6 Series
Old 01-16-2013, 04:32 AM
M6Power M6Power is offline
Send a message via Skype™ to M6Power
Mein Auto: BMW 645CI
Dynamic Drive warning
The Dynamic drive warning keeps appearing on my 6 series, but it looks like everything is okay. If i turn the engine off and restart again it goes away. Anyone with a similar problem? or can anyone shed some light into this?
Thanks in advance,
Old 01-16-2013, 04:48 AM
daytona745 daytona745 is offline
Mein Auto: 645CI, CorvetteZ06
I had the same thing happen. Sometimes it's low power steering fluid. Often it is voltage related. I ended up having to replace the battery and alternator and no problems since.
Old 01-16-2013, 05:41 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
Hi! Always first thing is top up the power steering reservoir, doesn't take much to top up/not expensive. tThen do a dynamic drive reset, it is in the manual basically turn the steering wheel lock to lock a few times..... as said once done 9/10 it fixes the issue...
Does my bum look good in this !
Old 01-16-2013, 07:32 AM
colink colink is offline
Mein Auto: 2004 645Ci Convertible
Topping up the power steering fluid was the solution for me. Make sure you use the Pentosin fluid - not generic autoparts store fluid.
My level was very close to the correct level, but just adding a little to bring it up to the correct level resolved the warning.
Old 01-16-2013, 08:16 AM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645
Maybe stupid question but were do I check the fluid level?
Old 01-16-2013, 10:35 AM
Engine bay, passenger side, between the coolant expansion tank and the strut tower. Should be marked "CHF11S Oil Only".
There are always traces of the oil on the surface of mine around the cap. I think I am going to check whether there is a replaceable gasket under the cap.
Old 01-16-2013, 10:43 AM
D Woolley
Mein Auto: 05-645
Thx
