hex bolt holding on rotor stuck - Bimmerfest - BMW Forums
Old 01-15-2013, 05:30 PM
djchasman djchasman is offline
Mein Auto: 2002 325i
Hey all. I am trying to change out the rear bearing on my 325 and the hex bolt holding on the rotor is not budging. Any ideas on getting it off without damaging. Thanks all.
Old 01-15-2013, 07:47 PM
I typed /rotor F3 in the bestlinks and came up with this which may help:
- How to remove stuck rusted-on brake rotors (1) & how to remove a stuck 6mm brake rotor set screw (1)
Old 01-16-2013, 07:32 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Squirt it with PB blaster and let soak for 30 min or so. Then insert your hex socket into the bolt and pound the end of it with a big hammer a few times. Then turn, then hit it with a hammer again, and turn and so forth. Should break loose. If you have access to an impact wrench, set it to the low setting and try zapping it a few times with that.
Regardless of the method, the PB blaster soak makes all the difference!
Old 01-16-2013, 01:02 PM
hitbyastick hitbyastick is offline
FYI if anyone ever has the chance to get their hands on some Kroil do it. Soaking with that magical substance has enabled me to get away with not using a blowtorch more times than I can remember. It's expensive and hard to come by but worth it.
Old 01-16-2013, 04:42 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
The PB blaster is a must. I put the 6mm allen on an impact driver, whack it once, and it comes right out. I have this type Snap-On
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 01-16-2013, 10:03 PM
Mein Auto: '04 330Ci 6-speed
And keep in mind if you break it off, it is a 'convenience' item. You can run without it with no problem. The wheel bolts are really what holds the rotor in place.
