#201
Thanks.
I thought it was the wrong cable. Ive contacted the seller to see if they can refund or replace it. Nothing i can do to make this cable work without additional hardware though? |
#202
Thanks |
#203
1st option
Buy this adapter additional to your existing cable: http://www.ebay.com/itm/BMW-Diagnost...1&cmd=ViewItem This solution is pretty flexible, will work with any model from 1998. You might run into a car which needs the female-male OBD2 adapter what this kit doesn't contain. 2nd option buy the cable pshovest suggested and buy the additional adapter above. This solution will be the most flexible, will work with any model from 1998. 3rd option: http://www.ebay.com/itm/BMW-USB-OBD-...1&cmd=ViewItem this will work with your father's car, but not on newer models with D-Can Last edited by acoste; 08-01-2012 at 03:01 PM. |
#204
Thanks for your help buddy.
What models will need the male/female connector? Knowing our luck we will need it! As i say just 4 wires to obd socket in car. |
#205
2nd solution works also with F series, the 1st doesn't.
#206
Just bought the 20 pin connector got a red light on lead but it still wont work!
It wont work with monoscan either... Anyone know exactly what cable will definitely work with a 98 520i? Thanks |
#207
#208
Will this work?
http://pages.ebay.com/link/?nav=item...d=150842075176 |
#209
My third solution definitely works on a 98 528i
But the setup is not easy. Especially on a 64bit machine. You have to change some settings for the com port. Some people say, not all of the usb-serial chipset works with Inpa. Read a lot about the setup before ordering a new cable. Sent from my ADR6350 using Bimmer App |
#210
Can somebody help me out please i need to synch dme to ews using inpa. Ppl say it takes couple mins but i cant find step by step instructions. I have code 2737 ( tamper protection) replaced watercooled alternator/starter/ and integrated supply module, i appreciate all the info. Dont really want to tow the car to the dealer
I bought the program and have everything running on a dell d610 I ran a full diagnostic with carsoft and tomorrow will be trying inpa, I will post back.
00 BMW 528ia Sport M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs. ![]() |
#212
Is there any software that runs under windows to read and write odometer values for BMW?
#213
thank you bluebee for your great info it really helped me BIG TIME!!
inpa works great now i am going outside to play around with NCS and try the auto lock at 5MPH feature.
#214
If anyone can help me make sense of all of this. All I need is to reprogram my passenger airbag module to have the correct vin and I cannot find a write up anywhere for it. Please help.
Cable for 2007 BMW 525i
I need to register the battery in my 2007 525i. Can someone suggest me the correct cable/adapter? Too much info and i am confused. Thanks in advance.
#216
http://www.one-stop-electronics.com/...&product_id=16 I am not sure what to use to register the Battery though. Maybe Tool32 or INPA, and possibly NCS Expert.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#217
There was A LOT of research and set-up, in addition to the required hardware, needed to program/register my battery. It was some time ago but this thread provided a solid base. Good luck!
#218
Thank you! @ shawnsheridan and @ grimloktt
#219
I'm trying to make sense of the basics of this. Is this suite basically a cheaper version of the Bavarian Technic tool and software? I'm guessing functionalities are basically the same (albeit the interface on the bav tech one looks better). I'm looking for a better BMW specific diagnostic tool other than a generic OBDII reader and I guess deciding between this and getting the Bav Tech software/adapter.
#220
Cross referencing to this thread today:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#221
HELP!
I have a 2007 525i (E60) and i tried to register my new battery and it is giving me this error. "ERROR_ECU_CONDITIONS_NOT_CORRECT_OR_REQUEST_SEQUE NCE_ERROR" Cable: INPA Compatable K + DCAN USB Interface Software: EDIABAS TooSetl32 Group files used: MSV70.PRG & MSV80.PRG I tried both group files above with car started and with just ignition on. Any help appreciated. |
#222
You're more likely to find help in this forum devoted to BMW software. http://forums.bimmerforums.com/forum...play.php?f=233
Regards RDL |
#223
Bluebee I would like you to contact me on morganbavaria@gmail.com to ask you couple of questions regarding programming and coding... Thanks in advance
#224
This is in the bestlinks, and it has all the major programming & coding forums: - BMW factory & dealer programming, coding, and diagnostic software such as INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman (1) (2) (3) (4) (5) (6) (7) (8) (9) & related BMW diagnostic-tool forums (1) (2) (3) (4) (5)
#225
Thank you so much ...
but I c these programs are for Models until 2003 or its until present models ? |
| Tags |
| acronyms, carsoft, diagnostic tools, glossary, inpa, ncs |
