The dreaded seat twist hit my E39 540i... - Bimmerfest - BMW Forums
Old 06-15-2008, 10:59 PM
MMMM_ERT's Avatar
MMMM_ERT MMMM_ERT is offline
Number 12 of 5 or 6
Mein Auto: Non-green vehicles
....and thanks to the interwebz...and a couple bloody knuckles...It's fixed for $3.00 worth of parts.
My driver seat stopped working properly...ie the seat back tilt...only one side would go up or down and the seatback would twist.
Using these instructions for an E34 and applying them to the E39...I removed the seat from the car and tested with a power drill to make sure the gearbox wasn't toast. Then, I was able to cut and shorten the sheath of the drive cables and "ghetto" it back together with some fuel line and fuel clamps.
I'm posting this for anyone else who may run into this in the future.
These are the threads I found out there...
http://www.nmia.com/~dgnrg/page_11.htm
http://bimmer.roadfly.com/7series/me...9w35/4172.html
http://www.bimmerboard.com/forums/posts/517802
http://www.bimmerfest.com/forums/sho...ght=seat+twist
Originally Posted by enamoured View Post
This thread just got mmmerted.
Originally Posted by DSXMachina View Post
Hey, hey, if it weren't for MMMM_ERT Off Topic would totally suck.
Old 05-10-2011, 12:19 PM
EuroTrash540i EuroTrash540i is offline
Mein Auto: 00' 540i
I still need to do this along with the headrest and the up/down adjuster. I love my e39
Old 05-10-2011, 12:28 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
perfect seats
send from space command
15486372<-----
Old 05-10-2011, 12:44 PM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
Originally Posted by Phlyers8 View Post
Anyone in the Southern California area, I will fix your seat twist for $300 per seat (depending on location). I have done a number of them now and have a solution that has yet to fail. E-mail me @ rjkidder32@msn.com
Dude stop trolling
Old 01-15-2013, 12:33 PM
Stone Roots's Avatar
Stone Roots Stone Roots is offline
Mugicinal Engineer
Mein Auto: 2003 E39 2009 E60
I found someone on craigslist who said hed charge $180 to fix both seats. I've spent the last two days trying to figure out how to fix these damn things. Ive seen a few different ways to fix them and im not sure which method to use and its just causing a huge headache - so im just going to pay this guy to fix it. If he ends up fixing them ill pass his number along if any one is interested.
Old 01-15-2013, 03:51 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Go search "terabass e39 seat repair" on youtube, you'll be amazed by what you see, anyone who dares charge more than $25 a seat for this is an arse. I cant post the link ATM since im on a phone.
I'm not sure if it applies to the bottom of the seat too.
[SIZE="1"]2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
Stuff For Sale: PM for info
E39 OEM Technical Graphite Trim / High Polished Black & Biege / Maple wood [Click]
E39 OEM High polished Gray Trim / Matt Chrome Interior [Click]
E38 750iL Chrome Door sills & Roof handles
E38 OEM 750iL Brake Caliper Upgrade kit (F+R)
All types of E39 OEM Used HVAC Buttons
Old 01-15-2013, 03:58 PM
Mugicinal Engineer
So just cut the outer sheath of the cable and the seat will work? If that is the case why are some people removing cables and motors and adding fuel lines and clamps and all these other things?
Old 01-15-2013, 04:04 PM
Dking078's Avatar
Member Supremo
I honestly have no idea. The main thing i see people doing is taking the cable out of the motor itself, shortening the sheath at the tip and then re heating the end metal link-thing back on. (It accomplishes the same thing here i guess) i linked the video in another twist thread not too long ago and another member said it worked.. Im so lazy and keep putting off fixing my passenger seat, but i will use Terabass's method for sure.
Old 01-15-2013, 05:57 PM
Studawg's Avatar
Studawg Studawg is offline
Mein Auto: 2003 540iT M Sport
I did this myself after watching the video just a couple of weeks ago. I had two adjustments on the passenger side that didnt work and 1 on the driver side that didnt work. Fixed all three by cutting out a piece of the cable, didnt have to remove seats or anything.
Old 01-15-2013, 10:35 PM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
lol its so simple i wouldnt have someone else do it. the hardest part of it is removing the seats. after that you can look at the parts and you will know exactly what you have to do. you dont even need to read DIYs. trust me as soon as you look at the bottom of the seat you will know what you gotta do.
Old 01-15-2013, 11:18 PM
Mugicinal Engineer
Well I got both the seats out that was easy. I've read every DIY on seat twist and there are conflicted methods. I just don't want to ruin the seat...
Old 01-15-2013, 11:57 PM
MikesE39's Avatar
ok the problem is that black plastic stretches and unplugs the coil that is inside it from the motor. so all you have to do is cut off 1 inch or so, or maybe less of that black plastic and join the 2 ends of the black plastic together with a hose clamp or something like that. then plug the coil that is inside the black plastic where it belongs. nothing can go wrong as long as you only cut the black plastic.
Old 01-15-2013, 11:58 PM
MikesE39's Avatar
dont forget to unplug the battery so you dont risk any codes, or airbag lights or something in your dash.
Old 01-16-2013, 12:08 AM
Mugicinal Engineer
Now see that contradicts the Terabass video that shows him simply cutting the outer sheathing and not adding or clamping anything...
Old 01-16-2013, 06:23 AM
Studawg's Avatar
you dont need to remove seats or clamp anything
Old 01-19-2013, 04:23 PM
ztitans1 ztitans1 is offline
Mein Auto: 1997 528
Thank you for the link
My driver's side seat just started doing this. I tell you what. The drive train on this car is bulletproof, but I feel like everything else is crap. As soon as I fix something another item breaks.
I just love this logo...
Old 06-18-2014, 12:39 AM
cclcal cclcal is offline
Mein Auto: 525iT
Both seat back were twisted. Did not remove seats, just looked underneath and found which black cable it was by feeling it while i moved the seat back, the vibrating one was the one to cut. Just heated it up w lighter and
removed about 1.5 cm of sheathing. Cut it while it was soft.
I had a hot knife but was out of butane. That would have made the job even easier. No clamp, no tape.
Used an utility knife and wire stripper. 23 minutes for both seats. Seat backs work like new!
thanks to terabass on m5board for simple fix.
Local shop wanted 200$, said it was labor intensive, parts are inexpensive.
Im happy!
