6 Series
Old 01-11-2013, 10:34 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Good to hear it's all fixed. That is a huge bill to have to swallow but actually you go a great deal. I've never seen the center water pipe (cap with seal) fixed for anywhere close to that amount. Normally the charge is at least $2K at an indie.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 01-12-2013, 05:43 AM
vegas645 vegas645 is offline
Mein Auto: 2005 645ci convertible
Thanks Yorgi. I was driving it yesterday and when I turned it off the oil can symbol popped up. I don't get a message in the I drive though showing that I need to add a quart. When I checked the dipstick it looked spot on. I changed about 3k ago.
Old 01-16-2013, 12:07 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Living in Fast Forward
Mein Auto: 2007 E63 650i
Originally Posted by vegas645 View Post
I just got the 6 back from the shop today and here is what was done.
R+R intake and replaced valley plate (Cap) with seal. $1488
Replaced leaking valve cover and upper timing cover seals. $1304
Replaced micro filters.
Brake fluid flush.
Coolant system flush
The car runs much better!!
$3,208
Glad to hear that she's well again!
Once a 6'er, always a 6'er.
Old 01-16-2013, 12:10 AM
07 E63650i's Avatar
Originally Posted by Yorgi View Post
Yes, the petrol cap that you need to remove every time you fill up the car.
There is a rubber seal on this cap that dries out over time and compresses after hundreds of removals, resulting in a less-than-air-tight seal. All modern (OBDII) emission systems pressurize the fuel/petrol tank. Any loss in pressure triggers a check engine light - the assumption being if pressure is leaking from the tank so are fuel vapours into the environment.
Germans are notorious for using low silicon content plastics and rubbers because they are very environmentally conscious. They want the plastics used in cars to eventually break down once the car is retired. The problem is that the plastics start breaking down too soon, within 8 to 10 years, and you start getting all sorts of electrical connection issues and plastic hoses/tanks failing.
The Asians are not afraid to use high silicon plastics and this is one of the reasons they have greater reliability over the Germans.
Ah, that explains why Asian vehicles tend to have better reliability. My theory is that BMW is very good at 'planned obsolescence'.
Old 01-16-2013, 12:11 AM
07 E63650i's Avatar
Careful not to overfill, as that can cause some serious issues.
Old 01-16-2013, 01:16 AM
BMdude816 BMdude816 is offline
Mein Auto: 2004 BMW 118
Sorry to hear about this big pile of work. But, glad to hear you just got it back. At least, you're good to go already.
Old 01-16-2013, 05:44 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
What is good about the cost spent is that you have added real life to your car, just make sure you use BMW own brand coolant fluid, even if you have to redo it!!!! This will protect the coolant system as it should be!!!!
Does my bum look good in this !
