E46 (1999 - 2006)
Old 01-12-2013, 04:50 PM
Marky_N Marky_N is offline
Mein Auto: 2000 E46 318ci
Driver door handle
Sometimes when I open the door it's quite hard to open, also the door handle sticks in the pulled position.
Anyone know how to fix this?
Old 01-12-2013, 06:49 PM
BigMotherWheels BigMotherWheels is offline
Mein Auto: 06 325ci Coupe ZSP
Maybe this:
On the edge of the door pull out a small rubber plug and insert an allen wrench to fit the screw inside. Back it off and then tighten it down. It is reported that doing this several times will ease the action. I have done this but cannot verify that repeated times improves action. Secondly lubricate the mechanism by spraying a thin lubricating spray into the hole. It worked for me.
Old 01-13-2013, 02:08 AM
Ok thanks man. I'll get this done today! It's only recently been playing up, never had this problem before. Hopefully this will work.
Old 01-15-2013, 10:00 AM
Tried doing this yesterday and today. The bolt is as tight as it will go and it still struggles to open the door.
The feeling I have is .... I pull the handle to open, it's quite easy but it comes out quite far, and it feels like I need it to come out that extra tiny bit for it to open. I sometimes it opens fine, most of the time it feels like it isn't going to open unless I really pull on it
Old 01-15-2013, 11:55 AM
I really wish this had improved the action. Without looking at it myself it sounds like a component may be worn or broken. Taking it apart would be what I would do next. Also check in to how much a new handle/mechanism costs. You may even be able to repair it based on what you find.
Good luck.
Old 01-15-2013, 02:56 PM
No worries mate. Thanks for the input though. Going to get it apart this week sometime and see what else I can solve. Hopefully it's a sticking motion or maybe I need to lose off the bolt and push it down, so then the handle is giving abit more leverage?! I don't know. Anything is worth a try I suppose
Old 01-16-2013, 09:40 AM
I have finally sorted my door handle out!
With the cold weather over here at the moment it has made the grease on the locking latch get too thick, so it was working as grease should haha. So for now with this cold weather I have layered alot of WD40 on it and it now works like a charm! Fantastic!
Soon as the weather gets abit warmer I'll have to put on some more proper grease on there. Make sure it doesn't happen again
Thanks for the help though mate
