BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#126
I have a Internet option now, but gives the error 'Not available for your country'
#127
That usually indicates you either did not "update services" though the iDrive menu, or there is an issue with the VIN you are using. Did you read the VIN back from the Combox and confirm it is the donor VIN?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#128
I think that in Europe Internet works only in UK, Germany and maybe Austria. I bought my 528i in UK and it worked while I was in UK and in Germany, but when I came back to Croatia, where I live, I got the same "Not available..." message
![]() If you were buying the car from authorized dealer in Poland, you probably couldn't buy this option because it's not supported in Poland. It's not the problem with VIN, I think, but with the fact that BMW does not support internet in every European country. |
#129
#131
#132
I did everything that was needed, but the internet further displays a message "Internet is not available in your country" When I update the services it downloads 5 kb of data and nothing has changed. VIN of the donor's ok.
Here is ma trace files: mcic Code:
TYP_LENKUNG linkslenker SPRACHE englisch koreanisch china_trad russisch BT_UFN wert_01 USED_MICROPHONES wert_01 PHONE_TYPE_JAPAN nicht_aktiv RINGTONE ringtone_1 RSE_HIGH nicht_aktiv TDA_CFG_CUST_MOBILE_USE_M aktiv TDA_DEACTIVATE_STATUS_M nicht_aktiv BT_OBJECT_PUSH nicht_aktiv MICROPHONE_SENSITIVITY l4_mic PB_DOWNLOAD_PRIORITY wert_03 INBAND_RINGING nicht_aktiv CONFIG_INDEX config_index_3 DPAS_INDEX dpas_3 TESTCALL_FLAG_ENABLE nicht_aktiv A2DP_AVRCP_EIN_AUS aktiv AKD_SUPPORTED_POIS wert_25 API_EIN_AUS_MED nicht_aktiv API_IPOD_ONE_WIRE aktiv API_IPOD_TWO_WIRE_SERIEL aktiv API_TWO_USB_M nicht_aktiv AUDIO_NOTES_EIN_AUS nicht_aktiv AUDIO_SOURCE_FILE file_1 AUDIO_VERSTAERKER wert_01 AVRCP_BROWSING_EIN_AUS nicht_aktiv CALENDAR_EIN_AUS aktiv CAR_TYPE_IPOD_LOGO bmw CONTACT_NUMBERS_BCALL_M nicht_aktiv CONTACT_NUMBERS_DEALER_M nicht_aktiv CONTACT_NUMBERS_HOTLINE_M nicht_aktiv CONTACTS_EIN_AUS aktiv DATACOMM_CSIM aktiv DATACOMM_INTERFACE mamac DRM_CHIP_ENABLED aktiv DUN_PROFILE_M aktiv EMAIL_EIN_AUS nicht_aktiv EXTERNAL_CALL_LISTS_M aktiv FBLOCK_PHONEBOOK_EIN_AUS nicht_aktiv GPS_FROM_MOST nicht_aktiv GPS_POSITION_TIMEOUT wert_01 HEAD_BOOT_UP_TIMEOUT wert_15 HEAD_UNIT_MODEL cic_mid_rueko HEATING_CONTROL_ENABLED aktiv HORN_CONTROL_ENABLED nicht_aktiv INCOMING_CALL_LIST_M aktiv IP_ROUTER aktiv LIGHT_CONTROL_ENABLED nicht_aktiv M_SECURITY_MODE_AEH des_cbc M_SECURITY_MODE_AEP aes_128 M_SECURITY_MODE_ASH des_cbc_mac M_SECURITY_MODE_ASP hmac_sha_256 MAIN_BOARD_ALONE ecallboard_present MED_SVS_EIN_AUS nicht_aktiv MMS_EIN_AUS nicht_aktiv MULTI_PARTY_CALL_M aktiv MY_INFO_SUPPORTED_POIS wert_25 ONLINE_ROUTER aktiv PHONEBOOK_NAME_DISP_ORD_M last_first PICTURE_VIEWER_EIN_AUS aktiv PIM_BILDER_EIN_AUS aktiv POWER_FOLLOW_UP_THRESHOLD wert_01 RDL_CONTROL aktiv RDU_CONTROL_ENABLED aktiv REMINDER_EIN_AUS aktiv REMINDER_TRIGGERS_EIN_AUS aktiv RESPONSE_ON_HOLD_M nicht_aktiv SECURE_SIMPLE_PAIRING_M nicht_aktiv SIM_ENABLED_MB csim SMS_EIN_AUS_MED aktiv SORTING_VARIANT_M standard STARTUP_ACTIVE nicht_aktiv SVR_ENABLED aktiv SWUP_ASK_CONF_ENABLED aktiv SWUP_ENABLE_ENG_UPDATES nicht_aktiv SWUP_ENABLE_SW_UPDATES nicht_aktiv SWUP_SOURCE_ONLINE nicht_aktiv SWUP_SOURCE_USBMSCDD nicht_aktiv TASK_EIN_AUS aktiv TDA_CFG_IND_PDM_GR_NBR_M file0 TDA_CFG_TSM_TRIGGER all TDA_FBLOCK fblock_df TDA_TSM_ACTIVE aktiv TELEMATIC_COUNTRY_VARIANT row TELEMATIK_VIN coding_vin TELEX_M aktiv TEXT_NOTES_EIN_AUS aktiv UNICODE_EIN_AUS nicht_aktiv USB_HUB_M nicht_aktiv VCARD_OVER_MOST_M aktiv VENTILATION_CNTRL_ENABLED aktiv VIDEO_PLAYER_EIN_AUS aktiv BT_EIN_AUS_MED aktiv OFFSET_BTAS wert_00 OFFSET_IPOD_SERIAL wert_00 COVER_ART_TWO_WIRE nicht_aktiv ETHERNET nicht_aktiv PAN_PROFILE_M aktiv FOLLOW_UP_TIME_EXTENSION wert_02 SWUP_CYCLIC_MONITORING wert_20 SWUP_CYCLIC_RESET_TIMEOUT wert_255 SWUP_CYCLIC_RST_THRESHOLD wert_05 HANDSFREE_SECONDARY nicht_aktiv Code:
TYP_LENKUNG linkslenker SPRACHE franzoesisch BT_UFN wert_01 USED_MICROPHONES wert_01 PHONE_TYPE_JAPAN nicht_aktiv RINGTONE ringtone_1 RSE_HIGH nicht_aktiv TDA_CFG_CUST_MOBILE_USE_M aktiv TDA_DEACTIVATE_STATUS_M nicht_aktiv BT_OBJECT_PUSH nicht_aktiv MICROPHONE_SENSITIVITY l4_mic PB_DOWNLOAD_PRIORITY wert_03 INBAND_RINGING nicht_aktiv CONFIG_INDEX config_index_3 DPAS_INDEX dpas_3 TESTCALL_FLAG_ENABLE nicht_aktiv A2DP_AVRCP_EIN_AUS aktiv AKD_SUPPORTED_POIS wert_25 API_EIN_AUS_MED nicht_aktiv API_IPOD_ONE_WIRE aktiv API_IPOD_TWO_WIRE_SERIEL aktiv API_TWO_USB_M nicht_aktiv AUDIO_NOTES_EIN_AUS nicht_aktiv AUDIO_SOURCE_FILE file_1 AUDIO_VERSTAERKER wert_01 AVRCP_BROWSING_EIN_AUS nicht_aktiv CALENDAR_EIN_AUS aktiv CAR_TYPE_IPOD_LOGO bmw CONTACT_NUMBERS_BCALL_M nicht_aktiv CONTACT_NUMBERS_DEALER_M nicht_aktiv CONTACT_NUMBERS_HOTLINE_M nicht_aktiv CONTACTS_EIN_AUS aktiv DATACOMM_CSIM aktiv DATACOMM_INTERFACE mamac DRM_CHIP_ENABLED aktiv DUN_PROFILE_M aktiv EMAIL_EIN_AUS nicht_aktiv EXTERNAL_CALL_LISTS_M aktiv FBLOCK_PHONEBOOK_EIN_AUS nicht_aktiv GPS_FROM_MOST nicht_aktiv GPS_POSITION_TIMEOUT wert_01 HEAD_BOOT_UP_TIMEOUT wert_15 HEAD_UNIT_MODEL cic_mid_rueko HEATING_CONTROL_ENABLED aktiv HORN_CONTROL_ENABLED nicht_aktiv INCOMING_CALL_LIST_M aktiv IP_ROUTER aktiv LIGHT_CONTROL_ENABLED nicht_aktiv M_SECURITY_MODE_AEH des_cbc M_SECURITY_MODE_AEP aes_128 M_SECURITY_MODE_ASH des_cbc_mac M_SECURITY_MODE_ASP hmac_sha_256 MAIN_BOARD_ALONE ecallboard_present MED_SVS_EIN_AUS aktiv MMS_EIN_AUS nicht_aktiv MULTI_PARTY_CALL_M aktiv MY_INFO_SUPPORTED_POIS wert_25 ONLINE_ROUTER aktiv PHONEBOOK_NAME_DISP_ORD_M last_first PICTURE_VIEWER_EIN_AUS aktiv PIM_BILDER_EIN_AUS aktiv POWER_FOLLOW_UP_THRESHOLD wert_01 RDL_CONTROL aktiv RDU_CONTROL_ENABLED aktiv REMINDER_EIN_AUS aktiv REMINDER_TRIGGERS_EIN_AUS aktiv RESPONSE_ON_HOLD_M nicht_aktiv SECURE_SIMPLE_PAIRING_M nicht_aktiv SIM_ENABLED_MB csim SMS_EIN_AUS_MED aktiv SORTING_VARIANT_M standard STARTUP_ACTIVE nicht_aktiv SVR_ENABLED aktiv SWUP_ASK_CONF_ENABLED aktiv SWUP_ENABLE_ENG_UPDATES nicht_aktiv SWUP_ENABLE_SW_UPDATES nicht_aktiv SWUP_SOURCE_ONLINE nicht_aktiv SWUP_SOURCE_USBMSCDD nicht_aktiv TASK_EIN_AUS aktiv TDA_CFG_IND_PDM_GR_NBR_M file0 TDA_CFG_TSM_TRIGGER all TDA_FBLOCK fblock_df TDA_TSM_ACTIVE aktiv TELEMATIC_COUNTRY_VARIANT row TELEMATIK_VIN most_vin TELEX_M aktiv TEXT_NOTES_EIN_AUS aktiv UNICODE_EIN_AUS nicht_aktiv USB_HUB_M nicht_aktiv VCARD_OVER_MOST_M aktiv VENTILATION_CNTRL_ENABLED aktiv VIDEO_PLAYER_EIN_AUS aktiv BT_EIN_AUS_MED aktiv OFFSET_BTAS wert_00 OFFSET_IPOD_SERIAL wert_00 COVER_ART_TWO_WIRE nicht_aktiv ETHERNET nicht_aktiv PAN_PROFILE_M aktiv FOLLOW_UP_TIME_EXTENSION wert_02 SWUP_CYCLIC_MONITORING wert_20 SWUP_CYCLIC_RESET_TIMEOUT wert_255 SWUP_CYCLIC_RST_THRESHOLD wert_05 HANDSFREE_SECONDARY nicht_aktiv Last edited by gumes; 11-17-2012 at 10:18 AM. |
#133
Does Data Connection show under phone as an option?
#134
Maybe in the business version is not work? My SW: TX-002.005.025-002.005 My fa.trc : E90_#0910&EBAT%0475$1CA$1CB$1CC$1CD$216$230$249$255$2K9$2PA$ 320$321$423$428$441$464$465$4CG$508$520$521$534$54 0$548$606$614$615$616$644$698$6AA$6AB$6AL$6VC$863$ 881$8A1$8S3$8TL$8TN-A090 |
#135
Apart from testing many different phone models, I was asking if you have an actual paid Tethering / Hotspot plan with your Cell Phone provider?
#136
Besides, on this website http://www.bmw.de/de/de/owners/conne...check_tool.jsp "BMW internet" business version does not work with any phone. Last edited by gumes; 11-19-2012 at 02:55 PM. |
#137
#138
it seems that the "BMW Internet" in 606 only works with built-in SIM card. But I will keep try.
#139
SA644 and SA614 = Mobile Phone SIM / Data Connection This is why you must kill BMW Assist to enable Bluetooth Tethering.
#140
I don't have my login information on the BMW Online, maybe this is the problem?
#142
No, that is not it, as it is not required.
#143
I will try it. but the country VO $866 will have an impact? my VO include: 609,614,615,616,620,644,654,676,6aa,6ab,6ak,6al,6a m,6ap,6ar,6fv,6nf,6nl,6nr,6va,6vb,6vc,7sp,866 |
#144
I am not sure about 866. That is for Chinese Language, but it is not the same as a Country Controller code like one of the 8Lx codes (e.g. S8LHA Country controller for Hong Kong).
#145
609,676,6nk,6vc (star from 6) and i have National version China: L8AA. remove this one? Zeitkriterium=0411 ,this one need to change? Thanks! |
#146
I would leave it and try it, and then if you can't get it working, then remove it. Your Production Date of 0411 should be fine as it is.
#147
I write two VIN with 614,615,but not work still. and i remove 8AA but lose navi. and i try to add VO 8AA not succeed. and i tick then code defult values with CIC. everything goto factory . i try to code SVT, but at last CIC retune error and factory setting still.. ![]() ![]() can you help me do something!!! Thanks! |
#148
Caf's werden gesucht Tal wird generiert NCD werden gelesen FDL CAFD-000000F9-07.03.0B signieren. Abarbeitung wird gestartet TAL execution started. [C205] ExecutionID=2013/01/16-19:30:21.058 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [HU_CIC - 63] prepareECUforCoding started [HU_CIC - 63] prepareECUforCoding finished [HU_CIC - 63] authenticateECUforCoding started [HU_CIC - 63] authenticateECUforCoding finished [HU_CIC - 63 - cafd_000000f9-007_003_011] Transaction type: cdDeploy; Message: TA started MCDDiagService [HU_CIC - 63 - cafd_000000f9-007_003_011] Transaction type: cdDeploy; Message: TA finished [HU_CIC - 63] finalizeECUCoding started [HU_CIC - 63] finalizeECUCoding finished [Exception - HU_CIC - 63] job failed with negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code conditionsNotCorrect; ECU: HU_CIC_63_ETHERNET severity: ERROR [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "FinishedWithErrorInTransaction". [C207] TAL execution finished. Duration: "31s". [C206] Abarbeitung beendet |
#149
![]() I will contact you shortly via Blackberry.
#150
I hit once time,but code ECUs restored.
But this time I can't, because before removed the 8AA VO. |
