock amp though.
![]() 01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT |
Second, you can take a signal from the amp (see post #4) or you can tap into a speaker wire. However, only certain subwoofers can do the latter. He needs to be specific if he expects any real help. |
. Not trying to argue, I just dont see the point in being over technical when you most likely have an idea of the general answer to the question. Specific questions get specific answeres vague questions get vague answers.... maybe he wanted a vague answer?
I have an 02 E39 Msport and my subs just stopped working.. Any suggestions??
Buy low, sell high.
Hi,
Anothergeezer - fantastic advice for a good overall financial view !! GQJQ - can you update with what troubleshooting/fault finding you've done so far please? Cheers, Dennis! |
ESS Tuning m60 version software m60 intake manifold a.f.e. c.a.i. 3" obx catback full powerflex urethane setup 545 ssk cdv delete m5 rear sway bar M5 chassis rods M5 3.15 lsd Bc-r coilovers w/ swift springs Akebono=suck ss braided brake lines coming soon: Jb lwfw
Inputting the signal into a powered subwoofer varies, depending upon the brand. Some only allow line level (RCA) inputs. Many subwoofers allow two types of signal input: line level inputs and speaker level inputs. The Infinity Basslink allows both as does my Blaupunkt. The line level input is the same signal you get at the back of a preamp/amp or receiver. The speaker level input is simply tapping into the powered speaker line. The latter approach means that the volume of the subwoofer is directly proportional to the volume of the speaker line it is connected to. Without knowing specifically what subwoofer he is attaching, we are speculating as to the solution to the problem. Refer to the subwoofer user manual for detailed guidance. |
