Old 01-04-2013, 02:21 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
48.1 vs. 48.2 PSdZData CAFD Changes
FYI. The difference from 48.1 to 48.2 for the CAFD folder only is 3 added:
Left base folder: C:\Users\SS09546.IT\Desktop\48.1_SPdZData
Right base folder: C:\Users\SS09546.IT\Desktop\48.2_SPdZData
Left Orphan Files (0)
Right Orphan Files (3)
cafd_00000b0a.caf.000_024_000
cafd_00000c18.caf.012_017_006
cafd_00000552.caf.001_026_011
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 01-04-2013, 03:14 PM
marsb007 marsb007 is offline
Mein Auto: 2013 535i
Can you send me those files please? Thanks!!!
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
So this wont need the other files updates like the .JAR files? Adding these 3 cafd will get you updated to 48.2?
Coding Inquiry call 917-939-4980
Old 01-04-2013, 03:45 PM
Why, are you getting a [C012] Missing CAFD error?
- BMWCCA #446923
- flick
Old 01-04-2013, 03:46 PM
There are many other differences, but mostly to the flash files (swfl), which should not impact coding.
See attached.
- BMWCCA #446923
- flick
Old 01-11-2013, 03:36 AM
tankren tankren is offline
Mein Auto: 116i
dear shawn, I cant find cafd_000000f9-007_003_024 in 48.1, could u please PM the download link for these added files? thx
Old 01-11-2013, 07:23 AM
Bummel Bummel is offline
Mein Auto: F11 535d
This File is not included in 48.2 , it`s a part of 48.3!
Old 01-12-2013, 06:24 AM
radarguy radarguy is offline
Mein Auto: 2011 535ix sport
Just Wondering
The dealer reprogrammed my F10 this week and E-SYS reads the integration step as F010-12-11-503. The previous was F010-11-09-503. I used the 48.2 files to re-code and they worked. It appears the dealer did not use the latest 48.3 integration level. Does that sound correct?
Old 01-12-2013, 06:30 AM
How do you know he did not use 48.3? While I do know F010-12-11-503 is 48.2, what I don't know yet is is if 48.3 got a new Integration Level, or if it stayed at F010-12-11-503, the latter of which is likely. So, the bottom line is you have no way of knowing whether you got programmed with 48.2 or 48.3 without seeing the actual ISTA/P Final Report.
- BMWCCA #446923
- flick
Old 01-12-2013, 06:39 AM
I thought that both would change. I asked for, but did not receive the ISTA/P Final Report. Thanks for the clarification.
Old 01-12-2013, 06:42 AM
No, not always, unless a module got new firmware I don't thinks. For example:
ISTA/P 2.47.5 F010-12-07-533
ISTA/P 2.47.6 F010-12-07-533
ISTA/P 2.47.7 F010-12-07-533
So, it often does not change.
- BMWCCA #446923
- flick
Old 01-12-2013, 09:35 AM
Just to confirm, I now have the 48.3 PSdZData, and the F10 Integration Level is in fact unchanged, and is still F010-12-11-503.
- BMWCCA #446923
- flick
Old 01-12-2013, 10:52 AM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
any reason to upgrade from 48.1 to 48.3 ?
Minha patroa é um BMW
Old 01-12-2013, 10:56 AM
Maybe. In theory if your car has 48.3, you would want and need 48.3 PSdZData; however, since the I-Level for F10 went unchanged, 48.2 PSdZdata will likely still work fine on a car programmed with 48.3. Now for F20/F30 with 48.3 on it, I think you will need 48.3 PSdZData because the I-Level went from F020-12-11-504 to F020-12-11-505.
But an F10 with 48.3 on it an 48.1 PSdZData will also likely need new 48.3 PSdZData, as 48.1 went from F010-12-11-502 to F010-12-11-503 when 48.2 was released.
- BMWCCA #446923
- flick
Old 01-16-2013, 06:11 AM
The-Professor The-Professor is offline
Mein Auto: F11 530xD
Hi Shawn,
could you please send me a link to the file with the 48.1 vs. 48.2 PSdZData CAFD changes?
Thanks,
Max
Old 01-16-2013, 06:21 AM
Originally Posted by The-Professor View Post
Hi Shawn,
Thanks,
Max
I did from your other request in the other thread.
- BMWCCA #446923
- flick
