Will these rims work? - Bimmerfest - BMW Forums
Old 01-16-2013, 01:12 PM
Kdubs Kdubs is offline
Mein Auto: 2000 528i
I found 18 in rims for (i feel) a good price. They are from a 2004 525. I have a 2000 528i.
Here are some specs:
rims model number 105-8JJX18 5-holes ET15
Distance between lug nut holes - 7 cm
Distance from center of wheel to center of lug nut holes - 6 cm
Diameter of center hole in wheel - 7.4 cm
inside diameter of wheel - 44.6 cm
width of the tires - 23.5 cm
offset ET15
Will these work on my 528 the way it is or will modifications be needed?
Here is the post: http://madison.craigslist.org/pts/3513206600.html
Thanks for any helpful input!
Old 01-16-2013, 01:14 PM
the540wgn's Avatar
the540wgn the540wgn is offline
Mein Auto: '11 335xi/'02 540iT
offset ET15
no, you would need to mod
ColdWeather + Summer + Sport -- 20/30 Ceramic Tint -- Euro Armrest -- JL 13tw5-3 Subwoofer -- LED AEs
Old 01-16-2013, 01:23 PM
would it be expensive mods or something easy?
Old 01-16-2013, 01:36 PM
the540wgn's Avatar
Well It really depends on what you'd want to do.
I think the two basic options are to get them machined to spec or get wheel spacers/hub adaptors.
I've personally done neither so I cant really tell you price stuff.
Check out this thread though:
http://www.bimmerfest.com/forums/sho...d.php?t=614946
It looks like some guys got quoted for both
Old 01-16-2013, 01:51 PM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
You will need to bore out the center to 74.1
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 01-16-2013, 02:26 PM
Youngproexec Youngproexec is offline
CPR ..
Mein Auto: ..
+1. As illezte39 says you will need the center bore enlarged to 74.1mm since the e60 wheels you are attempting to buy are too small at 72.56mm . If you cannot find a shop to bore the wheels out search for hub-adapters. H&R makes trak hub adapters that will allow you to run those wheels safely.
Old 01-17-2013, 09:17 AM
tmvE39/E53/Z32's Avatar
You all missed this part in OP's first post (I make it bold) The dimension in "cm" throws you all off They are NOT OEM wheels for E60 so there's a very good chance that the hub-bore is NOT 72.56mm
I found 18 in rims for (i feel) a good price. They are from a 2004 525. I have a 2000 528i. Bolt pattern should be fine: 5x120 as they fit on 04 525i
Diameter of center hole in wheel - 7.4 cm <-- If this is true, you should be fine. No need for hub re-bored.
offset ET15<-- Offset is fine for 8" width wheel to fit on your E39
It seems like they would fit with NO modification nedded. Ask the seller if he used hub-rings on his car. He should have them. If he didn't and have no vibration, the dimension is not correct.
Old 01-17-2013, 09:36 AM
the540wgn's Avatar
My bad OP, definitely missed that
Old 01-17-2013, 05:41 PM
sweet i will ask the guy about the hub rings and hopefully ill be set. thanks for all the help, i really appreciate it!
